inspecting a higher mileage, reasonably new 2021 tundra for sale
Discussion in 'General Tundra Discussion' started by HundsonsBae, Feb 18, 2025.
  1. Feb 18, 2025 at 1:32 PM
    HundsonsBae
    HundsonsBae [OP] New Member
    I recently found a 2021 Tundra for sale I'm keen to buy. I've been a toyota truck fan forever, previously had a tacoma I ran forever, recently had a disasterous stint with nissan (I went with the cummins 5.0L XD... long story longer motor blew at 131,000kms), and now looking to get a late model 2nd gen tundra I can hopefully keep and love for many years. I don't drive much, around 12,000 kms a year, but, it will be a work truck used mostly to haul tools.
    Anyways, this one I found is a 2021 but already has 110,000kms. That seems fairly high mileage for a truck only a few years old. What are common concerns I should look for when going to check out this truck? I've read about oil leaks between engine and transmission being an issue, and electrical issues. I don't trust the selling dealership's pre-sale inspection to tell me anything meaningful. There is a full service history for the truck at one dealdership so it looks like it was well maintained.
  2. Feb 18, 2025 at 2:01 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Cam tower leak is really only big concern with the v8 trucks. Even then, a seep is no big deal....actual leak would be an issue. Ive not really seen much about prevalent electrical issues or other common leaks with the 2.5 gen. Sometimes the wheel speed sensors or wiring go bad, get hit with road stuff or whatever. Their location is the reason and some have installed aftermarket covers for them for more protection. They are solid v8 trucks.
    Rust of course
    Usual checks for leaks, bushings, etc. as for any used purchase, though these are not specific issues for this model.
    joseph_womack likes this.
  3. Feb 18, 2025 at 2:12 PM
    HundsonsBae
    Thanks, appreciate the info. Will look in to the cam tower leak.
  4. Feb 18, 2025 at 2:12 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    5.7s can have water pump leakage problems/failure but other than the stuff mentioned above not much
  5. Feb 20, 2025 at 6:39 AM
    2mchfun
    Valley plate coolant leak, flood damage, water in rear diff. if previously backing in boat. Look at paint wear on the hitch safety chain loops for towing frequency, maybe hard on tranny. Look at rubber on brake pedal for sign of excessive city driving.
    Hammertimerrrr and joseph_womack like this.
  6. Feb 20, 2025 at 6:56 AM
    koditten
    Kirk
    Midland of the Mitten
    Doesn't seem like it's driven excessive. That's only 65000 miles. That's nothing for the 5.7.
    Better grab it before someone else does the math.
  7. Feb 20, 2025 at 7:05 AM
    PermaFrostTRD
    Northern NY
    Service / maintenance intervals. Diffs, trans drain, etc done at 30 or 60k (at least) especially the transmission due to lack of external cooler that was removed in the 2019MY - if the truck towed a lot;
    As others have mentioned the cam tower thing, seep is a non-issue - a true leak could be but those are unicorns. Door lock actuators went on my 2014 in like 2017/2018; Otherwise the 2014 and now my 2019 have been rock solid;
    A quirk with the 2020, 2021 MYs is that the push button start won't allow a "remote start" work around where the truck doesn't shut off when you open the door. But other than that, if the above and previously mentioned things check out, and the price is right - send it.
  8. Feb 20, 2025 at 7:08 AM
    koditten
    Kirk
    Have you entered the VIN into the Toyota owners.com website to access all the dealer service performed on this truck?
    You only need the VIN and you don't have own the truck to check.
  9. Feb 20, 2025 at 7:16 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My truck has zero anything serviced at dealer. Take it as a praise, as they broke nothing in my truck ;) See the truck you buy in person, crawl under, talk to the owner.
    koditten[QUOTED] likes this.
  10. Feb 20, 2025 at 7:27 AM
    koditten
    Kirk
    We are the exception to that.
    Most peeps who buy a new truck will take it to the dealer during the warranty period.
    jhtram likes this.
  11. Feb 20, 2025 at 7:34 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I did that with our less than year old $70k Sequoia. Had to open a damage claim with insurance after that. Couple of months of fighting and they admitted and fixed everything, but, man...
  12. Feb 20, 2025 at 8:03 AM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I did that the first service with Tundra and wife's Venza, just that first 5000 miles.
    After that, unless something broke and it is covered under extended warranty that I failed to remember or something that my local shop refuses to touch and advise me to go dealer, I am not going within 5 miles of a dealership. (OK, I do drive by it on the highway, but that's their fault building there, not mine. I have to get home, one way or another, and this way is long enough, let's not make it longer)
  13. Feb 20, 2025 at 10:28 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Same here, never. I have a few years of experience as a mechanic (back in the day, old school) and I know my way around a vehicle for regular basic service/repair. Since Toyotas (at least in my case since the mid 70s) seldom need anything more than basic maintenance, I'm good with that.
    vtl[QUOTED] likes this.
