Installed beat sonic front camera and harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by SiberianTundra, Dec 29, 2018.
  1. Dec 29, 2018 at 9:46 PM
    SiberianTundra
    SiberianTundra [OP] I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    jfits and Hatwsneezing like this.
  2. Dec 29, 2018 at 9:51 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
  3. Dec 30, 2018 at 3:25 AM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    YIKES!!! :eek2: What makes that camera worth $175?
    619Tundra likes this.
  4. Dec 30, 2018 at 4:33 AM
    SiberianTundra
    Greg
    War Machine
  5. Dec 30, 2018 at 6:12 AM
    Stig
    Stig New Member
    There weren't too many reviews on that Amazon camera but we're also only 2 reviews that mention any issues. One said the camera broke but didn't explain it and another didn't know how to remove the nut and broke it. I didn't see any reviews for that $175 camera though, but I'm sure it will work fine.
  6. Dec 30, 2018 at 7:00 AM
    womprat57
    womprat57 BABE the Big Blue Ox
    NH
    2014 SR5 DC 4x4
    So this will allow me to add to a base head unit?
  7. Dec 30, 2018 at 7:12 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
  8. Dec 30, 2018 at 7:52 AM
    SiberianTundra
    Greg
    War Machine
    True.
    I have warranty and you get what you pay for.
  9. Dec 30, 2018 at 8:04 AM
    SiberianTundra
    Greg
    War Machine
  10. Feb 26, 2019 at 12:56 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I just ordered my camera and beat-sonic kit today. My install might be slightly more difficult because I am planning on moving the parking sensor switch from next to the ignition key cylinder down to where the toyota glass break sensor is located. Moving the glass break sensor over to the USB/AUX pod and moving that into the center console. My only cause for concern is that the lead for the parking sensor switch will not be long enough to make it down to where the toyota glass break is. Has anyone opened this part of the truck up and seen how long the wire is that is connected to the backup sensor switch? I have a platinum and do not have free banks to put the new camera switch in. I also dont feel like having to reach in front of the shifter every time I park and want to activate the front camera. Much easier to reach around my keys and push a button there.
    SiberianTundra[OP] likes this.
  11. Feb 26, 2019 at 7:19 PM
    SiberianTundra
    Greg
    War Machine
    There is an auto ON mode when driving forward BTW. It detects when you are moving and turns on front camera. You can program it to do so. It is easy.
  12. Apr 19, 2019 at 9:35 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Just finished his project and it turns out that the wires leading to the parking sensor switch are not long enough to relocate below the A/C controls (without modification). Even if the wires were long enough I am not sure I would do it because each switch is designed to have a specific position in the dash and would require trimming plastic on the switch to make it fit. Ended up tucking the parking sensor switch inside the dash and secured it above the gas pedal. I left my parking sensors turned on as I’d have to reach above the pedal to turn them off. It’s great having my camera switch right next to my ignition though!
  13. Apr 20, 2019 at 8:56 AM
    SiberianTundra
    Greg
    War Machine
    i recently moved my switch near ignition as well. Love it there.
  14. Apr 20, 2019 at 10:02 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    What did you pay for Install?
  15. Apr 20, 2019 at 3:10 PM
    SiberianTundra
    Greg
    War Machine
    I paid too much for sure
  16. Apr 20, 2019 at 3:28 PM
    619Tundra
    Ok. Sounds like it.
  17. Feb 26, 2020 at 6:50 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    How has the unit held up so far?
    Also - I only have one open slot and that is where the GBS microphone would go.
    You say the wiring isnt long enough to reach to that location?
    Update:
    I sent them a question regarding the length of the wiring for the unit.
    Sam responded and said the wring absolutely will reach the center location below the AC controls.
    Maybe they re-worked their kit since you all installed them.
  18. Feb 27, 2020 at 5:31 AM
    Hatwsneezing
    Hatwsneezing New Member
    Another mod to add to the list!
  19. Feb 27, 2020 at 9:16 AM
    SiberianTundra
    Greg
    War Machine
    The length of wiring is not an issue.
    I have had this on my vehicle for over a year. Through car washes. Trips that were over 1000 miles. Elevation climbs of over 11000 ft.
    Same Camera is now on my new Dasaita stereo. I think it is not the best camera out there for resolution. But it holds up through rough stuff.
    If I had to do it again I would just get another camera that has better night vision.
  20. Feb 27, 2020 at 9:37 AM
    purplenova
    Tom
    Ohio
    I just ordered mine yesterday - so we're about to find out...lol
  21. Feb 27, 2020 at 9:52 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    The wire that beat sonic provides is long enough to reach anywhere in the dash area. The issue comes about with the factory wiring and when you don’t have any blanks to put the best sonic switch in (platinum and 1794 models) or if you want to put it next to your ignition and need to relocate a switch to another location.
    Sonicbluerider likes this.
  22. Feb 27, 2020 at 10:38 AM
    purplenova
    Tom
    Ohio
    Gotcha - mis-understood the previous comments about the wiring.
    Mater[QUOTED] likes this.
  23. Feb 27, 2020 at 11:25 AM
    SiberianTundra
    Greg
    War Machine
    You will like it. Easy to install. Running through firewall is the only hard part. But I use a firewall pierce tool with no issue.
  24. Feb 27, 2020 at 11:43 AM
    purplenova
    Tom
    Ohio
    Ive already swapped out the factory amp so should be able to run the wire through the same grommet...
  25. Mar 2, 2020 at 6:14 AM
    purplenova
    Tom
    Ohio
    Got the dang camera over the weekend, gotta love Chinese instructions.
    Hopefully when the CS6EP interface arrives they will have English instructions.
  26. Mar 2, 2020 at 8:03 AM
    Just wondering why you didn't go with the FRAC harness from @TundraTex . Can't beat his customer service.
  27. Mar 2, 2020 at 8:08 AM
    purplenova
    Tom
    Ohio
    Seems like a better fit for me and my mechanical abilities - I have an open blank for the on/off switch and did not want to drill holes to install two switches.
  28. Mar 2, 2020 at 8:08 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
  29. Mar 2, 2020 at 8:10 AM
    purplenova
    Tom
    Ohio
    May bite me in the butt - cause the instructions for the camera are in chinese and im not real good with electrical connections. If I cant figure it out, just sending it all back.
  30. Mar 2, 2020 at 8:13 AM
    @TundraTex harness is plug and play and you could have got switches to fit in the blanks.
    Hopefully it works out for you. :thumbsup:
    jclem65 and Black Wolf like this.
