Install Instructions - Gen3 OEM Exhaust Tip 00012-T1634-02
Discussion in 'Performance and Tuning' started by 17LimitedTRD, Jun 26, 2017.
  1. Jun 26, 2017 at 11:25 AM
    17LimitedTRD
    17LimitedTRD [OP] New Member
    2017 Quicksand Limited TRD
    Can't find the instructions anywhere. Toyota Parts stated they were in the box, but not included in mine. Any help here would be greatly appreciated. Stock exhaust 2017 Tundra 5.7L
  2. Jun 26, 2017 at 11:40 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    T-Rex266 likes this.
  3. Jun 26, 2017 at 11:49 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Should come with some inserts to be between the tip and your tail pipe. Once in place tighten down on set screw.
  4. Jun 26, 2017 at 12:36 PM
    17LimitedTRD
    Just the Exhaust Tip on stock tailpipe...See below, not sure how this is all supposed to be attached properly.IMG_3063.jpg
  5. Jun 26, 2017 at 12:46 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  6. Jun 26, 2017 at 12:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If it's anything like mine, I to cut off the end of the pipe where it flanges out.
  7. Jun 26, 2017 at 1:02 PM
    17LimitedTRD
    Actually got it to go on now...Needed a bit of assistance with a rubber mallet to get the shims to go in. Good to go! Thanks everyone!! Pics to follow...
    Bear likes this.
  8. Jun 26, 2017 at 4:53 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    It can be confusing on the living room floor. But as you've seen, once you get it on the truck it's pretty self explanatory. That's the Toyota conundrum. Best to go with it tho. Their oddball pipe size is the perfect size for our trucks;)
