Install from hell....
Discussion in '2.5 Gen Tundras (2014-2021)' started by throughitalldude, Oct 12, 2019.
  1. Oct 12, 2019 at 5:48 PM
    throughitalldude
    throughitalldude [OP] New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    So I ran into way more hiccups then I’d like for a standard install and tire swap. Stripped the tie rod stud on the passenger side. I had to stop the install run to harbor freight to buy a tap and die kit just to spend 2-3 hours retapping it to only run into another issue. Going to mount the spindle when I realized I was given fine thread nuts with corse thread bolts for the spindle to mount to the LCA. Ran to 4 different Home Depot’s to get correct nuts. Got home at 10pm to then finish the front at 1:30am. This morning went to get new tires put on and because of the -12 offset on my wheels plus the spindles kicking the rims out more 35s would rub wayyyy too much didn’t even fit when turning. Tire shop had a set of Toyo AT2 275-65-20 (34s) I thought they would look small but actually loved how they turned out. So after a lot of heart ache sweat and A million errors! Here she is. Tires are definitely more reactive then my old 35s and love that. Just have a bit of trimming to do on the front plastic and push the plastic forward. In all 3.5” lift in the front and 1” in the rear.
    TheBeast, Ostrich, TTund16 and 16 others like this.
  2. Oct 12, 2019 at 5:55 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Looks great!
  3. Oct 12, 2019 at 5:55 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Lookin good!! I’m happy for you all turned out well!!
    Blueknights75 likes this.
  4. Oct 12, 2019 at 5:58 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Thank you guys here’s a couple more!
    Ostrich, TTund16, Darkness and 9 others like this.
  5. Oct 12, 2019 at 6:03 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Looking Good !!!
  6. Oct 12, 2019 at 6:36 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Thanks everyone here’s the before and after
    Ted4311 likes this.
  7. Oct 12, 2019 at 7:22 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Those look really sharp! Welcome to the mod from hell club! I have a lifetime membership myself!
  8. Oct 12, 2019 at 7:53 PM
    Blueknights75
    Ron
    Clayton, NC
    Looks great!
    Pinay likes this.
  9. Oct 12, 2019 at 8:18 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Thanks everyone! Was super worried about that tire looking too small but I love how it turned out.
    georgiey22 likes this.
  10. Oct 19, 2019 at 9:09 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Look is fantastic! Way to stick out the install, you should be proud.
  11. Oct 19, 2019 at 9:12 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Looks amazing! Tires fit the look perfect as well
    Rica25 likes this.
  12. Oct 19, 2019 at 9:13 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Looks great
  13. Oct 19, 2019 at 9:17 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Sweet looking ride!!
  14. Oct 19, 2019 at 9:18 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Lift spindles? Stance looks good, only way to make it look better is a few gallons of black paint. :thumbsup:
  15. Oct 20, 2019 at 7:12 AM
    trinituner
    trinituner New Member
    Andron
    Orlando, Florida
    2017 Silver 1794
    Truck looks really good man
  16. Oct 20, 2019 at 7:33 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Much better! What a story, talk about determination!
  17. Oct 20, 2019 at 1:57 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Thanks everybody! Definitely gave me a run for my money.... the wife was starting to gain some doubts there
  18. Oct 20, 2019 at 2:48 PM
    TXTundra2722
    2015 Black Tundra
    What spindles did you go with?
  19. Oct 20, 2019 at 4:45 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Maxtrac
  20. Oct 20, 2019 at 4:51 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    I concur, doctor...
    TRUCK LOOKS AWESOME!
  21. Oct 20, 2019 at 5:56 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Looks good I’d lift the rear more you’re nose high unless you’re into that look.
  22. Oct 20, 2019 at 7:36 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Ya I am a fan of a little front rake so I really enjoy that, but I have an adjustable rear shackle and can bump it up more if I’d like.
    xtyfighterx[QUOTED] likes this.
  23. Oct 20, 2019 at 11:33 PM
    El_fisher1
    El_fisher1 New Member
    18 sr5 cement tundra CrewMax.
    2.5 kings
    Looks good..I have a similar set up and dint have to trim much on the front plastic. Just move it forward a little
  24. Oct 21, 2019 at 7:22 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Ya thats pretty much what I did. I trimmed a little to be able to move the plastic forward. If you were to look at my liners without laying under the truck youd have no clue i did anything to them.
  25. Oct 21, 2019 at 8:07 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    Looks good. I've had the Toyos on mine now for about 7K miles and love them.
  26. Oct 21, 2019 at 8:14 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Not going to lie I am very impressed with them. I always knew about the tires and saw them everywhere but never did any research into them or how they perform. I am loving them so far glad they were available when I was at the tire shop.
  27. Oct 21, 2019 at 12:50 PM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    "hunny I'll be in garage Friday night and finish up Saturday morning so we can go do _____ Sunday"
    Sunday at 11pm, frantically finishing up major project to drive to work Monday morning. It's always something but it's worth it!
    Looks great!
    TheBeast and Darkness like this.
  28. Oct 21, 2019 at 1:04 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Been there many times
    TheBeast likes this.
  29. Oct 21, 2019 at 1:45 PM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    The wife claims she was looking up 24 hour tows because of how long the the passenger side took with the stripped tie rod end. She figured I was completely lost and I told her its a extremely long and tedious process re-threading that. Glad she held of from calling anyone hahahaha
