Installed automatic nanny bypass!
Discussion in 'Performance and Tuning' started by Mountun Goat, Mar 7, 2020.
  1. Mar 7, 2020 at 5:38 PM
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Hey everyone. I just finished installing my auto nanny bypass harness from @MikeBeach
    The install was very simple.
    1. Remove lower dash piece off under the steering wheel.
    2. Remove the under dash fuse panel cover. There is an add-a-fuse to tie into the 15amp cigarette fuse. This requires leaving the panel cover off. I am storing my panel cover inside the under hood fuse box.
    3. Push the traction control button out of the slot and unplug the wire. This can be done by fishing your fingers up from the lower panel void.
    4. I cleaned a bit of sheathing off the yellow wire behind the trac button to ensure a positive contact. Then clip the add-a-wire onto the yellow wire. Plug the pigtail into the add-a-wire clip.
    5. Find yourself a proper ground point to tie the ground to. I used a dash frame bolt just above the fuse panel. (circled in the pic)
    6. Plug the add-a-fuse into the 15 amp cigarette fuse. FYI on my install I found the add-a-fuse orientation mattered. I didn’t have power until I flipped the add-a-fuse 180 degrees.
    7. Reinstall the dash piece.
    8. Fire your truck up and watch in amazement as your nannies turn themselves off for you :) :) :)
    Thanks again @MikeBeach for the harness! This thing is a game changer for me!
  2. Mar 7, 2020 at 5:58 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  3. Mar 8, 2020 at 5:39 PM
    MikeBeach
    MikeBeach New Member
    Houston TX
    '11 CM-DAP-SABM/AFE/5100s etc.
    https://youtu.be/sgpZlFDwNAY
    Let me know if anyones interested in one. Having nannies off all the time is an incredible driving experience.
  4. Mar 8, 2020 at 6:26 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    After driving with my truck today Im in love it! It’s in race car mode steady! :burnrubber::burnrubber::burnrubber:
    MikeBeach likes this.
  5. Mar 15, 2020 at 1:48 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This sounds amazing! Thanks for posting
    Mountun Goat[OP] likes this.
  6. Mar 15, 2020 at 2:06 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    It’s honestly the coolest upgrade for the price. Now that they bypassed steady it feels like a pretend locker almost. Never lags or stutters when I want it to roar.
  7. Mar 15, 2020 at 3:05 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wonder if the bullydog tune works the same with nannies off. I really want to buy this thing now
  8. Mar 15, 2020 at 6:40 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    If you can turn them off with a tuner then it will work. It’s exactly as a button only automatic.
    Hbjeff[QUOTED] likes this.
  9. Mar 15, 2020 at 7:38 PM
    MikeBeach
    Houston TX
    Seriously right? I never have to worry about the computer kicking in and cutting off power.
    Funny, I was in a hurry the other day and didn't wait before throwing it in to Drive and nannies didn't turn off... and of course I needed to get across traffic and gunned it and it fell flat on its face....argh! $%@%@%@.
  10. Mar 15, 2020 at 7:39 PM
    MikeBeach
    Houston TX
    It should work just fine with any aftermarket tuner. Let me know if you're interested in one.
  11. Mar 15, 2020 at 7:39 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha that happened to me once so far, so I can relate!
    MikeBeach[QUOTED] likes this.
  12. Mar 15, 2020 at 7:44 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yes it does. I have a different nanny bypass and had the BD tune last year with bypass and it all worked flawlessly.
  13. Mar 15, 2020 at 7:55 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    So everything is turned off every time you start the truck. Are you able to turn them back on by just pressing the dash button? Wet and ice, the traction control works well.
  14. Mar 15, 2020 at 7:57 PM
    MikeBeach
    Houston TX
    Correct, button works like normal. I live in Houston where it rains a lot, so I will turn it "on" often if its raining hard enough.
  15. Mar 15, 2020 at 8:14 PM
    TruckyTruck
    Gary
    Well, I gotta say, Mike, this is pretty cool and something a lot of folks have asked for over the years. My ECU is tuned by Orange Virus. Any idea if your module would conflict with my trucks programming? I can't see how it would, but thought I'd ask.
    @Mountun Goat Dan, your truck has all the goodies, huh!? Nice write up, bud.
  16. Mar 15, 2020 at 8:20 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
  17. Mar 15, 2020 at 8:26 PM
    MikeBeach
    Houston TX
    I'm tuned by DAP in person and I have no issues. The tune is what made me want nannies off every time the truck turned on.
  18. Mar 15, 2020 at 8:27 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha thanks :hattip:
    TruckyTruck[QUOTED] likes this.
  19. Mar 15, 2020 at 8:28 PM
    MikeBeach
    Houston TX
    I havent had the opportunity to try it on a 3rd gen. Someone makes one for a 3rd gen and told me it wouldnt work on my 2nd gen. Thats what made me go figure it out for 2nd gens.
  20. Mar 16, 2020 at 7:37 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Mountun Goat[OP] and chugs like this.
  21. Mar 16, 2020 at 10:03 AM
    MikeBeach
    Houston TX
    Sent you a PM.
    Please send PMs if you have any questions or pricing questions.
    Thanks
  22. Mar 17, 2020 at 2:02 PM
    MikeBeach
    Houston TX
    Sending 2 out, lysol'd and gloves used to pack and ship. Ill have 3 ready to go for next week, @Hbjeff has dibs on one of them.
    Btw: I'm just a hobbiest and each unit gets better and better. I test them in my truck before I ship to verify the timing is correct, they take about 2 hours to make. Im not trying to make a fortune, just extra tundra money.
    Thanks
    Mike Beach
  23. Mar 17, 2020 at 3:44 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nice clean work :hattip:
  24. Mar 18, 2020 at 1:37 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    This is most definitely on my 'list' :thumbsup:
    Rica25 and MikeBeach like this.
  25. Mar 18, 2020 at 6:29 AM
    coTony
    Tony
    Montrose, CO
    I have had this on my truck for about 18 months now and love it! I put a switch on it so I can control it, otherwise it comes on every time you start the truck. Not good if someone else drives it or you go to the dealer. Turn the switch off and no worries. My switch is illuminated so you can see if it is on but it is hidden up under the climate control panel
    Wynnded, MikeBeach and TX210Tundra like this.
  26. Mar 18, 2020 at 8:00 AM
    jbcrewmax
    jbcrewmax New Member
    SETX
    2019 TRD Pro
    How much you want for one? And I'm assuming I can throw a switch inline with the + or - lead so I can make it on-demand?
    Rica25 and Mountun Goat[OP] like this.
  27. Mar 18, 2020 at 8:59 AM
    MikeBeach
    Houston TX
    Correct you could add a switch. Judging by the profile picture you have a 3rd gen, as of right now I'm only making it for 2nd gens. There is someone who makes them for 3rd gens already. I test and install every unit it my truck to insure that the timing is correct, so to have a 3rd gen around to do that I doubt I'll get into the 3rd gen market.
    Thanks
  28. Mar 18, 2020 at 9:08 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  29. Mar 18, 2020 at 11:01 AM
    jbcrewmax
    SETX
    2019 TRD Pro
    Gotcha. Thanks for letting me know.
    Thanks for the link!
  30. Mar 18, 2020 at 3:48 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
