I'm an idiot, I can't remove T10 dome bulbs in my 2006 Double Cab
Discussion in '1st Gen Tundras (2000-2006)' started by ktundra, Aug 27, 2020.
  1. Aug 27, 2020 at 12:56 PM
    ktundra
    ktundra [OP] rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    It's nearly impossible to get a grip on these tiny T10 bulbs.
    I've tried a trick someone showed on YouTube by using a zip tie to cinch on it, and pull it out but it still slips off. I've even tried to use silicone tubing that I managed to get onto the bulb, but it slips off. Arrgggh!!!!
    Has anyone been able to do this easily? There's a tool on Amazon for this, which I don't care to buy...
  2. Aug 27, 2020 at 1:10 PM
    Clearly, your truck is permanently broken. Please sign the title over to me as soon as possible and I'll, er, dispose of it in a slow, fun, friendly, slightly darker with one less bulb sort of way.
    bassman417, N84434, Pucks18 and 2 others like this.
  3. Aug 27, 2020 at 1:12 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Try putting masking tape on a needle nose. Make sure the tape is backwards where the sticky will be touching the bulb.
    ktundra[OP] and Hoff like this.
  4. Aug 27, 2020 at 2:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If I recall correctly, my 2004 DC has 2 map lights and 2 rear dome lights that were T10. If you are working on those locations, my suggestion after trying multiple suggestions is to take the unit/s completely down to remove bulb socket and all(eazy peezy). Slightly more time but some of us have that time along with a bucket of patience....YMMV !
    ktundra[OP] likes this.
  5. Aug 27, 2020 at 3:00 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    This is what I had to do also
    BubbaW[QUOTED] and ktundra[OP] like this.
  6. Aug 27, 2020 at 3:33 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    I would not be defeated.
    Grabbed some duct tape, wrapped it well around the bulb, then yanked straight down.
    Bam!
  7. Aug 27, 2020 at 4:08 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Oh boy. ... funny but not funny....
    ThatSR5Tundra likes this.
  8. Aug 27, 2020 at 4:35 PM
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    I did the same thing it came out with plain scotch tape once I wrapped it super easy
    ktundra[OP] and Tundra2 like this.
  9. Aug 27, 2020 at 6:24 PM
    You want to try another really fun one? Do the glovebox light.
    ThatSR5Tundra, Tundra2 and bmf4069 like this.
  10. Aug 28, 2020 at 8:05 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    or the mother of all mutha f’ers...the cigarette lighter. Have no fear PHM has you covered on his build page I believe !
  11. Aug 28, 2020 at 8:10 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Agreed, that is the most time consuming one!
  12. Aug 28, 2020 at 1:32 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Its real easy to take off those reflective backing covers and then you can pull the bulbs out to.
  13. Aug 28, 2020 at 11:59 PM
    bokch0y
    bokch0y I'm a sucker for DirtySOHC's
    Cig lighter one was the absolute worst!!! Glove box and ashtray ones were annoying, but more tedious than anything else. Cigarette lighter bulb was just straight up a nightmare.
    bmf4069 and Tundra2 like this.
  14. Aug 29, 2020 at 12:02 AM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    I used packing tape. Make sure bulb
    Isn’t hot. Roll it up like you’re about to pack a joint. Get it as far up the bulb as you can and seal the tape as much as possible and yank. Just like the duct tape guy. I just prefer packing tape.
  15. Sep 2, 2020 at 11:58 PM
    Desrat
    Desrat New Member
    AZ
    06 Double Cab RWD V8
    Did my dome/map/door lights tonight, and I found that needle nose pliers in conjunction with a microfiber cloth wrapped around the bulb worked good and didn't crack any of the bulbs. Just be gentle and wiggle it out.
  16. Aug 15, 2022 at 10:42 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Removing the T10 bulbs is no joke. lol. I didn't want to buy the tool on Amazon either. I watched a YouTube video on using tape around the bulb. I tried painters tape, electrical, and furnace duct tape with no luck. So finally I used to small zip ties with the tails opposite of one another and wiggled it out. Was a pain, but I got it done.
  17. Aug 15, 2022 at 11:05 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    I managed to crush mine with pliers, and then used a pick to get the bases out. I like the tape idea much better. :-/
    AZBoatHauler likes this.
  18. Aug 15, 2022 at 11:48 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I used the duct tape trick on my cargo light bulbs and it worked great.
