Installed AGM X2 Battery and SDHQ Battery Terminal
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodbucks, Aug 29, 2020.
  1. Aug 29, 2020 at 7:34 PM
    rodbucks
    rodbucks [OP] New Member
    jeff
    Campbell
    2019 Tundra Limited Cement
    Fox 2.5, Rago Front Skid, BD Pro Ditch Lights, Diamondback HD, TRD Exhaust, TRD Rear Sway
    DSC_1503.jpg Picked up and installed a 27F, X2 Power battery from Battery +, along with new Battery Terminals from SDHQ.
    Found a discount code for 20% off and a mail in rebate for $20 for the battery, still pricey.
  2. Aug 29, 2020 at 9:16 PM
    Caveman
    Caveman New Member
    Very nice, I've been contimplating this upgrade as well. I bought the connections but can't decide on a battery.
  3. Aug 29, 2020 at 11:12 PM
    Zero One Actual
    I have the exact same setup and love it.
    Wallygator likes this.
  4. Aug 30, 2020 at 12:30 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    if your looking for a battery that has a lot of amp hours for accessories an such. I recommend the XS Power Battery , for are Trucks they don't have the exact group number but it only varies by 1" in a lower height. if you use post's you will have to get the post adapter's. I bought mine because of my stereo plus all of my aftermarket electrical needs. at some point I will be removing the post's an going to a bus bar setup.
    16 blue crewmax likes this.
  5. Aug 30, 2020 at 5:10 AM
    Caveman
    Caveman New Member
    Are you guys changing your alternator to a higher output or any other mods to help charge this beast?
    chugs and HulkSmurf14 like this.
  6. Aug 30, 2020 at 6:06 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    You would need a voltage booster.
  7. Aug 30, 2020 at 6:20 AM
    Wallygator
  8. Aug 30, 2020 at 8:38 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    This is what you have to do to maintain an AGM on an 18+ truck. The voltage to the battery is regulated by the ECU. It no longer is done by the ALT fuse like previous models. Only way to increase voltage is to change duty cycle in the ecu, which tuners haven’t cracked yet for 19+.
    This is why I ultimately went with a wet cell with a good warranty. Having to constantly monitor an agm wasn’t worth it to me.
    el_conquistador, chugs and rockmup like this.
  9. Aug 30, 2020 at 8:50 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Same here.
    My X2 Power experience was nothing but a PITA..
    Danman34[QUOTED] likes this.
  10. Aug 30, 2020 at 10:05 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Why? I feel people go overboard trying to maintain an actual maintenance free battery. I know people feel they need to boost the alt. output by ~.5V but I haven't heard of any actual bad experiences using the X2 Power (or it's equivalent) battery so I'm interested to hear your issues.
    Y0TA PR0 and HulkSmurf14 like this.
  11. Aug 30, 2020 at 11:29 AM
    NueveTundra
    Planet Earth
    I put in a LActrical High Output 300amp Alternator into mine. I found i was using all the power that it the stock one was making while driving and not getting a good charge. So i went to this one , haven't had any issues.
    Dont forget if you upgrade your alt you need to upgrade your wiring.
  12. Aug 30, 2020 at 11:36 AM
    Danman34
    Danman34 New Member
    Danny
    Amperage is not what determines if the battery gets charged or not, voltage does. You can put a 500 amp alternator in but if you’re not supplying the proper charge voltage an agm requires you’re wasting your time and money.
    shellshock likes this.
  13. Aug 30, 2020 at 11:49 AM
    NueveTundra
    Planet Earth
    14.4V X Amps = Watts is the calculation.... if your watt demand is greater than half of the number by the stock alt output your not going to get charge 1 bit while running and using all your needed watts. Your alt will not charge your battery and your battery will lose charge.
  14. Aug 30, 2020 at 11:51 AM
    Danman34
    Danman34 New Member
    Danny
    We’re talking about proper charge for an AGM battery. Nobody is talking about watts nor is it relevant to charging an AGM battery.
  15. Aug 30, 2020 at 11:55 AM
    NueveTundra
    Planet Earth
    That doesn't even make sense , it sounds like you wrote the same thing twice.... someone a couple lines up posted a question i was responding to. Then you jumped on me.... i'll just take my 12V self out of here.
  16. Aug 30, 2020 at 11:59 AM
    Danman34
    Danman34 New Member
    Danny
    It makes absolute sense. I was informing all that a higher amperage alternator won’t make a bit of difference if the running voltage is not correct for an AGM battery. These trucks are not designed to charge an AGM. So if you’re going to run an AGM, you have to modify the voltage regulation, which is not done simply by changing the alternator.
    Wallygator and gabex35 like this.
  17. Aug 30, 2020 at 2:52 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Because it died on me twice within the first 6 months of purchasing it.
    First time I was 3 months in.
    Got it to start the truck, voltage was 10.8, truck wouldn't start.
    Batteries Plus gave me a loaner battery, tested the battery said it was fine.
    Told me if it happened again they would replace it.
    They kept the battery for 3 days charging and testing.
    Toyota said my charging system was fine when I had it in for an oil change that week.
    I bought the HKB booster and an AGM charger/maintainer after reading the AGM batteries like a higher output than the 13.4 volts the stock alt was putting out.
