IMPORTANT EQUIPMENT RECALL (Remedy Notice) Potentially Defective Power Steering Gear Service Replace
Discussion in 'General Tundra Discussion' started by PSYCHO WHITE TUNDRA, Feb 22, 2022.
  1. Feb 22, 2022 at 5:32 PM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA [OP] Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    0F978B4B-AEB7-474F-BC59-148B7BCCB591.jpg FYI- Incase y’all haven’t received one yet. It’s coming. Possible years affected are 2007-2021 Tundra models
  2. Feb 22, 2022 at 5:48 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Just got mine today.
  3. Feb 22, 2022 at 5:57 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
  4. Feb 22, 2022 at 6:01 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Oh well, some of us may have missed it. Didn't realize could only mention it once.
    ATV25 and Kgfit85 like this.
  5. Feb 22, 2022 at 6:05 PM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    Giskk and ZappBrannigan like this.
  6. Feb 22, 2022 at 6:08 PM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
  7. Feb 22, 2022 at 6:10 PM
    Bergy24
    Bergy24 New Member
    I started the post. You are correct it’s was a heads up. I wasn’t officially notified by Toyota until late January
  8. Feb 22, 2022 at 6:26 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Hope everyones turns out ok , calling tomorrow to see if appt. needed, and if they even have the parts if needed. Not going to take it in and have them tear it apart and then set and wait for parts for 6 months.
  9. Feb 22, 2022 at 6:45 PM
    biebs96
    PA
    Is it my understanding that unless the vehicle was built after Aug 5, 2021 or has had steering rack work that there is a possible effect?
    So essentially if no rack work was done on a vehicle older then Aug 4, 2021 technically it would not be effected?
    DIYDad, Terndrerrr, Giskk and 10 others like this.
  10. Feb 22, 2022 at 6:48 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    That’s the way I am understanding it…
    DIYDad, 1lowlife and biebs96[QUOTED] like this.
  11. Feb 22, 2022 at 6:59 PM
    biebs96
    PA
    I checked my VIN, so it appears it is a warning to those possibly effected by repair or built after.
  12. Feb 22, 2022 at 7:00 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    I searched my vin as well and got the same response.
    MatD13 and biebs96[QUOTED] like this.
  13. Feb 22, 2022 at 7:54 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Nope. My 2020 was on the lot in March of 2020. I thought this was just for the '21's until I received my notice today.
  14. Feb 22, 2022 at 8:11 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Got my notice today, but when I search my vin for recalls just shows the headlight one
  15. Feb 22, 2022 at 11:33 PM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    Same got mine too, checked the vin and came back with no current recalls on mine.
  16. Feb 23, 2022 at 12:00 AM
    Look in the red box from the letter in the first post. If you haven't had rack work done since August 5th 2021, then any older trucks are NOT included. Big bold letters.
  17. Feb 23, 2022 at 4:50 AM
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    Nope. The original comment you replied to is correct, it’s in the letter, they blanket sent this notice to everyone to net not only the 2021 built after august, but anyone who may of had a tundra that got rack work done during those same months. So yours being a 2020 doesn’t matter as if your rack had an issue and needed to be replaced and it got one that was made 2021 august+ then you would have potential is what they are saying.
    the recall is all based on a cutting tool that they found went out of spec by a said date, and a collar of sorts for the rack may of been cut out of spec causing the failure, so although the vehicle may have a rack made during those months of production (new vehicle, or a oem replacement rack) it still comes down to if it’s out of spec or not.
  18. Feb 23, 2022 at 5:02 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Best gen for the win!
  19. Feb 23, 2022 at 5:31 AM
    Architect
    Architect New Member
    marc
    New Jersey
    2020 CMTRDPRO
    I agree, I too received the notice yesterday for 2020 Pro and that was my interpretation as well.
    Enjoihavok[QUOTED] likes this.
  20. Feb 23, 2022 at 7:00 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I finally read the fine print, so to speak. I'm good. Thanks for pointing that out.
  21. Feb 23, 2022 at 7:38 AM
    Orracle
    Orracle New Member
    Canton, GA
    Received mine today
  22. Feb 23, 2022 at 10:03 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I called the dealer. She looked my truck up and pretty much said I do not need to bring the truck in, but if I noticed oil or sounds to have it looked at. Alrighty then… lol
  23. Feb 23, 2022 at 10:11 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    2018, I'm good here too.
    Oey12[QUOTED] likes this.
  24. Feb 23, 2022 at 2:08 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Called my dealer today , said I need to wait for 2nd notice before scheduling anything, I didn't realize there is a 2nd one to verify the need. Also said, if I need to come in , won't schedule me until parts are available.
  25. Feb 23, 2022 at 2:10 PM
    Did you have steering rack work done in 2021? If not, then you don't have one of the 151 replacement parts that could have the defect. Toyota is just being cautious issuing these. It's a really small batch of parts.
  26. Feb 24, 2022 at 6:07 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I received mine yesterday. Checked the Vin. Not affected.
  27. Feb 24, 2022 at 7:15 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    The way I read it, I got my 21 in December of 20. Had no work done on it in that area.
    No leaking or noise, I'm good and can ignore.
  28. Feb 24, 2022 at 7:55 AM
    Retired...finally
    What was the build date? If later than October you should be fine. Mine was smack in the middle of the window but I was one of the 75%ers with a rack built on the three good machines.
  29. Feb 24, 2022 at 7:59 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Haven't gotten one for my 2020 yet....
  30. Feb 24, 2022 at 8:00 AM
    You will, but it'll be just like the others. Unless you have had power steering replacement parts since August 5th 2021 you don't have one of the defective parts.
    Moe2o4[QUOTED] likes this.
