Installed 2" spacers on stock 20x9rims w 35s
Discussion in 'Wheels & Tires' started by racin, Jul 6, 2018.
  1. Jul 6, 2018 at 3:33 PM
    racin
    racin [OP] zmr
    Tampa, FL
    2015 Met.Gray 4x4
    Installed 2" wheel spacers with 35x12.5x20 tires on 20x9 tss stock wheels 3/1 lift...zero rub :) 20180706_135831.jpg 20180706_135842_HDR.jpg 20180706_135858_HDR.jpg
  2. Jul 6, 2018 at 4:14 PM
    Noice!
    racin[OP] likes this.
  3. Mar 26, 2019 at 6:47 PM
    racin
    racin [OP] zmr
    Tampa, FL
    2015 Met.Gray 4x4
    **If you need zero rub..mud/splash guard must be removed(all plastics in the way)..also VERY IMPORTANT..when purchasing tires especially M/Ts 35s DO NOT buy the ones that ultimately wider right to the edge of the tire...the perfect example of tire style/design to purchase is ATLAS M/T tires..I included a picture..look at the edge on the tire..see the way its angled in...that 1"/2" little difference makes the difference no rub on BODY MOUNTAtlasMT.jpg
    Mnorris1206 likes this.
  4. Mar 26, 2019 at 6:54 PM
    Mnorris1206
    08 tundra
    Man if I knew all this 2 yrs ago my truck wouldn't be on a 6" lift well maybe. I do like my tuck lifted. But your truck looks really nice good work
  5. Mar 26, 2019 at 7:09 PM
    Mnorris1206
    08 tundra
    Hey did you know they make clear lenses for the tow mirrors ?
  6. Mar 26, 2019 at 7:11 PM
    racin
    racin [OP] zmr
    Tampa, FL
    2015 Met.Gray 4x4
    nice thanks
  7. Mar 31, 2019 at 4:14 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Those tires look like they will hum a tune on the highway,
  8. Mar 31, 2019 at 6:06 AM
    racin
    racin [OP] zmr
    Tampa, FL
    2015 Met.Gray 4x4
    To be honest...they are very quiet
    Mnorris1206 and XXtorNATEoXX like this.
  9. Feb 5, 2020 at 2:28 PM
    B-rock
    B-rock New Member
    Brandon
    2017 Toyota Tundra SR5
    What offset do you have on your wheels?
  10. Feb 5, 2020 at 3:34 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I believe tss wheels are +50mm offset, and 2" spacers are 50.8mm, so he should be at -.8mm offset
  11. Feb 6, 2020 at 11:31 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I have the same Vision wheels and they are +18
  12. Feb 6, 2020 at 12:22 PM
    Berdine
    Binghamton, NY
    So, if they're +18 and the 2" spacers are 50.8mm, then his offset is -32.8
