Input on air impactools?
Discussion in 'General Tundra Discussion' started by geno0506, May 10, 2019.
  1. May 10, 2019 at 8:49 PM
    geno0506
    geno0506 [OP] New Member
    Michael
    Just curious if any one have used this brand, Ingersoll Rand 2317G Edge Series Air Impactool and Ratchet Kit, Black
    https://www.amazon.com/gp/product/B004CY1DSS/ref=ox_sc_saved_title_3?smid=ATVPDKIKX0DER&psc=1
    Being the surgeries I've had I doubt I'll ever be at 100% again with my age and I love doing my own mods and work on the Tundra, this seems it may be easier physically!
    I do have some torque wrenches, can the above be used for torquing say, suspension and wheel nuts and things!
    Thanks for any input!
  2. May 10, 2019 at 8:58 PM
    Twinky
    07 double cab work horse
    No personal experience with it but if your interest heres a tear down video on a Ingersoll that is probably very similar.
    https://youtu.be/b7yV7uYq0wk
    It seemed decent.
    Copper Man and geno0506[OP] like this.
  3. May 10, 2019 at 9:11 PM
    geno0506
    Michael
    thanks for sharing that, :thumbsup: :cheers:
  4. May 10, 2019 at 11:26 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Of course that air ratchet can be used for the things you listed. I'm hoping you have a fairly deciant air compressor to supply air. Any tool you buy is useful as long as it gets the job done and you didn't hurt your self.
    Some will say buy the best, you won't regret it. There is some wisdom with mind set.
    Most expensive tools usually has the best warranty, the cheaper tools maybe not. My father sold tools for a living for 30 years. You get what you pay for.
    Good luck.
    geno0506[QUOTED][OP] likes this.
  5. May 10, 2019 at 11:30 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    I've got three IR impacts in my shop right now, two extended anvil and one short. All are approaching 25 years old. It's been my experience you're not going to wear one out in a home shop. Age and muscular dystophy have really changed my habits and I'm relying heavily on air tools and the newer battery tools.
    geno0506[OP] likes this.
  6. May 11, 2019 at 3:38 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    Here is some real world experience. Take it for what it is worth to you, because if you take my advice, you'll spend more money :D
    I think from that pack, you will use the impact wrench as often as you are dealing with tight bolts and you will use the ratchet once or twice for your entire life.
    For this reason, I recommend you spend a few dollars more and get this impact:
    https://www.amazon.com/NitroCat-120...569106&s=hi&sprefix=air+cat+,tools,270&sr=1-4
    The impact you showed only has 500ft.lb. of max torque. This seems like a lot, but if you are talking about suspension bolts with some age on them, it's not going to cut it. The one I listed has nearly 3 times the torque and is a pound lighter while being quieter. All around a better impact.
    As far as the ratchet goes, I've got a 3/8 and 1/4 in my toolbox that has been used once or twice each. They hog through the air, so even with a belt drive 60gallon compressor, you have to listen to noise while pushing the button, then noise while your compressor fills frequently. You always have an air hose in your way so you can't use it in very tight spots. Finally, they try to break your wrist. You have to keep a firm grip when trying to break something loose or be ready when you are tightening something because it is going to twist hard and fast when the bolt is tight. I found that you had to have a ratchet to break things loose or put final torque on something usually anyway, so might as well finish the job with the ratchet.
    If constant ratcheting is your concern, I would recommend battery powered:
    https://www.amazon.com/Milwaukee-ML..._1_2?keywords=2557&qid=1557570724&s=hi&sr=1-2
    This is a lot more expensive, but I would rather spend more for something that you will actually use and is pleasant to use. This one will still have the wrist breaking action of any auto-ratchet, but it will be quiet and can fit in tighter spaces.
  7. May 11, 2019 at 4:03 AM
    bfd300
    bfd300 New Member
    Believe it or not Harbor Freight air tools are decent. But can’t go wrong with IR.
    monaco730, geno0506[OP] and OBXTundra like this.
  8. May 11, 2019 at 5:37 AM
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    Ir get used and abused at my work daily and never give us trouble
  9. May 11, 2019 at 7:54 AM
    geno0506
    Michael
    Thank you all for the awesome responses, I really appreciate them ! :cheers:
  10. May 11, 2019 at 8:08 AM
    DoubleJackOnTap
    DoubleJackOnTap New Member
    SW Washington
    2018 Super White TRD Sport
    CoverKing Neoprene Seat Covers, UltraFlex
    geno0506[OP] and saybng like this.
  11. May 11, 2019 at 8:11 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Good advice. I own that exact air ratchet, it works fine. I rarely use it, or any other air ratchet.
    That Nitrocat 1200 is a nice gun, and extremely good value. Far lighter than that IR edge too.
