I'm part of the Gen1 Tundra Family! :)
Discussion in '1st Gen Tundras (2000-2006)' started by ToyotaJim, May 7, 2020.
  1. May 7, 2020 at 7:34 PM
    ToyotaJim
    ToyotaJim [OP] New Member
    Pristine condition for a 20 year old truck. I thoroughly inspected. Mechanically it's 9 out of 10, only deducting due to about 150,000 miles. Drives great even at highway speeds, all gears worked in a parking lot test, climbed curbs effortlessly, engine and transmission performed excellent with no apparent problems in performance or fluids or hints of any issues. Cosmetically it's a 9 out of 10 with some minor blemishes, inside and out. And the blemishes are either fixable or very trivial. Big item, no rust and it looks like it had a very gentle and well-loved 20 years...
    Carfax totally clean, and this was babied and spent 75% of its life in Southern California... :)
    It was by far the least expensive Gen 1 I've looked at anywhere in the nation, especially with the King lift kit and mag wheels, and it was relatively close.
    Overall, I'm very very happy and the bubbly look has really grown on me. :)
    I very much appreciate all the advice on this forum! Thanks everyone!
    MrAristo, revtune, speedtre and 15 others like this.
  2. May 7, 2020 at 7:37 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    congrats. How's the frame look? From that front angle it almost looks like it has baja front fenders...or whatever they're called. It looks great!
    edit:
    or maybe it's just cause there isn't any fender flares up front???
    ToyotaJim[OP] likes this.
  3. May 7, 2020 at 7:41 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Definitely different fenders.
  4. May 7, 2020 at 7:42 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    hard to really see. Need another angle
  5. May 7, 2020 at 7:43 PM
    ToyotaJim
    I crawled all around under it and saw no serious issues or rust, except the muffler. Frame looks to be in excellent condition and with a heavy protectant coating. Might be a small few spots that could be addressed.
    Maybe someone here with a more trained eye can provide feedback?
    Mountun Goat, Darkness and NUDRAT like this.
  6. May 7, 2020 at 7:49 PM
    ToyotaJim
    A few more underneath. I found almost no rust. Would it be a good idea to get under it with a wire brush and get that surface rust off and hit it some black rustolium, or should I take it to a pro?
  7. May 7, 2020 at 7:50 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    looks like a great find. Congratulations.
    I'd say to change those brake & P/S fluids.
    Which implies you may want to just change all fluids & lube all the zerk points underneath.
    It's a nice truck, don't let simple maintenance catch you out. Better to know where you are starting from.
    Enjoy it, looks like a real find.
    speedtre, bmf4069 and ToyotaJim[OP] like this.
  8. May 7, 2020 at 7:51 PM
    ToyotaJim
    Fenders definitely flare out front and rear.
  9. May 7, 2020 at 8:05 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    i'd say taking it to a pro is overkill at this point. i'd go the wire brush & paint route. I'll just say I'm a big fan of POR-15 Top Coat.
    It's the UV stable version of POR-15, little pricey but I've found it does what you want it to & lasts.
    You might look into Fluid Film or Waxoyl. It really keeps a clean truck clean (rust free) underneath.
    ToyotaJim[QUOTED][OP] likes this.
  10. May 7, 2020 at 8:18 PM
    ToyotaJim
    Some asked about the flares. Don't know more about the flares. Here's two good pictures of the flares.
    The lift kit has King written on it. I'm not experienced with lift kits but some research suggested they are very good. The wheels and tires are 305/70/16 BF Goodrich KO2 ATs and they all appear nearly new.
  11. May 7, 2020 at 9:13 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Inspect that center bearing, the rust around the flange might mean it's on borrowed time.
    NUDRAT and ToyotaJim[QUOTED][OP] like this.
  12. May 7, 2020 at 9:28 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  13. May 7, 2020 at 9:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Fiberglass fenders on that bad boy.
    Someone took good care of it, I’d say you did well!
    MrAristo, Darkness, NUDRAT and 3 others like this.
  14. May 7, 2020 at 9:36 PM
    empty_lord
    05 rollover special
    It’s sitting on a body lift. Not a big fan of those... but you can’t really remove it without going with smaller tires
    imDementeD and ToyotaJim[OP] like this.
  15. May 7, 2020 at 9:52 PM
    ToyotaJim
    I'd love to know more since you seem to know what you're talking about. I'm pretty dumb when it comes to this.
    NUDRAT likes this.
  16. May 7, 2020 at 10:03 PM
    Limu
    Limu New Member
    Alan
    2001 Tundra white
    Donahue coilovers front, Fox rears. Deaver 10 leaf pack
    Looks nice. Great find
    NUDRAT likes this.
