Installing a reverse light in your trailer hitch . . . .
Discussion in 'Lighting' started by Aron9000, Oct 23, 2018.
  1. Oct 23, 2018 at 12:12 AM
    Aron9000
    Aron9000 [OP] New Member
    Aaron
    Anybody done this?? I back into my dark ass driveway, back into spaces at night, mom and dad's house is a PITA to back out of their long ass driveway, really I'd just like some sort of reverse light on the rear bumper that works like a headlight.
    I'd be open to any kits that mount in that receiver hitch. I'd like to avoid drilling into my truck, I don't tow all that much either and I definitely am not connecting to a trailer in the pitch black middle of nowhere.
    Any recommendations on light kits? Brighter the better. I'd also like to know how you wired this sucker up. Did you use the trailer harness? Reverse light harness on the tail-lights?? I've wired up a few custom stereo installs, so I feel confident on the wiring aspect.
  2. Oct 23, 2018 at 2:39 AM
  3. Oct 23, 2018 at 3:28 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I used some single row leds and used bumper mounting bolts. I thought floods might be better but lights are spots. Actually the spots are probably better. Wired in to reverse wire at tail light.
    JoshuaA and Prostar 190 like this.
  4. Oct 23, 2018 at 4:32 AM
    Check out this thread, post #425
    https://www.tundras.com/threads/tri-state-area-members.20704/page-15
    PM Mike, @mgm16trdpro
    mgm16trdpro likes this.
  5. Oct 23, 2018 at 4:51 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I had the white night reverse spot lights on a previous truck. It’s very easy to install, bright and clean looking. 388EB2B1-5CC2-4DB6-BA28-57A17D3C6CE2.jpg
    Here’s another option with leds. This mounts around the hitch ball.
    JoshuaA likes this.
  6. Oct 23, 2018 at 5:15 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Hi Aaron, Jim tagged me to help. If u look at the post he tagged, I had a setup from hitchworks that worked great. Take a look at their site, they sell all different setups. Only reason I sold was my fault on too much of a drop on the hitch for my offroad use. Besides that it was great. I decided to put some baja designs squadrons cutout into just the black plastic part and I'm very happy with them now. Any questions feel free.
  7. Oct 23, 2018 at 5:44 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Changing out the reverse bulbs with bright LEDs and installing a Putco Blade gave me lots of white reverse light and killed two birds by adding additional safety, a bright red brake strip with turn signals for those following behind me.
    If that’s not enough, then any of the above solutions would give you headlight stength if that’s what you really need. The white wire right in the middle of the trailer harness is the reverse light tap.
  8. Oct 23, 2018 at 10:57 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    that is what I did. Looks like the same lights I used. I have a double row set on my boat trailer. I wanted a lower profile on the truck so went with the singles. I think they were less than $30 on Ebay or Amazon. The ones I have on the boat trailer have held up to probably 15 dunks on the ramp.
  9. Oct 23, 2018 at 11:04 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  10. Oct 23, 2018 at 9:40 PM
    mgm16trdpro
    Northern NJ
  11. Jan 3, 2021 at 4:07 PM
    CM2007
    CM2007 New Member
    Northern California
    2007 CrewMax SR5
    TRD Exhaust, Dark Tint, Bluetooth (2020 or earlier) License Plate Camera (2021) Tyger T1 Roll Up Tonneau (2021) Loncky leather steering wheel wrap (2021) Dechromed with Plasti-Dip (2021) Osram Reverse Bulbs (2021) Bilstein 6112s up front (April 2021) 2022/2023: New Head Unit (Android?) Sliders/concealed running boards
    Before I install any extra hardware I want to try the brightest reverse bulbs available...what are the brightest?
  12. Jan 3, 2021 at 5:03 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I first put leds in the reverse light sockets. They do well to the side but not straight back. I ended up adding recessed pods in bumper. This was after I had a set of single rows mounted to the bottom of the bumper that failed.
    CM2007[QUOTED] likes this.
  13. Jan 3, 2021 at 6:28 PM
    CM2007
    CM2007 New Member
    Northern California
    2007 CrewMax SR5
    Ok. Your case makes me wonder if there’s a way to redirect the brightest LED bulbs to a better angle...just a few degrees would make a big difference it seems like. Thanks for the info.
  14. Jan 3, 2021 at 7:48 PM
    Check out Vleds.
