Installed a rci skid plate today worth it
Discussion in '3rd Gen Tundras (2022+)' started by Duke_962, Nov 5, 2022.
  1. Nov 5, 2022 at 4:23 PM
    Duke_962
    Duke_962 [OP] New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    [​IMG] [​IMG] [​IMG] [​IMG] Installed a rci Offroad skid plate for the engine today to replace my fiber/carpet one (non Offroad package truck) worth it and great quality. No issues with ice chunks or road debris now. Will be ordering trans plate soon.
  2. Nov 5, 2022 at 5:11 PM
    Duke_962
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Well worth it and search for a coupon code. I found one that saved me a bunch on shipping. I have made my own in the past but just wanted a bolt on one and this is very well made for the price. I looked at about 4 company’s and this wasn’t the cheapest but I’m happy with the purchase.
    Acedude and Eurodriver like this.
  3. Nov 5, 2022 at 7:34 PM
    Tundra_Lover7
    Tundra_Lover7 New Member
    2024 Platinum CrewMax TRD offroad
    3 inch TRD lift, TRD Skid plate, RCI Trans/Cat converter skid plate, RCI Bed Rack, Nitto Recon Grapplers, OEM bed mat, BAK Revolver X4S Tonneau, OEM Mudguards, OEM Black Chrome exhaust tip, TRD pro flairs, TRD pro grill, Baja designs light bar, Rigid ditch lights
    Did the installation of the skid plate require you to leave off the front sway bar? I noticed it was missing in your picture. I have the TRD skid plate that came with my truck but I like the fact the RCI one has a door so you can change the oil with dropping the skid plate.
    Tom976 and Acedude like this.
  4. Nov 5, 2022 at 8:07 PM
    Duke_962
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    No the sway bar is in the last photo. Only thing you have to remove is the factory carpet. And deploy the front air dam prior to install. Turn the truck off and hold the mist setting for the wipers for 2 seconds. Took all of 20 mins to put on the truck.
    Acedude and RookieEP like this.
  5. Nov 5, 2022 at 8:39 PM
    Tundra_Lover7
    I see it now thanks!
  6. Nov 6, 2022 at 2:42 PM
    Scruffy_Nerf
    Scruffy_Nerf New Member
    2022 Toyota Tundra SR5
    I’m trying to decide between the RCI and TRD skid plate. As far as I can see, the main reason to pick the RCI option is the oil change door. Can anyone confirm that the oil change door in the RCI plates works well?
  7. Nov 6, 2022 at 3:33 PM
    Duke_962
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Yes. It lines up. As for between the two. Rci much heavier duty.
    BravoDeltaRomeo and Scruffy_Nerf like this.
  8. Nov 6, 2022 at 3:36 PM
    Scruffy_Nerf
    Thanks! I’m glad it’s working well for you.
  9. Nov 6, 2022 at 3:45 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    FYI @RCIoffroad is doing their Black Friday sale right now
    :spending:
  10. Nov 6, 2022 at 4:33 PM
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    Just asking, but I thought the TRD pro skid plate came with the door for oil filter access?? I know the cheap, crappy, tin skid plate doesn't (but its garbage anyways)
  11. Nov 6, 2022 at 5:08 PM
    Scruffy_Nerf
    As far as I know, it does not have a door. @2020Platinum made a video on changing the oil and had to take off the skid plate to do it. https://youtu.be/zvJ-EKWoVII
    It looks fairly simple to remove.
    2020Platinum likes this.
  12. Nov 6, 2022 at 5:34 PM
    Ragnarkov
    Stephen
    Nothing.... yet.
    This would be a case of 'me being a dumbass who can't read good'. I forgot it was a 2022+ thread. doh! :crazy:
    This stupid they changed the 2022 trd skidplate to not include one...
  13. Nov 6, 2022 at 7:32 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I still can’t believe this is a thing. Seems like it would just get wet and stay that way and cause rust issues.
    Not to mention not actually protecting anything…
  14. Nov 7, 2022 at 4:02 AM
    Duke_962
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    I would think it could stop a mosquito or possibly small fly at best.
  15. Nov 15, 2022 at 7:16 PM
    Scruffy_Nerf
    I ended up going with the TRD plate. I found an open box one for $225 plus tax. At that price, I’ll deal with annoying oil changes. Otherwise, RCI seems like the way to go.
    Tundrastruck91 and Durtywrench like this.
  16. Nov 15, 2022 at 7:18 PM
    Duke_962
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    a deal is a deal. Question how thick is the factory one? I have seen them on trucks but never check how thick they were.
  17. Nov 15, 2022 at 7:20 PM
    Scruffy_Nerf
    I’ll get my calipers out and check when I get home but I believe it’s 1/4” aluminum.
  18. Nov 16, 2022 at 7:34 PM
    Scruffy_Nerf
    1/4” aluminum confirmed.40EE492A-333C-47D6-AB63-37E26494B012.jpg
  19. Nov 17, 2022 at 6:11 AM
    Duke_962
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Not a bad deal for that thickness.
  20. Nov 17, 2022 at 7:19 AM
    Duke_962
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    You shouldn’t If it’s factory but even with the carpet one I took off. You have to take it off to get to the filter.
  21. Nov 18, 2022 at 9:52 AM
    Scruffy_Nerf
    I don't see why any of the Toyota OEM skid plates would cause a problem. It's possible that some of the aftermarket plates would be an issue simply because the service team doesn't want to deal with uninstalling and installing them back on the truck. Even if they did that for you, I wouldn't be surprised if they charged for the labor of that process. If you are worried, you could always remove the skid plate before bringing it in.
    Eurodriver[QUOTED] likes this.
  22. Nov 18, 2022 at 10:10 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Can someone tell me if the TRD skid plate covers the engine and transmission? Trying to compare which RCI plate would be equivalent.
  23. Nov 18, 2022 at 1:38 PM
    Scruffy_Nerf
    I'm installing it over the weekend and will post a photo. I probably won't post it here since it's off topic to this thread but keep an eye on the other 3rd gen. threads.
    Dfrink[QUOTED] likes this.
  24. Nov 18, 2022 at 8:28 PM
    Duke_962
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Post it here. It’s all skid plate related. There are a few nice ones on the market. Let’s see what everyone goes with and the pros and cons on each one. I have to say the Trd and Rci one are very close in protection. But without seeing installed photos it’s hard to tell the subtle differences.
    Dfrink likes this.
  25. Nov 19, 2022 at 2:18 PM
    Scruffy_Nerf
    Super easy install. 10-15 minutes tops. Had to buy (2x) M8 x 1.25 bolts for the rear mounting points. The plate covers the engine but not the transmission. However, I’m installing a cat shield next which will cover the transmission. It also doesn’t interfere with with air dam which is nice.
    Yaboy, Dfrink and Duke_962[OP] like this.
  26. Nov 19, 2022 at 3:24 PM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Where did you find this open box?
  27. Nov 19, 2022 at 3:33 PM
    Scruffy_Nerf
    BAM wholesale parts. I almost gave up after looking through online classifieds for awhile.
  28. Nov 19, 2022 at 3:36 PM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Cool, thanks!
  29. Jan 11, 2023 at 12:08 PM
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    How long does it take for RCI to deliver after an order? I’m approaching 60 days since my order. I’ve tried to contact them by email and phone with no luck except for an email response more than a month ago.
    Tom
  30. Jan 11, 2023 at 3:21 PM
    tbrady
    tbrady New Member
    Southern Idaho
    An hour after my post, I got an email with a Fedex tracking number. Go figure.
    Eurodriver, Dfrink and AND like this.