  17. May 7, 2020 at 10:12 PM
    empty_lord
    05 rollover special
    Where the body and the bed mount you’ll find the bolts that mount them. From the one photo you posted under the bed it appears there are body lift pucks. Factory mounts for the bed were straight onto the frame. A body lift does as it says, it lifts the body off the frame to clear larger tires. Likely have a steering shaft extension and some other little things. Good news is it’s all reverseable (but time consuming) But your tires on it now will no longer fit without rubbing dang near everything
  18. May 7, 2020 at 10:25 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Yup that's why the engine splash guards are missing. Those don't work with a body lift
  19. May 7, 2020 at 11:41 PM
    ToyotaJim
    Something like this might be a easy solution. Any downside?
    https://youtu.be/b1R5AMDqDRY
    Lil Steve and NUDRAT like this.
  20. May 7, 2020 at 11:43 PM
    empty_lord
    05 rollover special
    yea. any rubber like thing there will help greatly keeping junk out of the engine bay
  21. May 8, 2020 at 4:21 AM
    Professional Hand Model
    Hand Protectors
    Scored!:yes:
    150k miles is just getting started on these 4.7L engines.
    As far as the body rust, I’d just spray the whole frame with some PB Penetration (one can should do) and come back a few days later and do a grease rub using a 2 tubs of Moly-b and a sponge. Lots of work doing the grease rub, but it will never come off and it turns your frame black again. The grease turns from goo when applied into a doughy protective shell over time.
    ToyotaJim[OP] and NUDRAT like this.
  22. May 8, 2020 at 5:50 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Wow, great start!! Kings upfront, bilsteins in the back, fiberglass fenders, ko2's, body lift and super clean!
  23. May 8, 2020 at 6:18 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The truck has so much lift in the front in you've got easy access to do headers. :yes:
    Great find! She looks nice.
  24. May 8, 2020 at 6:22 AM
    imDementeD
    I was looking at this and completely jealous as I am contemplating starting this, this weekend since I got the rest of my tools in...looks too easy on this build!
  25. May 8, 2020 at 6:33 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can't believe he has OEM upper control arms with that much lift. Didn't think it was possible.
    ToyotaJim[OP] and imDementeD like this.
  26. May 8, 2020 at 6:43 AM
    Cjames17
    Cjames17 You gotta wanna
    Indiana
    2019 Black SR5 TRD Sport CM
    Great looking truck. I love that body style.
    Northern and ToyotaJim[OP] like this.
  27. May 8, 2020 at 7:40 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It isn't doing much lift by the coilover so the arms aren't struggling. The body lift is increasing the gap between body and frame, that gives more space for header install. The fiberglass fenders look like they give about 3" rise and 3 or 4" flare out. 2 reasons why he doesn't have fender liners. Looks like there are wheel spacers up front as well.
    Sweet truck, I'm liking the color and the stance. Really a clean find.
  28. May 8, 2020 at 10:39 AM
    ToyotaJim
    Thanks everyone for the information and encouragement. I looked nationwide for a long time for this unicorn. The only drawback is the mileage, which is actually low for 20 years and low for a well-maintained Tundra, but it's still 1/2 way to the moon and a lot of miles... But it was among the nicest and lowest mileage ones for sale I found and it was local to me, and it also to my surprise the least expensive especially with the condition and lift.... From my research on the value of these along with the condition & lift, I feel like I paid about 1/2 what the dealership could have sold it for. I don't want to say how little I got this for ... but for the price I bet everyone here would have walked in with cash and bought it. It was really inexpensive and I am still surprised and waiting for the engine to blow or the wheels to fall off. lol.
    I was actually a bit nervous and didn't want to jinx myself. I put down a ~10% deposit on a signed purchase contract, but the dealership had to fix a few minor things and it took 2 days. I was sweating it out over two days because I feared someone would offer more money and buy it out from under me and the dealership would just make up a reason to break the sale to me.
  29. May 8, 2020 at 10:49 AM
    ToyotaJim
    Oh, also, another detail, when I picked it up yesterday and these repairs were completed I talked again to the owner. I had briefly spoken to him in passing a few days ago at the dealership, small talk, being cordial. When I paid and picked up the truck yesterday he was there again and he mentioned the phone was ringing off the hook for interest in the truck. I'm shocked I got it and for the low price, actually. Kudos to his integrity and not hosting a bidding war and selling it out from under me.
  30. May 8, 2020 at 10:55 AM
    Hand Protectors
    Your black could look this good. :poking::D
    bmf4069 likes this.
