Illumination ring
Discussion in 'Lighting' started by lad2007, Jan 23, 2020.
  1. Jan 23, 2020 at 7:23 AM
    lad2007
    lad2007 [OP] New Member
    Ladonna
    2007 tundra sr5 reg cab 4x4 5.7
    Might be a stupid question but... I have a 07 tundra 5.7L 4x4 reg cab and recently it went from starting/driving fine to episodes of starting and then once stopped not starting again could leave it sit and then would start, now it does not crank, lights do come on. was told the ignition immobilizer was bad. the illumination ring is only half way lit up does that mean anything or just the led could have gone out? we are taking the key to get checked today to see if its bad. any other suggestions are greatly appreciated before I spend $400 on a new immobilizer. Thanks!!
  2. Jan 23, 2020 at 7:24 AM
  3. Jan 23, 2020 at 7:31 AM
    you need part #
    Toyota 89783-06021
    Simple 15 minute install max.
    @Roman could help you out with the part.
    My Install...should be the same just different part #'s
    Illuminated ignition ring
    Roman and lad2007[OP] like this.
  4. Jan 23, 2020 at 7:36 AM
    Welcome from NY, by the way.
  5. Jan 23, 2020 at 7:57 AM
    lad2007
    Ladonna
    Thanks!! Happy to be part of the group!
  6. Jan 23, 2020 at 8:00 AM
    lad2007
    Ladonna
    Im trying to get this immobilizer crap figured out. so with that illumination ring being half out does that mean that part is not functioning correctly and will keep the truck from starting? Or is the actual immobilizer unit possibly bad not just the light/antenna part? Ive been directed in so many different ways and the dealership is not wanting to offer up any info. A lock smith actually gave me more info than the dealership. Lock smith states that 9x out 10 the actual immobilizer is not bad. sound correct?
  7. Jan 23, 2020 at 8:32 AM
    If it's half out, maybe it's unplugged? I think the led is bad.
    Cheap fix is to replace it yourself.
