Installed Powered Sub UNDER Rear Seat in ‘19 CrewMax
Discussion in 'Audio & Video' started by Xrtherapy11, May 27, 2024.
  1. May 27, 2024 at 8:52 PM
    Xrtherapy11
    Xrtherapy11 [OP] New Member
    mtucker likes this.
  2. May 27, 2024 at 10:03 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Nice, looks clean
    Xrtherapy11[OP] likes this.
  3. May 27, 2024 at 10:11 PM
    Xrtherapy11
  4. Aug 16, 2024 at 3:47 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Can you give us more detail on how you installed this? I am assuming you removed the factory sub and used the speaker wires from that to hook up to the new sub/amp and then ran the power wire to the battery? Any issues with the install or things you would do differently?
  5. Aug 17, 2024 at 1:10 AM
    JayMax03
    JayMax03 New Member
    2017 TSS Off Road Tundra
    How thick is that foam?
  6. Nov 30, 2024 at 8:53 AM
    Xrtherapy11
    I didn’t have a factory sub in my truck, but the install was very straight forward: I did run a heavy gauge power wire from the battery and the rest of the hookups were achieved through tapping into the wiring at the factory amp, under the seat. I used a LOC and grounded at the rear of the truck. Can’t think of anything I would have done differently. It came out as planned.
  7. Nov 30, 2024 at 9:20 AM
    Xrtherapy11
    If I remember correctly, it was between 2.5”-3”. The subwoofer has a lip all the way around, which allows it to sit on top of the carpet and foam this also provides an air gap of about 0.5”-0.75”. This keeps the sub from having any contact points with metal or any other hard surface that makes it a vibration-free install.
