Increase RIDE COMFORT?? Open to suggestions
Discussion in '2.5 Gen Tundras (2014-2021)' started by lukedias00, Jul 7, 2023.
  1. Jul 7, 2023 at 6:36 AM
    lukedias00
    lukedias00 [OP] New Member
    2014 Tundra 4x4 Off-Road Limited
    Hey Tundra bros,
    So I bought a machine early this year, not knowing hardly anything about lifting trucks. Bought it because it was in great shape but didn't know that 3/1.5 spacer lift is frowned upon until I started doing some digging on why it road like a dump truck on the road.
    I'm not looking for a Cadillac comfort, just looking to not arrive at work sore.
    Here's the set up:
    TRD Off-Road Bilstein Suspension (4600 I think) with a 3 inch spacer lift up front.
    1.5" blocks in back, (I know shackles are better but am not currently worried about the rear)
    35"x12.5"xR20 K02 Tires, (E-rated, which isn't helping the stiff ride)
    I did recently put JBA UCA on.
    And a front diff drop kit.
    I'm thinking first step is to get rid of the spacers up front and put some coilovers on from @Toytec Lifts, was going to put on Kings 2.5 with external res, but that seems overkill seeing as how 99% of my driving is pavement.
    Would something like the Toytec Eibach be sufficient? Pretty cheap, usually you get what you pay for but the reviews seem to be positive. How do Toytech/Eibach set up compare to Old man emu?
    Any insight would be appreciated.
    If anyone is interested in 35" K02 let me know ha.
  2. Jul 7, 2023 at 6:42 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    What about some 5100's on the top setting? Wouldn't cost a lot and isn't overkill.
  3. Jul 7, 2023 at 6:43 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If u drop the 20 inch rims, e rated tires, add eibach coils instead of spacers and go with CB shackles instead of blocks, that's going to be about as good as it gets.
    What psi are you running? That plays a big role. I like 35 normally but go up to 40 for long trips for mileage but I noticed a huge difference with only 5 psi on e loads.
    alb1k, 1UP, nobodyintexas and 5 others like this.
  4. Jul 7, 2023 at 6:50 AM
    lukedias00
    Have you run blocks and shackles? Wondering how big a difference they really make.
    I asked BF Goodrich (Michelin now) about Tire Pressure for the E rated K02 on a half ton, they said 39psi front and 42psi rear.. so that's what I'm running
    Do you run E rated tires?
  5. Jul 7, 2023 at 6:54 AM
    MadMaxCanon
    Ya I have KO2 also. I run 35 in front and 32 in back unless I'm on a road trip. All the weight is in the front and you need the traction in the rear. They say higher psi in back because of hauling or towing but most times your not. Try dropping your psi and see how it feels
    Also I have never messed with blocks I have shackles and roadmaster active suspension in the back with extended bumps.
  6. Jul 7, 2023 at 6:55 AM
    lukedias00
    Can you put a 1/4" CB shim on top of the 5100? Just to keep 3in up front, or I guess could swap out the 1.5" blocks for 1" shackles and just used the Bilstein 5100 top setting (2.3") I believe. What do you run?
  7. Jul 7, 2023 at 6:55 AM
    18" TRD Off Road Wheels
    Definitely ditch the 20 inch wheels first. Go to 18s. The added sidewall will soften stuff s bit.
    A bit more info on your intended use will help with suggestions. Pics as well.
  8. Jul 7, 2023 at 6:56 AM
    lukedias00
    What do you have up front? So you run 35" k02 E-rated at 32 psi in the back?
  9. Jul 7, 2023 at 6:57 AM
    MadMaxCanon
    There is no height adjustment in the back. You lift with the shackles. Make sure you get extended bumps and your shock can handle the added height.
  10. Jul 7, 2023 at 7:00 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Return it to the stock TRD Offroad config, with regular Michelin LTX A/T2 tires on 18 wheels. It actually was a pretty plush truck, on par or even better than my Volvo.
    Hoff, Oey12 and WILLINH like this.
  11. Jul 7, 2023 at 7:00 AM
    MadMaxCanon
    I currently have 275/65R18 Ko2s at 35 psi. Eibach coilovers up front with shims for 2 inch lift with durobump stops and trd swaybar. Rear has Billy 5160 with cb shackles, roadmaster active suspension and durobump for 2.5 inch rear lift at 32 psi.
  12. Jul 7, 2023 at 7:01 AM
    lukedias00
    I was referring to putting shims up front with the adjustable 5100's (2.3" of lift). Extended bumps for the front? or front and rear, haven't heard of rear bumps
  13. Jul 7, 2023 at 7:03 AM
    MadMaxCanon
    I offroad and the bumps were a clutch upgrade and keeps the suspension safe. No hard bottomouts and jumps are super smooth. Totally worth the money.
