RESOLVED!!! (INCESSANT BEEPING!!)
Discussion in 'Electrical' started by DaveInTexas, May 2, 2023.
  1. May 2, 2023 at 4:51 PM
    DaveInTexas
    DaveInTexas [OP] New Member
    Dave
    West Texas
    2020 Tundra SR5 + 2003 Tundra SR5
    The 2020 has a Ranch Hand front brushguard/bumper
    YEARS LATER EDIT: See post #15 for the great solution I found!
    omg, I am about to lose my mind over the unending “courtesy alerts” this truck makes; seatbelt! keys! door!
    I don’t care if all vehicles have em. I don’t care if the NTSHA says we need them. I just need the noise to stop before I end up in the mental ward!
    I do a lot of very short drives on pastures where I’m not needing the seatbelt, keys are left in, door ajar for valid reasons.
    I have a seatbelt cheater but that’s not efficient.
    I’ve asked two service centers to disable them, they couldn’t figure how.
    I’m about ready to offer $2000 to anyone who can shut. them . off!
  2. May 2, 2023 at 6:19 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    Head unit, sub's , components, front / back camera's, too many lights to mention, dual battery, winch / bumper, TRS projector headlights, roof nest hard-shell, integrated backup spot lights, vault, all aluminum radiator / water pump, tailgate storage, plenty of dents and scratches
    there's a little speaker in the dashboard... somewhere... I never thought about "disabling" it, but that's a GREAT IDEA!
    :redxfall:
    Jeff_5_7 likes this.
  3. May 2, 2023 at 6:26 PM
    chrisf111
    chrisf111 New Member
    Drivers seatbelt is easy to open up and remove the spring that forces the switch UP when no belt installed. Passenger side should be the same but it's a little dicey with the airbag deployment logic tied into if the belt is buckled. I'd just keep a junkyard seatbelt cutoff plugged in that side. That's what I do for my dog riding up front.
    The door sensor should be easy enough to bypass the door jam trigger switch. Just remove and wire the ends together. The truck will think door is always closed.
    The one that may not be so quick or easy is the key left in ignition, though I don't know if that goes off if the door is closed...
  4. May 2, 2023 at 6:43 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    I can confirm the seat belt one works, worked on mine, bypassing the door trigger will disable the dome light though :angrygirl:
  5. May 2, 2023 at 6:47 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
  6. May 2, 2023 at 6:52 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    HOT DAMN! Weekend project located!
  7. May 2, 2023 at 6:57 PM
    DaveInTexas
    Dave
    West Texas
    How do you know this won’t mess with the airbag?
    if not, I’m interested!
  8. May 2, 2023 at 7:00 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    I've a 2007, not even a key to turn off the passenger side, i don't believe the airbags had any connection to the seatbelts until... later? :notsure:
  9. May 2, 2023 at 7:05 PM
    chrisf111
    2007+ the passenger side airbag is connected to the seat belt switch. I believe there is some logic on the passenger side to only set off the airbag depending if the occupant detection system detects weight in the passenger seat and/or the belt is buckled.
    As far as I know the driver side is always active, as the truck always assumes there is a driver.
  10. May 2, 2023 at 7:12 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    So since my buckles are telling it that they're buckled, that means it assumes there's someone there right? My dog was setting off the weight sensor while i was driving, VERY annoying
    Also, i jumpered the seat belt buckle, not removed the spring.
  11. May 2, 2023 at 7:15 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    The dealer should be able to disable the seatbelt chime; they did on my '21 Pro... If you look in your owner's manual it's part of the adjustable settings in one of the charts showing what you can change/adjust and what the dealer can adjust for you (this one is dealer only)
    The rest of the silliness is tied into the whole safety suite mess, and all those warning beeps are designed to help you avoid leaving a child or senior, etc... in the vehicle unattended, etc... I'm sure at some point someone made a mistake that resulted in someone's death (left child, etc.) in vehicle and in someone's infinite wisdom it was decided that auto manufacturers should do A,B, and C to avoid this happening in the future.
    Kinda like the floor mat cluster from a while back.
    Ponderosa_Pine likes this.
  12. May 2, 2023 at 8:10 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    One beep I’ve never figured out is sometimes when off-roading for a while a beep coming from around the center display starts going off every few seconds. Only way to turn it off is to stop and restart the engine. Not sure if related to lots of bouncing around or what. Removing the beep speakers is a genius idea.
    Tripleconpanna likes this.