    HKB brought it up to 14 volts, still have it in the truck.
    3 months later it died again and that was with me hooking it up to a charger/maintainer once a month.
    I called Batteries Plus and reminded them they told he if I had any more problems they said they would replace the battery.
    Manager told me he would still have to test it and that they had no loaners.
    Remember they kept the battery for 3 days last time they charged and tested it.
    I reminded him one more time that he said he would replace the battery, he refused.
    I can't go 3 days without my truck.
    So, I drove over to Interstate battery and bought a MTP-27F.
    Used my 6 month old $219 Batteries Plus X2 Power AGM battery as a $20 core charge trade in.
    Even if Batteries Plus charged and tested it, I don't want the same battery back.
    I charged it myself at the 1st of every month when it started lagging on the start..
    I couldn't sell it in good conscience knowing that there is something wrong with it.
    Maybe I got a lemon, I don't know.
    What I do know was I was tired of having to check my voltage meter EVERY TIME I got in and out of the truck.
    To top off my sad story, I never got my rebate check from Batteries Plus from the initial purchase.
    So fu(k Batteries Plus and AGM batteries..
    So before you ask anymore questions;
    NO, the truck does sit for periods of time, it is my daily driver.
    NO, I never had a battery issue before the AGM with my first or 2nd battery for this truck, AGM was the 3rd.
    NO, my truck doesn't have a huge parasitic draw that would drain the battery, never had an issue until I bought the AGM.
    NO, I haven't had anymore problems since telling the Batteries Plus manager to GFYS, and trading his battery in for a $20 core charge for the Interstate.
    The new Interstate has been great, I should have kept the one I had, but I got caught up in the AGM hype.
    Just checked it, 12.8 volts haven't started it since yesterday.
    A quick start bumps it up to 13.7.
    g6attzkp_f4e24b5246639afb8dc2d3cd986bc20e623081a0.jpgzc946iwl_f5659020937fe97805e269d0651d5e62d5e106d4.jpg
    SO, my X2 Power experience was nothing but a PITA..:thumbsup:
  18. Aug 30, 2020 at 3:09 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Taco guys use a $10 Ford fuse/diode. Bumps charging up to 14.4-14.6 volts.
  19. Aug 30, 2020 at 3:09 PM
    The Patriot 1776
    '16 TSS CM 4x4
    What was the 20% discount code? Thanks.
  20. Aug 30, 2020 at 3:20 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Hm interesting. I thought it was still ALT-S since that fuse is still there
    Is there a thread somewhere that talks about the 18/19 tundras? This is the first I’ve heard of it being in the ecu.
    on the 16+ Tacoma, that fuse doesn’t exist any more. I’ve modified the charging voltage in my Tacoma using the vF tuner software. If it’s actually in the ecu, that would be cool. It was easy to tweak on my Tacoma.
  21. Aug 30, 2020 at 3:53 PM
    Danman34
    Danman34 New Member
    Danny
    Yes I know. But 18+ Tundras and I believe even the Tacoma’s are regulated through the ECU now.
  22. Aug 30, 2020 at 3:54 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I did not know that. Thanks.
  23. Aug 31, 2020 at 4:15 AM
    rodbucks
    jeff
    Campbell
    Discount code was..AUTO20...not sure how long it last though.
  24. Aug 31, 2020 at 5:53 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Just to be clear.
    A 2010 with an AGM battery and a voltage booster should work?
    Problems only seem to be with 2018 and newer?
    Is this correct?
    chugs likes this.
  25. Oct 24, 2020 at 3:04 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Your AGM only cost $219 Wow They are $349 minus 10%
    NewImprovedRon and HulkSmurf14 like this.
  26. Oct 24, 2020 at 7:53 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I went back and looked at the purchase.
    I don't where I got $219.
    The base price for the 24F X2 I bought was $309.
    I think it was 20% off and then another 10% off to order online.
    Even though the math doesn't seem to add up to be exact.
    https://www.batteriesplus.com/productdetails/sli24fagmdp
    Subtotal: $250.99
    Fees: $3.00
    Shipping: $0.00
    Tax: $20.46
    Total: $271.45
    I also had an online rebate for $25 or $30.
    I never did receive the rebate check.
    That would have brought it closer to $242 if I would have gotten the rebate.
    But I'll tell you this, I'll never buy anything from Batteries Plus again..
    Totmacher likes this.
  27. Oct 24, 2020 at 7:59 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I just had to replace my x2 group 27f marine, in our 4Runner. I would occasionally put it on a tender. It gave us nothing but raw power whenever we needed it!!!! It lasted over 4 years in one of the hottest climates in Arizona, very short drives, all stop and go traffic.
    I will be more diligent about putting it on the tender now, hopefully get 5 full years out of the new one!
  28. Oct 24, 2020 at 8:23 AM
    Tundrafan23
    Tundrafan23 New Member
    Why am I seeing a .5 volt increase after adding a HKB booster fuse on my 2020 then?
    WillTunBlack20 and cavalry bear like this.
  29. Nov 15, 2020 at 4:37 AM
    ZPMAN
    Minnesota
    If you don't mind me asking, do you have an aftermarket head unit?
  30. Nov 15, 2020 at 11:18 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Yes, but that has nothing to do with my AGM issues..