  14. Jul 7, 2023 at 7:05 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    39f psi 42r psi is for max load, I only put 32f 35r for my bfg
    after an hour drive it will go to 38f 40r
    lukedias00[OP] and MadMaxCanon like this.
  15. Jul 7, 2023 at 7:07 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I'm stock but I believe you can put the shim on up front since you already have upgraded UCA's.
    For the rear, @MadMaxCanon setup is solid
    MadMaxCanon likes this.
  16. Jul 7, 2023 at 7:10 AM
    MadMaxCanon
    You can safely put a 1/4 shim up front as is I think. With my eibach I had to get slightly longer bolts up top to be safe.
    Jaypown[QUOTED] likes this.
  17. Jul 7, 2023 at 7:10 AM
    lukedias00
    99% highway truck, don't really wanna spend a fortune returning it to stock, kinda like the look of it lifted
    GODZILLA[QUOTED] and Winning8 like this.
  18. Jul 7, 2023 at 7:12 AM
    lukedias00
    Do you run E-rated?
  19. Jul 7, 2023 at 7:27 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    275/70-18 BFG KO2 E rate
    lukedias00[OP] likes this.
  20. Jul 7, 2023 at 10:55 AM
    No need to go stock, but smaller wheels will get you more sidewall in the same size tire. That will be an improvement in comfort. If you're not on rough terrain and you're not towing, ditch the heavy tires as well. Spacers are usually fine for pavement princesses, so I wouldn't change that in the front if you like the look. Shackles will definitely ride better than the blocks in the back, though.
    As for the money, if you want a more comfortable ride you'll have to put something into it. If you try to go cheap you'll wind up changing it again later and paying more overall. Buy once, cry once.
  21. Jul 7, 2023 at 10:59 AM
    lukedias00
    After talking to Toytec, they recommended starting with the suspension and going to shackles.
    Going to do the 6112 Front and 5100 rear (Bilstein) and put CB shackles and take out the blocks. As well as put in a carrier bearing drop.
    I'll let y'all know it goes. The tires are brand newish so I don't really wanna go that route at the moment even though I know it'll soften up the ride
  22. Jul 10, 2023 at 6:59 AM
    king.cong.1119
    king.cong.1119 New Member
    I went from 35s E-rated MT tires to 37s C-rated AT tires, it completely changed the riding comfort, in a good way.
    Trust86 likes this.
  23. Jul 10, 2023 at 7:20 AM
    6112’s and Bilsteins in general are not known for a plush ride.
  24. Jul 10, 2023 at 7:26 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Op I had a similar setup on a Tacoma and had a similar setup that caused a bad ride quality.
    I had custom leaf springs made that lifted the truck 1 inch in the rear. OEM TRD Bilstein’s could not handle. I then installed Bilstein 4600’s (valved differently than OEM) on advice given…ride was even worst. Ultimately had to go to 5100’s for lifted applications. The OEM and 4600’s would over extend making the ride horrible.
    Small spacers are fine up front but those larger ones are not that good as you already know.
    Eibach equivalent all day everyday over the 5100’s IMHO. I had many family members and three of my own Toyota trucks either Bilstein’s (4600’s and/or 5100’s-not their high end stuff). Once I installed the Eibach, I completely changed my opinion of Bilstein simply due to the ride quality.
    dpast88 and lukedias00[OP] like this.
  25. Jul 10, 2023 at 7:29 AM
    To hear everyone on here tell it, remote resi 2.5” Fox’s are the nicest ride in town.
    vtl and lukedias00[OP] like this.
  26. Jul 10, 2023 at 7:36 AM
    lukedias00
    Well, I pulled the trigger on the bilstein 6112 coilovers for the front and 5100 for the back, and am going to swap out the rear block lift for CB shackles. I'm sure it'll help ride quality tremendously over 4600 with 3 in spacer.
    I got it all for 1,400, thought about fox or kings but just seems overkill for a pavement princess.
    Oey12[QUOTED] likes this.
  27. Jul 10, 2023 at 7:43 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    I agree with the higher end stuff be overkill.
    I have the CB 1 inch shackles on my Tundra. I was EXTREMELY leery about the OEM Bilstein’s being long enough after my Tacoma debacle. I went ahead and trusted CB’s advice. My truck rides nicer than stock in the rear now…
  28. Jul 10, 2023 at 7:51 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    cause shackle lower spring rate even further
  29. Jul 10, 2023 at 7:53 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    4600 are plush.
    Joro43 likes this.
  30. Jul 10, 2023 at 7:59 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I did 5100's on the bottom setting combined with +2.5" Eibach springs. It rides like stock and is exactly 3" of lift. I did however need to add a 1/4" thick shim on drivers side to correct the 1/2" of lean.
    Rodtheviking likes this.
