Infamous Secondary Air Injection
Discussion in '2nd Gen Tundras (2007-2013)' started by RJL, May 3, 2022.
  1. May 3, 2022 at 11:24 AM
    RJL
    RJL [OP] New Member
    Ricky
    2007 White Tundra SR5
    Bed cover 1 piece
    I have a 2007 Tundra SR5 4.7L. Just changed out both air valves on the secondary air injection system. Where is the air pump for the driver side air valve located? I found one diagram showing in was under the intake? I can't locate that link anymore.
  2. May 3, 2022 at 11:26 AM
    JRS
    JRS New Member
    2012 DCLB
    Both are in the front passenger fender well. Remove the liner to get to them.
  3. May 3, 2022 at 11:35 AM
    RJL
    RJL [OP] New Member
    Ricky
    Bed cover 1 piece
    I have not removed the fender well liner yet, but there is only one wire harness and on hose exiting from that fender well. Both going to the passenger side air valve.
  4. May 3, 2022 at 11:37 AM
    JRS
    JRS New Member
    2012 DCLB
    Someone with a 4.7 will have to chime in. Both are there on the 5.7.
  5. May 3, 2022 at 12:10 PM
    AlexJD
    AlexJD New Member
    2009 toyota tundra 4.7
  6. Sep 28, 2022 at 10:23 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    I know I am late to the party but wanted to include some additional resources about the Failure prone Secondary Air Injection System. Anyone having issues do not hesitate to reach out.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
