Impact wrench for timing belt change
Discussion in '1st Gen Tundras (2000-2006)' started by sixteen2nd, Mar 4, 2020.
  1. Mar 4, 2020 at 5:30 AM
    sixteen2nd
    sixteen2nd [OP] Shadetree Mechanic
    2003 White Tundra Access Cab TRD
    As the weather gets nicer here in the northeast I am planning ahead for my timing belt change along with other maintenance. I bought a fixer-upper 2003 AC this winter and it has been sitting since January. I jumped on the DeWalt 20volt bandwagon a few years ago and want to get a 1/2 inch impact wrench for working on the Tundra. Do people think the extra torque of the DCF899 (700ftlbs max and 1200ftlbs breakaway) is worth the extra cost (about $100 more) over the DCF894 (330ftlbs max and 600ftlbs breakaway)? I'm thinking of things like the harmonic balancer and other front end parts.
    Thanks!
  2. Mar 4, 2020 at 5:39 AM
    Professional Hand Model
    Hand Protectors
    Yes!
    PCJ likes this.
  3. Mar 4, 2020 at 6:06 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Depends on how drastically bigger it is and if it'll fit where you need it. Always shoot for the biggest if it'll work.
    I have the Milwaukee mid torque (600 ft lbs) because of its size. The high torque is too chunky for my usage (wheels/suspension).
  4. Mar 4, 2020 at 8:31 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    That's a tough call.
    The smaller 894 will be more convenient and will offer enough torque to handle 95% of the fasteners you'll encounter. Plus if you're dealing with a fastener that's in tight quarters, all the torque in the world won't help if you can't reach it.
    On the other hand I've never heard anyone say, "I wish this impact wrench didn't have so darn much torque!"
    bmf4069 likes this.
  5. Mar 4, 2020 at 9:01 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
  6. Mar 4, 2020 at 9:20 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I don't remember the balancer bolt being that big of an issue to remove with 1/2 inch drive breaker bar. You'll want to look into the Schley tool cause you also need to torque the bolt back on.
  7. Mar 4, 2020 at 9:24 AM
    Hand Protectors
    We’re assuming the radiator will be removed for maximum access?
  8. Mar 4, 2020 at 10:01 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I have this tool.... It's fantastic! Schley hit a home run with this thing... Part Number SCH64300. I bought mine used off eBay for 35 bucks.... Well worth it
  9. Mar 4, 2020 at 11:00 AM
    sixteen2nd
    I am removing (and replacing) the radiator so there should be good clearance.
  10. Mar 4, 2020 at 1:52 PM
    Hand Protectors
    You have clearance Clarence.
    bmf4069, TX-TRD1stGEN and 15whtrd like this.
  11. Mar 4, 2020 at 1:54 PM
    sixteen2nd
    roger Roger...and don't call me Sherly
  12. Mar 4, 2020 at 2:00 PM
    Hand Protectors
    Surely Shirley.
    bmf4069 and 15whtrd like this.
  13. Mar 5, 2020 at 3:48 AM
    tvpierce
    Maine
    The price seems to have gone up considerably.
  14. Mar 5, 2020 at 3:51 AM
    Hand Protectors
    What is that tools specific job? Can something else be used, say like an impact wrench, in its place?
  15. Mar 5, 2020 at 4:05 AM
    tvpierce
    Maine
    It holds the harmonic balancer so it won't spin when you loosen/tighten the big nut on the front of the crank shaft. An impact works to remove it, but it's supposed to be torqued to a certain spec on install. Personally, I've just used my air-impact to tighten them in the past. I figure as long as my air-impact has a max torque higher than the spec, that's good enough for me. I know purists will scoff at my approach, but this is one of those times when the precise torque isn't critical, it just needs to be tight enough to keep it from backing off.
    I've also used the old shade tree trick of cotton clothes line rope stuffed down cylinder #1 on a compression stroke. It worked quite well with no problem, but the air impact is just quicker and easier.
  16. Mar 5, 2020 at 4:12 AM
    Hand Protectors
    So no need for special tool if you have impact wrench.
  17. Mar 5, 2020 at 4:45 AM
    sixteen2nd
    I haven't done it yet, but according to this video you can use just an impact wrench if you don't have the harmonic balancer tool.
    https://youtu.be/fM1A0DWhRHc?t=81
  18. Mar 5, 2020 at 4:51 AM
    sixteen2nd
  19. Mar 5, 2020 at 5:21 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    There are a number of homemade versions of the Schley tool, and even Toyota describes an SST that looks homemade, but yes, I would agree.... An impact would be fine to remove/install. The Schley tool does allow you access without removing the radiator, but it's too easy to pull it out and not risk damaging it. Plus, as was stated, the Radiator is cheap enough that replacement when you do the T-belt is a good idea.
    Peace of mind...
  20. Mar 5, 2020 at 6:43 AM
    tvpierce
    Maine
    IMHO: Yes. (Edit for clarity: Correct, no need for special tool if you have an impact, IMHO.)
    But I appreciate people's desire to do it "right" and torque to spec. Personal preference.
  21. Mar 7, 2020 at 3:52 PM
    sixteen2nd
    I splurged (buy once, cry once) and got the DCF899. I'll report back when I do the timing belt how much “easier” it was with more torque
