Installing 6112/5160 need help
Discussion in 'Suspension' started by Bigolbaddy, Jun 28, 2020.
  1. Jun 28, 2020 at 11:31 AM
    Bigolbaddy
    Bigolbaddy [OP] New Member
    Ben
    Fort Worth
    2020 MGM 1794
    I picked up Bilstein 6112/5160 and I am preparing to install myself. I think I misunderstood what the 5160s will do.
    1. I thought that they provide 1.5” lift over stock but I’ve been reading that to get the lift, I still need shackles, is that correct?
    2. I have also been reading that shims will correct the lean, but most run 2 on driver and 1 on the other. Why not 1 and none? Is it for the added 1/4” lift?
    3. I have 285/75r17s on Icon Vectors +25. Will the added 1/4” be needed. The 6112 are set at 1.9.
    TIA
  2. Jun 28, 2020 at 11:36 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Regarding #1, the 5160's have the capability to do so because of longer travel but you need an actual shackle, block, or new leaf springs to actually raise the rear end by that much.
    atrinh15 and Bigolbaddy[OP] like this.
  3. Jun 28, 2020 at 11:42 AM
    AZBoatHauler
    So.Arizona
    Re 2, I installed one shim on driver and none on passenger. Nothing wrong with that. I didn’t care about the extra height, just wanted to even it out.
    can’t help on the tires. My 275/70 18 only rubbed the stock “skid plate/splash guard but I removed the front mud flap and air spat for looks.
    Bigolbaddy[OP] likes this.
  4. Jul 4, 2020 at 7:12 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I have my 6112s set at 1.9” with no shims and run 285/75/17s on Icon Rebounds with no rub. I also have 5160s out back.
    As you noted, rear shocks don’t cause lift. You need shackles, blocks, an add-a-leaf or a new leaf spring pack to add lift. The 5160s are designed to work with 0-1.5” of lift. Beyond that, you may over extend them and cause damage.
  5. Jul 4, 2020 at 7:20 AM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    I have 1 shim on the left, none on the right. Even that 1 might have been unnecessary because the difference was only 0.25".
    equin likes this.
  6. Jul 4, 2020 at 8:55 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Any lift in the rear is done wirh either:
    1- lift shackles
    2- lift blocks
    3- New leaf springs with lift built in
    The shocks do not provide any lift. The numbers you see associated wirh a rear shock are the amount of lift, above stock, they are capable of handling.
    NewImprovedRon likes this.
  7. Jul 4, 2020 at 10:28 AM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    Finished the install about 90 minutes ago. Killer in this N Texas heat. But it looks great IMO. SPC UCAs, Bilstein 6112 at 1.9 and 5160s. Last pic, where it’s circled is the drivers side rub. Haven’t fully inspected. Waiting until after the alignment. 638E5EF7-DA67-4F11-A6CA-F8AA389DC17D.jpg 6FC8D4CA-6935-4AD1-988B-FC254B5DDAC0.jpg C05B6967-0EBF-46BB-8BA2-47263B0AF5D6.jpg 773054E5-CC3D-48F8-A403-DD1185A48E7E.jpg 4C6F743C-A03F-45B9-8905-52D5E6B110DC.jpg CF7DF4F1-6B7F-4900-B1F9-DB54EAF31959.jpg
  8. Jul 4, 2020 at 9:46 PM
    KENNY
    KENNY New Member
    Those front mudflaps stick out a good amount, you can remove them and it doesn't look like anything was there.
  9. Jul 5, 2020 at 8:28 AM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    Your very right, I did remove those actually. That was the rear.
  10. Jul 5, 2020 at 8:35 AM
    Kanobi13
    Kanobi13 New Member
    Nice!!!
  11. Jul 5, 2020 at 5:11 PM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    Did this install with my pop and he wondered if the SPC ball joint would slide since is doesn’t lock into place. Anyone have this happen?
  12. Jul 11, 2020 at 7:09 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I have done SPC UCAs on my wife's 4runner and I was curious too...it's been 5 months and 5k miles and it's staying put...I hope it (they) stays "locked" in place!
