I'm Stumed
Discussion in '2nd Gen Tundras (2007-2013)' started by AnthonyC, May 7, 2017.
  1. May 7, 2017 at 3:32 PM
    AnthonyC
    AnthonyC [OP] TAKE IT EASY WHILE YOU"RE GOING FAST
    Anthony
    Virginia Beach, VA
    2010 Tundra SR5 TRD DOUBLE CAB
    TRD DUAL EXHAUST, FIRESTONE AIR BAGS
    Hello guys and ladies
    I just replaced the A/C compressor, dryer, expansion valve. I opend up the ductwork to check the evaporater for any obstructions on the outside of the evaporater. Put everything back together, evacuated the system, and charged it. Put the dash back together. Everything works except for the radio, clock, ambient temperature reading. I also have an icon lite for an air bag. I pulled the dash skin back off to double check all my connections. I disconnected the battery before I started this project. The A/C works beautifully, defrost, and heat work as it should as well. I checked all the fuses. I'm at a loss. Can anyone help me out?
    Thanking you in advance,
    Anthony C
  2. May 7, 2017 at 3:39 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Maybe disconnect the battery again then reconnect after a few mins?
    TXRailRoadBandit73 likes this.
  3. May 7, 2017 at 3:40 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I hate gremlins!
  4. May 7, 2017 at 5:37 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm all over the rum and seegar part!
    Law323 likes this.
  5. May 7, 2017 at 5:56 PM
    Yeah disconnect both terms wait few minutes let ECU reset
  6. Aug 10, 2019 at 3:13 AM
    AnthonyC
    Anthony
    Virginia Beach, VA
    I apologize for the late response, it was just one wire that connected to the fuse panel that kept disappearing in the dash when I tilted it to put it place. I found it when I started to trace the wiring in the dash. I had the dash on the tailgate and noticed this wire that I know I didn't connect while the dash was in place. Bingo! that was the problem.
    Once again I apologize for the late reply. It is a must reply for other Tundra guys and gals here in the community.
    15whtrd, NWExplorer, Darkness and 4 others like this.
  7. Aug 10, 2019 at 5:22 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Awesome! Great to hear you successfully trouble shot your dash gremlin. Thanks for sharing your victory.
  8. Aug 10, 2019 at 7:08 AM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    Glad to see you’re no longer stumed...:rofl:
    BestGen likes this.
  9. Aug 10, 2019 at 12:29 PM
    AnthonyC
    Anthony
    Virginia Beach, VA
    Also I’d like to note. To get at the expansion (TXV) valve without taking out the dash. Remove the steering wheel assembly. You will be able to see the lines going into the TXV.
    If the evaporator has a leak the dash has to come out to get to the plentum.
