I'm going to order my parts. 5100.
Discussion in 'Suspension' started by Erick, May 8, 2018.
  1. May 8, 2018 at 11:19 PM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
  2. May 9, 2018 at 3:12 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    5100's are a good choice. I don't think your gonna need that kit. You should be able to reuse your top hat and bushings being you have a 16. 1" block is fine, though it's recommend to use a tapered block. If your off roading , then shackles would foot the bill. If your gonna set the front @ max height, as I mentioned in your tire post, you could move up to a 33" as long as you don't go with a wide tire. Post pics when you get it done. :thumbsup:
  3. May 9, 2018 at 5:05 AM
    Tundramoney
    Tundramoney Old school
    Earth
    No problems with 1” rear block and your new shocks. Stay away from shackles if you haul loads and use your truck as a truck.
    Backslider likes this.
  4. May 9, 2018 at 5:55 AM
    I have ToyTec shackles on my truck. I haul loads and use my truck as a truck with zero issues....Just sayin..
    rons23 likes this.
  5. May 9, 2018 at 5:56 AM
    Rica25
    Ricardo
    Tulare
    I have exact set up but you don't need that kit
    Black Wolf likes this.
  6. May 9, 2018 at 6:04 AM
    ToyotaTundraMike
    2015 Tundra
    Lolwut?
  7. May 9, 2018 at 7:29 AM
    Erick
    Erick
    Thornton Colorado.
    It's a work and fun truck I do remodels. I do use the heck out of my truck.
  8. May 9, 2018 at 9:23 AM
    Tundramoney
    Earth
  9. May 9, 2018 at 2:06 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    What spring would you need if you wanted to assemble 5100's and keep your stock coilovers intact? Does anybody sell just the factory spring or would you be money ahead and get 6112's?
  10. May 9, 2018 at 2:22 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I think that with the added cost of springs you would not be much less than 6112's assembled. Do you need to keep the stock shocks assembled? I did 5100's and the ride is better than stock so I would not go back.
  11. May 9, 2018 at 2:27 PM
    Rngr188
    Chad
    Harrison AR
    I don't really need the stocks assembled but thought it would be nice to have them around in case they would be needed for a quick swap. If I decide 6112's I will either buy them assembled or buy a top cap and assemble them myself.
  12. May 9, 2018 at 2:36 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Stock springs are 700lb and the 6112 springs are 650lb. If you are going to keep both I think the 6112's are a better option IMHO.
  13. May 9, 2018 at 5:30 PM
    Erick
    Erick
    Thornton Colorado.
    Order placed. Thanks boys.
  14. May 9, 2018 at 5:41 PM
    Erick
    Erick
    Thornton Colorado.
    Who does tundras recommend for 5100s? I ordered the on Amazon for 330 shipped.
  15. May 14, 2018 at 1:43 PM
    Rngr188
    Chad
    Harrison AR
    At the 1.71" middle setting and a .50" shim on each side totaling 2.21", would a bump stop extension kit and diff drop be necessary?