  13. Jul 11, 2020 at 8:35 AM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    On my THIRD alignment. The adjustability of the UCA seems to be throwing everyone off, not understanding that they need to factor that into adjusting the Castor. I am getting worn out by this. Sorry for the vent.
  14. Jul 11, 2020 at 9:04 AM
    Danman34
    Danman34 New Member
    Danny
    Where are you bringing it to get done? I wound up finding a mom/pop chassis shop that does old school alignments. My truck never drove better after numerous attempts at franchise wheel and tire places.
  15. Jul 11, 2020 at 9:08 AM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    At a place that was recommended... we will see
  16. Jul 11, 2020 at 9:22 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Good luck! 4th times a charm...right?
  17. Jul 11, 2020 at 9:36 AM
    Murph2308
    Murph2308 New Member
    Man, this lift looks great. Well done! Hoping that 4th alignment does the trick!
  18. Jul 11, 2020 at 10:42 AM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    Thanks for the compliment, but no... the current alignment still didn't get it. It might be close enough to manage for a while. Calling SPC on Monday to ask if they have a place in DFW that they supply - will try going that route.
  19. Jul 11, 2020 at 10:45 AM
    Danman34
    Danman34 New Member
    Danny
    What are they having trouble with? The way it’s aligned is no different than with stock uca.
  20. Jul 11, 2020 at 10:58 AM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    From the SPC website: "Get your drivability and tracking back: When you lift your truck you affect caster and camber. SPC’s arms have +1° of caster built into them. Using its patented ball joint design the arm will get you 0° to +4° of caster and ±2° of camber, so you can put your alignmnet angles back to specification."
    The adjustments are made with these:
  21. Jul 11, 2020 at 11:01 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I go to the Firestone on Rufe Snow. The lead alignment guy there is an avid off-roader and always dials my numbers in perfect.
    I don't remember his name, but I'm sure you could call and ask about their experience with aftermarket UCAs and if they'd take a look.
  22. Jul 11, 2020 at 11:04 AM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    Thank you
  23. Jul 11, 2020 at 11:05 AM
    Squatting Pigeon
    Holden
    North Texas
    Happy to help!
    Keep us posted if you find somewhere that nails it for you.
  24. Jul 11, 2020 at 2:14 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Do what I did.
    Find the closest reputable lift install shop, and take it where ever they send lifts they do.
    Cost me a fortune (about $800 with parts) due to frozen LCA cam adjustment bolts that had to be cut out and replaced, but they saved my LCA's from also having to be cut off and replaced, and lubed the shit out of the new bolts where Toyota installs them dry, which causes them to weld together. I did 6112s with CB shims 2/1 for 3in total lift with SPC UCA'S also.
    Good luck!
  25. Jul 11, 2020 at 2:21 PM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    ironically, that is what I did and still didn’t get the rig aligned, lol.
  26. Jul 11, 2020 at 2:41 PM
    Seafury
    Agent K
    SC Low Country
    Well that sucks ass.
    Very sorry to hear that man!
    Maybe try another one?
    Certainly ask them if any of the adjustments are frozen, as they may all need to be moved. Did you set the UCA ball joints to the proper setting, or just straight on, or?
    My shop also got me almost exact specs I asked for, guess I got lucky.
  27. Jul 11, 2020 at 5:15 PM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
    2020 with 5k miles, so nothing is frozen. Set the ball joint to a or d, forget which. The name faces the rear of the truck.
    Seafury likes this.
  28. Jul 11, 2020 at 6:46 PM
    Seafury
    Agent K
    SC Low Country
    Good your truck is new.
    But my shop said they have seen it on brand new and 1 year old trucks even, take that for what it's worth. :notsure:
    As far as which setting to put the SPCs on, I can't proclaim to know for your setup, sorry can't help more there. Mine required name facing out to the side flat.
    Good luck and let us known how it goes :thumbsup:
  29. Jul 11, 2020 at 9:32 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Why are you replacing the UCAs ? Just curious. The stock UCAs with that setup should work fine and not be over extended from what i was told. Im about to do the same install soon but leave the OEM UCAs. What did they run you if you dont mind me asking?
    CaptainGrumpus likes this.
  30. Jul 11, 2020 at 9:45 PM
    Bigolbaddy
    Ben
    Fort Worth
    2020 MGM 1794
