iJDMTOY fog lights
Discussion in 'Lighting' started by War Machine, Aug 13, 2018.
  1. Aug 13, 2018 at 5:27 AM
    War Machine
    War Machine [OP] SSEM # 5 3MW
    I bought these, just to check out:
    iJDMTOY (2) 24W High Power 3-Inch 2x3 LED Pod Lights w/Fog Lamp Location Mounting Brackets & Wiring Kit For 2014-up Toyota Tundra https://www.amazon.com/dp/B072FR1TPV/ref=cm_sw_r_cp_tai_DCxCBbHMA1F52
    There’s a mounting bracket which calls for mounting to the OEM holes in the bumper caps. There are no holes in mine, the OEM dogs just clip in. This is the second set of bumper caps I’ve had, since I got new ones powder coated. The old ones didn’t have holes either.
    I’m sending these back, but I was wondering if any of you have four screw holes in your bumper caps. There’s three reviews for them, and none mention not even being able to install them, so I’m confused.
  2. Aug 13, 2018 at 5:36 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I dont have any fog light mounting holes either.
    NewImprovedRon likes this.
  3. Aug 13, 2018 at 6:33 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    So I had these... There should be a backing plate with the 4 holes. The lights sandwich into the fog light hole. No such holes exist in the fog light housing.
    If my memory serves me right it goes front plate>bumper>back plate w/light>nuts
  4. Aug 13, 2018 at 6:34 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    They were pretty darn bright and silly easy to install.
  5. Aug 13, 2018 at 8:36 AM
    War Machine
    So the bumper is basically pinched between the two plates? Nothing attaches directly to it? I can see that, but the instructions called for it to be screwed to the OEM holes in the bumper.
  6. Aug 13, 2018 at 9:11 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Yeah exactly. It had locking washer and nuts on them. When I installed it, I used the blue loctite for sanity purposes.. Not sure I recall it stating to use the OEM holes on the bumper. Once I understood how to it secure in place I stopped reading :notsure:
  7. Aug 13, 2018 at 10:53 AM
    War Machine
    I’ll check it out before returning. Thanks.
  8. Aug 13, 2018 at 11:07 AM
    Pudge
    CT
    For what its worth I got morimoto LED fog lights and I like them. They are in that price range and can be had for less during group buys and even used.
  9. Aug 13, 2018 at 11:11 AM
  10. Aug 13, 2018 at 12:15 PM
    War Machine
    These were relatively cheap. Less than half of Baja. I just wanted to check out the distinct look. The Morimotos look pretty similar to stock, right?
    I honestly didn’t have high expectations for these. I just wanted to check them out.
  11. Aug 13, 2018 at 12:45 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Look up the rigid ones for instructions, there should be 3 plates, 1 plate goes behind the bumper, and 2 in front then the 4 bolts go through and sandwich together, in just took mine off last night, thinking of going a different route.
  12. Aug 13, 2018 at 1:35 PM
    Pudge
    CT
  13. Aug 13, 2018 at 1:38 PM
    Pudge
    CT
