In Dash Squeak Solution
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hoff, Jul 18, 2020.
  1. Jul 18, 2020 at 10:18 AM
    Hoff
    Hoff [OP] New Member
    2021 TRD OFF ROAD CREWMAX
    AE193D0D-AB97-4767-BB93-6E86F7DA820B.jpg 1B569D4F-325B-49F2-9D6E-5F5EDFD93210.jpg 45B074C6-865D-4185-AB86-B830E5D7C1E7.jpg 43F08C4F-DF73-4968-AA8A-14403EEAEF72.jpg 4A76C0DD-4307-4E4D-AFEA-D52870292280.jpg So I had what I thought was a in dash squeak which drove me crazy. I sounded like something plastic was loose and giggling. But not all the time. What I found was behind the engine the ABS brake lines are held in place by a rubber or plastic brackets. I sprayed the ABS brake line holding brackets with a silicone spray and I haven’t heard that annoying squeak since.
  2. Jul 18, 2020 at 1:34 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Hmmm,I'm gonna do that.I have odd noises at different temps and times in my truck. Thanks
    Hoff[OP] likes this.
  3. Jul 18, 2020 at 1:40 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    ECM brackets have also been known to cause interior noises.
  4. Jul 18, 2020 at 1:42 PM
    Rob's Inferno
    And numerous pieces of the plastic dash rubbing etc. Ive been chasing squeaks,creeks and various noises.
  5. Jul 18, 2020 at 1:43 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Does it sound like a sharp squeak over bumps? I have the same thing. I've wasted so much time trying to figure it out lol.
  6. Jul 18, 2020 at 1:46 PM
    Hoff
    What I was hearing was kinda like a crackling sound. It’s hard to describe and yes when driving over small bumps at slower speeds.
    Tundyfundy likes this.
  7. Sep 2, 2020 at 11:18 AM
    DaleDanTony
    DaleDanTony New Member
    14 SR5 CM
    i'm getting a vibration sound around 1000-1500 rpm, regardless of temp. sounds like plastic.. and behind the stereo/ dash... but still interior.. any ideas?
  8. Sep 2, 2020 at 12:54 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Another common place on the 3rd gens is the plastic clips on the upper end of windshield just inside the headliner near the sunvisor , these plastic clips help align the windshield upon installation and sometimes they rub on the glass causing an intermittent squeak or rubbing sound .
  9. Sep 2, 2020 at 6:36 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I searched, off and on for a few years, for a squeak that one day I found when I reached out the window, and grabbed a hold of the side view mirror s plastic housing. I couldn t believe it was from outside cause it sounded like it was inside the dash somewhere.
    DaleDanTony likes this.
  10. Sep 2, 2020 at 7:01 PM
    Another squeak that took me months to figure out happens over small bumps. The condenser top mount bushings rub against the bolt and squeak. Solution is to put some grease inside the bushing.
