Installed a K&N cold air intake today
Discussion in 'Performance and Tuning' started by Wheelertrd, Apr 13, 2016.
  1. Apr 13, 2016 at 9:14 AM
    Wheelertrd
    Wheelertrd [OP] New Member
    Bobby
    2007 tundra trd 5.7
    Level kit cold air intake
    Install a k&n cold air today
  2. Apr 19, 2016 at 9:01 PM
    Tundra212x
    Tundra212x New Member
    Rick
    2012 Tundra TRD
    I just purchased a 2012 Tundra and it has the same K&N air intake installed. Wheelertrd, after you installed your intake, did it amplify/increase the sound that your exhaust makes? My Tundra is very loud, to the point that anytime I accelerate it makes a lot of noise. I think I've narrowed it down to the exhaust, but if it's the intake causing it, I'll look to replace it with the stock air intake. Thanks...
  3. Apr 22, 2016 at 10:18 AM
    SNOWBIRD
    SNOWBIRD New Member
    rodney
    2013 trd limited
    IF YOU WANT TO REPLACE THAT K&N SYSTEM WITH THE FACTORY ONE LET ME KNOW... the intake does make a lot of noise!
  4. Apr 22, 2016 at 2:45 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    I have contemplated installing one of these on my 2004 Tundra but wondered whether or not it would actually benefit my truck any. They are not cheap and question whether they provide any additional horsepower or fuel efficiency. I am adding a performance muffler this coming Monday to add some wanted sound to it but don't want it too loud if that is something that this will do.
  5. May 18, 2016 at 1:08 PM
    Dustin808
    Dustin808 New Member
    Dustin
    2008 Midnight blue Tundra Limited
    3" leveling kit 20" MOTO METAL wheels (MO961's) 305/55/20 (33") NITTO TRAIL GRAPPLERS True dual exhaust(custom built) Fabtech BullBar W/LED lights Custom Black Housing headlamps Custom LED tail lamps (Smoked) Fabtech Blacked out grill (Goes over existing grill not a replacement) PIONEER Head unit ( GPS,NAV,IPOD,Bluetooth,DVD,MP3,CD, etc...etc...) Tundra shadow light replacement for the standard door light. HID conversion on low beam side custom drilled and used LED button lights (amber) for the Bull BAR and used as a DRL (X4) 3" Recessed LED back up lamps custom fit into the rear bumper.
    Food for thought the intakes for this truck does no benefit or any bolt on for that matter unless you you change the parameters which can be done with a piggy back but make sure your warranty is up because it will leave a foot print.
    15whtrd and Ancient1 like this.
  6. May 18, 2016 at 5:02 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    The reason none of the companies that are making CAIs for these trucks won't post dyno results to back up their claims of increased HP, is because they don't. In fact some guys complain that they may have lost some HP. There is a lot of good info on some other tundra forums about CAIs. I would suggest reading that info before wasting money on a CAI.
    Black Wolf likes this.
  7. May 19, 2016 at 10:40 AM
    15whtrd
    15whtrd Mr. Blonde
    And if you look at it the K&N looks more like a hot air intake. I had one on a few previous vehicles. If you notice your stock airbox sucks in cold air from the fender. The K&N poorly seals to the hood allowing hot air from the engine compartment to enter the intake. HAI
    Dustin808 likes this.
  8. May 19, 2016 at 10:47 AM
    That K&N "cold air" intake and others similar to it are nothing more than hot air intakes. By the way S&B does post their dyno data. Best air filtration period. S&B is very clear that "any" HP gains would occur at higher RPMs. With S&B it's not about HP with them. It's all about filtration. S&B filter specs blow away the competion by far. If I was ever to contemplate on replacing my factory CAI, (which is unlikely??) it would be for the S&B, otherwise you are wasting your money.IMHO
    15whtrd[QUOTED] likes this.
  9. May 19, 2016 at 12:08 PM
    TheBeast The Beach
  10. May 19, 2016 at 4:03 PM
    AMRE2ME2
    AMRE2ME2 New Member
    There are no Dyno charts posted for a tundra on any of these links. And they never will because it would show that their product doesn't do anything for a tundra. Do you realize that your tundra already has a CAI right from the factory?
  11. May 19, 2016 at 5:02 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    So matluth are you running an S&B?
    If so let's hear about it and see pics...
  12. May 19, 2016 at 5:13 PM
    15whtrd
    15whtrd Mr. Blonde
    No he's not, but he said if he did it would be an S&B
  13. May 19, 2016 at 5:18 PM
    dandailey
    Dan D
    Newport News Va.
    Oh , maybe if I read posts more thoroughly,lol
    15whtrd and rons23 like this.
  14. May 19, 2016 at 7:56 PM
    Re read my post. LOL
  15. May 19, 2016 at 8:08 PM
    Simple pics will convince you?? That's what Playboy used to be for. A little reading and research doesn't hurt. Helps make your case better. just sayin. Re-read post. I thought my post was pretty clear. Apparently not. (I'm just being overly sarcastic, don't take offense).
  16. May 19, 2016 at 8:11 PM
    The only reason I would upgrade to a S&B is for FILTRATION!!! S&B makes filtration products for the military in very "challenging" environments. Do your home work. I'm busy enough helping with my grand kids homework. Please re-read my post. Anyone who buys an aftermarket "CAI" for HP gains is foolish. Unless you drive at 5000 RPM's all the time. Get real. IMHO.
    Oh...I forgot some of the aftermarket CAIs sound cool...................Also there is is lot of non junk science info "out there" explaining why a wet filter (as in my current drop in K&N) is superior to a dry filter.
  17. May 19, 2016 at 8:47 PM
    DITTO^^^^^
  18. May 19, 2016 at 9:08 PM
    dandailey
    Dan D
    Newport News Va.
    you didn't understand my last post. Thank you.
  19. May 19, 2016 at 9:22 PM
    I hear you. My sarcastic comments sometimes don't go over too well. I forget how many times I've had to go back and re-read a post. A couple of guys here have bought the S&B. Maybe they can chime in. What's cool is the S&B is cheaper. A lot cheaper by $150 to $200 cheaper than many of the CAI brands mentioned here and it provides the best filtration. Not sure how the S&B sounds. Check out S&B's site. They show their filtration results against pretty much all the competition. I don't even think they bother with dyno tests. Just filtration comparisons. They even have pics of their test lab which no one else does. That's why I would most likely buy their product.
  20. May 30, 2016 at 2:56 PM
    Kently
    Kently New Member
    Kent
    2013 TRD Crew Max
    Did you notice any difference in performance or fuel mileage? If so, what were the most profound or perhaps disappointments?
