Ihacker harness issues
Discussion in 'Lighting' started by woah62, Apr 27, 2019.
  1. Apr 27, 2019 at 3:05 PM
    woah62
    woah62 [OP] Resident Evil
    2017 Sunset Bronze Mica Tundra SR5
    So I’m having issues with my drls working. The headlights work fine but when I start my truck the drls do not come on. I disconnected and reconnected everything. Also I noticed I do not hear the relay harness power on. So I’m not sure if that’s the issue. Please help
  2. Apr 27, 2019 at 3:11 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  3. Apr 27, 2019 at 3:13 PM
    atxtundra
    atxtundra New Member
    Which harness?
  4. Apr 27, 2019 at 3:14 PM
    woah62
    The dimming one for 2019 trd headlights
  5. Apr 27, 2019 at 3:16 PM
    atxtundra
    I’m not 100% certain but I think you might need to Depin/cut the grey wire.
  6. Apr 27, 2019 at 3:17 PM
    woah62
    I depinned it and connected to relay harness like in instructions
  7. Apr 27, 2019 at 3:17 PM
    woah62
    It’s worked before but now it’s not
  8. Apr 27, 2019 at 3:27 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    I used the iHacker harness but for bright always. I connected it to the fuse box and no issues. Did you get this option? Check the fuse to ensure it’s not blown.
  9. Apr 27, 2019 at 3:29 PM
    woah62
    I have a different harness that uses a relay harness. I’ve checked the fuse on the relay harness and it’s fine
  10. Apr 27, 2019 at 3:37 PM
    atxtundra
    If it worked before and now it’s not, I would bet it’s a fuse or bad relay.
  11. Apr 27, 2019 at 3:41 PM
    woah62
    I traced it back to it starting after I upgraded the foot well light with an LED. I removed the new foot well bulb then reinstalled it and the DRLs are working now. Any ideas on how the new foot well lED light caused this? It is all working fine for now...
  12. Apr 27, 2019 at 3:48 PM
    Bheid
    Bheid It's not a toy, it's a Toyota.
    Doug
    Indiana
    2016 Black Tundra SR5
    Fab Fours Black Steel Elite front bumper Rhino Lined Bed Century Truck Cap Bridgestone KO2 tires K Source tow mirrors Blackvue Dashcam
    Polarity issue with the footwell bulb I'd guess.
  13. Apr 27, 2019 at 4:10 PM
    woah62
    Possibly. Just for troubleshooting I put the led bulb back in and everything still works. When I originally put the bulb in the polarity wasn’t right so I had to flip the bulb. After that is when it stopped. Strange
  14. Apr 27, 2019 at 5:06 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Hey make sure the firewall wire is tight and wire don’t slide off the plug, I had this issue over and over again when people inserted the metal pin into plug in the wrong side and don’t lock correctly in place so when you move the wire DRL might stop working
