Install New Grill with sensor
Discussion in '2.5 Gen Tundras (2014-2021)' started by Delrio666, Aug 3, 2021.
  1. Aug 3, 2021 at 6:35 AM
    Delrio666
    Delrio666 [OP] New Member
    2020 Tundra 4x4 Crew Cab SR5
    Rear bumper, Whiteout mirrors and hood bulge
    Where would I find a local place at a reasonable price in San Antonio area to install a replacement grill on my 2020 SR5 CrewMax Tundra. Getting rid of the chrome. I have the replacement grill. Would do myself but don’t want to mess up the sensor placement.
  2. Aug 3, 2021 at 6:45 AM
    Welcome from NY.
    You can do it yourself, very easy to do. You cannot mess up the sensor.
    Unplug the wire, pull the grille off, attach new sensor, put new grille on then reconnect the the plug.
    You can do this!
    Gravy and Delrio666[OP] like this.
  3. Aug 3, 2021 at 9:09 AM
    Delrio666
    Ok. I’ll give it a shot. Thanks :fingerscrossed:
    Jim LE 1301 likes this.
  4. Aug 3, 2021 at 9:13 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    It is very easy, just take your time. Also, set up a blanket in your bed as a work area for swapping the sensor.
    Delrio666[OP] likes this.
  5. Aug 3, 2021 at 12:47 PM
    Delrio666
    Thanks for the advise. Will do
  6. Aug 3, 2021 at 1:09 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    So the issue is in breaking the plastic pins for the press washer when removing the sensor from the old grill. Take a screw driver and bump the press washer from the edge. This will slightly bend it allowing you to slide it off. Use a hammer to flatten it back out for reapplication on the new grill.
  7. Aug 3, 2021 at 1:13 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Or if he doesn't care about the old grille he can just cut the tab on the old grille for easy take off.
  8. Aug 3, 2021 at 1:25 PM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    If you’re replacing just the grill and not the surround too, it can be a bit tedious. Just take your time with the clips, once you have it done you’ll probably feel a bit silly that you almost paid someone to do the same thing. Lots of YouTube videos to help out too.
    Good Luck!
  9. Aug 3, 2021 at 2:22 PM
    :thumbsup:
    You got this.
