Illumination Buttons for Radio and Climate Control No Longer illuminate at Night
Discussion in '2.5 Gen Tundras (2014-2021)' started by kentran5397, Aug 28, 2018.
  1. Aug 28, 2018 at 4:24 PM
    kentran5397
    kentran5397 [OP] New Member
    Dallas. TX
    2014 Tundra 1794 Edition
    2019 Trd Pro LED Headlight 2019 1794 Grill LED Interior and Reverse Light LED Bedlight Vled Footwell LED Driver Side Grab Handle Bullet Fender Flares MX4 BakFlip Start X Remote Start Dual USB ports for the front and rear KO2 A/T Tires 275 60 R20 *Future Mods* TRD Rear Sway Bar Leveling Kit 38 gallon fuel tank swap
    Greetings fellow Tundra Owners,
    I have notice an issue with my 14' 1794 edition Tundra. The buttons for the radio and climate control no longer illuminate like they use to. The illumination for my speedometer still lights up at night and is dimmable using the dial, but the other buttons do not light up. My first instinct was to check the fuse, but when checking both fuse boxes I was not sure what this would be labeled under. Attached are some pictures that I have taken at night time. I have not done any electronics mods or upgrades to the truck.
  2. Aug 28, 2018 at 6:33 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Look for the park light fuse. If your truck has any aftermarket led lights I would remove those first.
  3. Aug 28, 2018 at 6:33 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Or tail fuse.
  4. Feb 5, 2019 at 5:52 PM
    mattcfelker
    mattcfelker New Member
    2018 White Tundra SR5 4x4
    4 inch Lift, 35X12.50R20, Black out Badges, LED head/fog lights, Husky Liner Mats
    Did you ever find a solution to this issue my 2018 is having the same?
  5. Feb 5, 2019 at 9:07 PM
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
    I took mine to the dealership due to a similar problem. They put a new fuse in at no charge.
    Been out of warranty a couple of years.
  6. Oct 15, 2019 at 4:13 PM
    kentran5397
    Dallas. TX
    I was finally able to resolve this issue! Turns out the @DallasTundra was correct ! It was a faulty fuse. When I initially checked it the fuse was good and not broken, but turns out the fuse itself was faulty causing the HVAC lights not to light up.
  7. Oct 15, 2019 at 6:05 PM
    DallasTundra
    Glad you got it fixed. My fuses looked okay at first glance also, but the technician found two faulty ones. I was holding my breath, till the service advisor said “no charge”.
