Installed HD LEAF SPRINGS and 2.5'' Block , rides like a rock
Discussion in 'Suspension' started by KJACOBS1212, Jul 9, 2020.
  1. Jul 9, 2020 at 3:26 AM
    KJACOBS1212
    KJACOBS1212 [OP] New Member
    KB
    2011 TUNDRA SR5 DBL
    3'' SPACE LIFT FRONT / 2.5 BLOCK ON BACK / HD SPRINGS INSTALLED
    Had a broken leaf springs , so decided to install HD leaf springs so it does not happen again. we also installed a block in the back and 3'' space in the front to lift the truck a little. ever since I installed the new leaf springs it hits bumps like a ROCK sounds and feels like the back is going to fall off. Could this be fixed with some new shocks in the back. I understand its going to ride rough with the HD leaf springs but was not thinking this bad.
    2011 tundra sr5
  2. Jul 9, 2020 at 5:23 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I’m pretty sure all you can do at this point is remove the spacer and especially the HD springs. Toyota springs are known to be soft. If you make them stiffer your ride comfort is done..As for the rear shocks, you can try a hydraulic shock, but I doubt it will help with softening the rear end.
    KJACOBS1212[OP] likes this.
  3. Jul 9, 2020 at 6:01 AM
    SouthWestGA
    SouthWestGA New Member
    The first thing i would do is remove that block and see what it does
    zcarpenter92 likes this.
  4. Jul 9, 2020 at 6:24 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Spacers are the worse way to lift a vehicle.
    Take those out and get drop shackles like Coachbuilder. Then if you must, add smaller blocks to reach your height goal.
    I also hope you got new UCA'S in the front with your 3in lift or your alignment will suck, even though it may be "in spec" yours tires will get eaten up. Also drive shaft drop and front diff drop to avoid more troubles.
    In the end HD leafs are going to be stiff and ride rough, they are for heavy loads/towing,not empty cruising.
  5. Jul 9, 2020 at 6:38 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    For a livable heavy duty suspension you may want to check out Old Man Emu- will give you about 3 inches of lift and will drive much better. They are HD components, so are about 10% stiffer than stock- but totally doable. Great for hauling loads, towing, etc. I think you would be much happier. As mentioned earlier, approaching 3 inch lift in the front will require adjustable UCAs.
    Black Wolf likes this.
  6. Jul 9, 2020 at 6:46 AM
    BIGUGLY
    Paul
    2018 Limited
    If you lifted the back and did not replace the shocks they are probably shot. You have to match the shocks with the amount of lift. If they were stock there is no way they can handle working at that extended length.
    AccuTune Offroad likes this.
  7. Jul 9, 2020 at 7:22 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Add some weight in the back of the truck. Riding empty will be super rough. Heavy duty leafs are usually built to be under load. I also agree with the OME components. That will be my next upgrade as I usually have 500-1000 lbs in the bed at all times.
  8. Jul 9, 2020 at 7:24 AM
    Get rid of the entire spacer and block setup. They ride like crap.
  9. Jul 9, 2020 at 7:31 AM
    KJACOBS1212
    KB
    2011 TUNDRA SR5 DBL
    Thinking about having the local spring manufacture modify the springs I have or throw new ones on and eat the cost of the HD ones. I will also be looking for some new shocks for the Rear, looking at the Bilstein 5125 Series Rear Shocks for a 3''-5'' lift. I will definitely be looking into the front spacers . They were a bitch to do so I might hire them out this time. I currently have 35's on the truck. What kind of front lift do you all like running.
  10. Jul 9, 2020 at 7:50 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Before you spend money on the leafs, I'd look at the other things people mentioned. New rear shocks first, then front shocks without the spacer. If that doesn't work, try the shackles in the rear. Front spacers change the way it rides much more than rear blocks.
    I put HD leafs on mine and love they way the ride, stiffer, but not super stiff.
  11. Jul 9, 2020 at 8:10 AM
    KJACOBS1212
    KB
    2011 TUNDRA SR5 DBL
    I will try rear shocks first. The truck rides amazing its just the rear end when I hit bumps.
  12. Jul 9, 2020 at 9:25 AM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Shackles in the rear and you will feel like your rear end is cradled by the hand of God.
    Johnders2586 likes this.
  13. Jul 9, 2020 at 10:55 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Curious what HD spring are you using? How much more capacity do they have over stock?
  14. Jul 9, 2020 at 10:55 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Also what air pressure are you running? And did you just upgrade to the 35’s as these affect ride quality greatly, probably a 10 ply tire. I find 3-5psi difference in the tires can make the most difference.
  15. Jul 9, 2020 at 11:02 AM
    KJACOBS1212
    KB
    2011 TUNDRA SR5 DBL
    Huskey HD springs from RockAauto.Did not look to see how much more capacity they can take over stock. by looking at my old ones and the new leaf springs there was a extra leaf in the new ones. New tires just installed yesterday.