  13. May 2, 2023 at 9:32 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    In theory I am pretty sure I can make the truck never beep again by removing the signal to the speaker. I’m not sure I would advise it permanently but maybe put it on a toggle switch.
    You can keep the switch “off” disabling the speaker for as long as you own it. If you ever need it back to factory to sell or for inspection whatever just flip the switch back on.
    I will do some testing on this and see if it works
  14. May 3, 2023 at 11:22 AM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    Sorry to hound you, my simple brain needs things spelled out, so if my seat belt buckles are tricked into thinking they're always buckled you say that WILL interfere with the airbag? :confused:
  15. Mar 23, 2025 at 11:41 AM
    DaveInTexas
    Dave
    West Texas
    I am thrilled to report I have been able to easily, cheaply & safely disable the &@#! seatbelt alarm!
    I can now enjoy my 2020 Tundra and not have to banish Toyota from my list of ‘next trucks’!
    These are available on Amazon/EBay <$10
    I trust them to be strong enough in a collision.
    They are sold as “Seatbelt Extenders”
    You plug it in and leave it there.
    atc250r likes this.
  16. Mar 23, 2025 at 11:55 PM
    Tripleconpanna
    You know the seat belt alarm is a techstream setting that the dealer can shut off for you if you ask... should be no charge!!!
    I had it done on my '21 Pro :thumbsup:
    mustang67408 and GODZILLA like this.
  17. Mar 24, 2025 at 5:35 AM
    DaveInTexas
    Dave
    West Texas
    Nope!
    Asked two different dealers, they spent an hour, couldn’t get it done!
    Thanks tho!
  18. Mar 24, 2025 at 5:46 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
  19. Mar 24, 2025 at 5:53 AM
    Tripleconpanna
    That's an interesting, although not unheard of, response from some dealers... especially considering it's right in the owner's manual....
    It's under Customization / Customizalbe Features starting on pg 564 for my '21 Pro:
    An 'O' under line 3 is an indication the dealer can adjust the setting:
    Pg 572 shows Seat Belt Reminder Buzzer is NOT customizable by the user at the mult-info display or multimedia center, however it is an optional setting adjustment by the dealer:
    Sucks that you got the run around, but I'm glad you found another solution :thumbsup:
  20. Mar 24, 2025 at 6:05 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    brhodea and atc250r like this.
  21. Mar 24, 2025 at 6:24 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    I'm going to guess the "speaker" is attached to the back of the gauge cluster. It oughta take about 20 minutes to pull the cluster, remove the speaker, and reassemble everything. Then you've gotten rid of the thing for all alerts.
  22. Mar 24, 2025 at 10:20 AM
    DaveInTexas
    Dave
    West Texas
  23. Mar 27, 2025 at 9:32 PM
    mustang67408
    mustang67408 Toyota Master Diagnostic Technician
    Victor
    Hot dry place in Nevada
    2010 Tundra CM 4x4 FFV 5.7 (Supercharged)
    Current : Magnuson S/C 5.7 FFV, Tundra CM, SNIV tuned w/HP Tuner, SG-1 Wide band AF w/gauge, TRD cat back, slotted and drilled rotors, stainless brake lines, TRD pads front and rear, front OEM Sport sway bar, rear TRD sway bar, 38 gallon OEM fuel tank, Tesla screen, ham radio, 2.5 Icons w/ res front and rear. X2 battery w/Voltage Booster Pro 2014 OEM wheels. https://drive.proton.me/urls/Y8739Z14BG#HCVT8AowG9fl ---------------------------------------------------- Previous: 2002 Tundra AC 2wd... Converted to OEM 4wd , S/C 4.7, TRD exhaust. 35's w/4:88's, too many other mods to list. https://drive.proton.me/urls/SWEWY4AFMC#eC7zX57Ex6pI ---------------------------------------------------- Other: 1967 mustang , Blown 408, 671Mike Kuhl 12.5% overdriven, 300shot NOs 5 speed TKO600, 4:11's Ford 9", Detroit Locker (real) Evans Coolant, Twin 12" Spahl fans https://drive.proton.me/urls/ABBVY3TQ3M#OT9LceyNwbTy ---------------------------------------------------- 2015 4runner TRD drop in filter Prinsu 1/2 roof rack, Nfab side steps, TRD FJ lift kit. ---------------------------------------------------- 2007 Prius 45mpg+ ... It's the only way to afford fuel for these Beasts!
    You're right, I do it all the time. Haven't found any seat belt chime I can't turn off.