    I’ll also suggest their 1056XL, the 1/2” stubby version. They are lighter, and fit where others don’t. I use mine at work all the time. Rated at 500 ft-lbs, I’m constantly amazed at it’s performance. Plenty for any Tundra projects. A good 3 years of steady use and not one hiccup either.
    https://aircat.com/1-2-composite-compact-impact-wrench
    Don’t use them for torquing stuff up though, loosening, and assembling only. Then torque with a torque wrench.
  12. May 11, 2019 at 11:13 AM
    Batel
    Batel New Member
    Bradley’s right , the air motor on that IR is an old design, it is not the torque monster the newer ones are. You’ll likely not wear the IR out, but If your budget allows, get a higher output one, especially if high torque is an issue. And look at some of the rechargeable tools, they’re great too. They allow me to do things I couldn’t do with just hand tools anymore.
  13. May 11, 2019 at 11:58 AM
    geno0506
    Michael
    Good advice, thanks for sharing! I'll check out the budget and see what I can do, have to sneak it under the wife's radar, @ARamirez73 next time we meet up, :lalala: what is said in the forum stays in the forum :cheers:
  14. May 11, 2019 at 12:09 PM
    geno0506
    Michael
  15. May 11, 2019 at 12:20 PM
    DoubleJackOnTap
    SW Washington
    Yes, I think that is the one. I've seen it on sale before in the flyers I think it was $89 or so.
  16. May 11, 2019 at 12:21 PM
    Remember your on PAROLE, don't violate it! This was your 2nd FELONY! one more and your out and I can't save you
    Twinky and geno0506[QUOTED][OP] like this.
  17. May 11, 2019 at 12:25 PM
    geno0506
    Michael
    WTF, that the past, this isn't a banable thread :censored::stirthepot::frusty: :poking: :crapstorm: :cheers::bowdown:
    Don't make my other personality come out to play, LMMFAO
  18. May 11, 2019 at 12:27 PM
    REMEMBER..THEY ALWAYS WATCHING YOU
  19. May 11, 2019 at 12:28 PM
    geno0506
    Michael
    thanks bro!
  20. May 11, 2019 at 12:30 PM
    Batel
    Batel New Member
    I always try to remember, happy wife, happy life!:amen:?
  21. May 11, 2019 at 12:49 PM
    geno0506
    Michael
    exactly, My wife always know so I can't get away with jack if I tried! Actually I always put my family ahead of me! :cheers:
  22. May 11, 2019 at 12:50 PM
    geno0506
    Michael
    of course, I'm just jackin around, she is always a step ahead of me! :angrygirl:
  23. May 11, 2019 at 2:45 PM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I have the HF earthquake and it is awesome.
  24. May 11, 2019 at 3:07 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I left air powered tools 3 years ago as cordless (battery) have gotten SOOOOOOOOO good. From little gyroscopic screwdriver to 3/8" ratchet to 1/2" impact twisting up some 800 lb-ft. No cord/hose = huge happy. Yes, there is a mooooooney difference. Otherwise I don't have an opinion on the specific IG tools.
  25. May 11, 2019 at 3:08 PM
    geno0506
    Michael
    cool, :cheers:
    yeah I went on their website, they look solid! I have a HF down the street!
  26. May 11, 2019 at 3:15 PM
    geno0506
    Michael
    I have a Milwaukee old 28V cordless drill, sawmill and circular saw in the garage that didnt get damaged in my garage fire but the 2 28V batteries did! It seems the batteries are $80-100 apiece though!
    these were before the fire and remodel
  27. May 11, 2019 at 3:15 PM
    geno0506
    Michael
    If I knew where to get the 28V batteries rebuilt or cheaper built ones, I'de do it!
  28. May 11, 2019 at 4:00 PM
    geno0506
    Michael
    OR18TRD[QUOTED] likes this.
  29. May 11, 2019 at 6:17 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I have a Nitrocat. Nitrocat & you won’t go back. After I bought my Nitrocat, I found there were “high-flow” fittings available. I started looking at the fittings of my hoses. Many are quite restricted compared to the high flow fittings. I bought new hoses & the high-flow fittings & even my old Craftsman impact sounds like it’s got new life. I highly recommend some good hoses & high-flow fittings.
    I highly recommend the Flexzilla high flow fittings & 3/8 air hose for use with any air impact tool.
    https://www.amazon.com/Flexzilla-Hi...zilla+air+fittings&qid=1557623608&s=hi&sr=1-1
    https://www.amazon.com/Flexzilla-Fi...=B001C6NC7O&psc=1&refRID=6CC9T8BRRKM981F7V23D
  30. May 11, 2019 at 6:20 PM
    SoCalPaul
    Paul
