Install help 2014 Tow mirrors !
Discussion in 'Towing & Hauling' started by MillsTRD14, Mar 7, 2016.
  1. Mar 7, 2016 at 8:23 AM
    MillsTRD14
    MillsTRD14 [OP] New Member
    Aaron
    2014 Tundra TRD
    Ba mufflers 7 inch, Bilstein 5100 TRD strut bar, Firestone adjustable ride rite airbags, tow mirrors , BFGoodrich ta ko2 33s, TRD shift knob, blacked out emblems, tundra Pro grill......
    Well I just got in my tundra tow mirrors and needing some help on the install . I got tired of pulling my TT without them . They are factory Tundra Tow mirrors off of a 2008 tundra , and help on a link etc would be great ..Thanks !!!
  2. Mar 7, 2016 at 9:49 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
  3. Mar 7, 2016 at 11:16 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Remove sail panel, remove door panel(held by a few screws, and clips around the edges), unplug factory mirror wiring, remove factory mirror via 3 bolts, reverse process and then do the other side. Done.
    Newguy84 likes this.
  4. Mar 7, 2016 at 11:30 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Intallation is fairly simple (even for non-expert like me).
    First pop off the plastic panel behind the level that opens your door. Remove small liner in little cubbyhole (what you use to close your door). Behind each of these, you will find a screw. Remove these screws.
    Then loosen the plastic holder toward the front of the door. This should pop up as shown.
    Then pull out the door panel. You could just prop the door on something (I used a lawn chair). That way you do not have disconnect wiring inside the door panel.
    Once you open the door panel, the small triangular panel can pop out. Behind this panel, you will find three screws. They hold mirrors in place. Unscrew these (be careful not to drop them inside your door). Disconnect the connector.
    Pop out the mirror and put your two mirror in. Tighten the screw. Connect the plastic connector. Basically reverse the steps.
  5. Mar 7, 2016 at 11:41 AM
    chphilo
    Western PA
    I realized that door panel was hiding the last screw in my picture (I think this was because I did not take the door panel completely off). Here's a someone else's better picture of these screws.
    MillsTRD14[OP] likes this.
  6. Mar 8, 2016 at 4:27 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Thanks !!
  7. Mar 18, 2016 at 5:56 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Toyota factory tow mirrors installed $220 a set , anyone wanna Know where I got them ?
  8. Mar 18, 2016 at 9:08 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    This may cause a feeding frenzy lol, plug and play , heaters work and mirror motors work great . There "used" but there mirrors so not gonna be any wear really .
  9. Mar 18, 2016 at 11:39 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Lol , just checking to see if y'all where paying attention . LKQ is where I got them , just give them a ring and they will find you a pair , great people to deal with and super fast . Fyi first set came in and one was scratched that I didn't like so they overnighted another. Plug and play factory tow mirrors , no shaking at highway speeds etc , everything works heat, power adjustability .
    http://www.lkqcorp.com/en-us/
    And then the frenzy begins ....., let me know who all gets some ;)
  10. Mar 18, 2016 at 11:39 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
  11. Mar 18, 2016 at 11:40 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    I need a set of Tundra pro headlights , anyone got a set ?
  12. Mar 18, 2016 at 11:45 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    Has anyone ever tried taking apart the headlights and blacking them out themselves ?????
  13. Mar 18, 2016 at 7:22 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have opened my OEM 2014 lights when I retrofitted them, it was a pain. These lights are sealed with permaseal. I would just buy a set of TRD Pro Lights from @Roman and sell your stock lights, well worth it.
    Roman likes this.
  14. Mar 19, 2016 at 5:07 AM
    chphilo
    Western PA
    Correct me if I am wrong, but what they sell doesn't seem to be OEM Toyota tow mirrors. There have been after-market tow mirrors for years (at half the price).
  15. Mar 19, 2016 at 6:16 AM
    MillsTRD14
    Aaron
    2014 Tundra TRD
    You can order there aftermarket models or you can order factory take offs . Basically they put in the part your looking for and then in my case they turned the computer screen around and you can actually see the truck there coming off of, there all wrecked trucks . Mine came off of a 2009 Tundra that was completely smashed in the back . They will try and sell you there aftermarket stuff but I told them I wanted used factory stuff , I have a branch in my home town. It's pretty neat what they do and there operation .
  16. Mar 20, 2016 at 4:59 AM
    chphilo
    Western PA
    That makes more sense. That's a viable option.
