Ignition cut when hitting bump. Potential worn ign or key?
Discussion in '2nd Gen Tundras (2007-2013)' started by Trident, Sep 23, 2024.
  1. Sep 23, 2024 at 6:20 AM
    Trident
    Trident [OP] New Member
    2007 Tundra DC 4X4
    My 2007 exhibited some wild behavior this weekend. 289k on the truck & the ignition or maybe moreso the key is worn to the point I can pull it out of the ignition with the truck running. Now during highway travel I've experienced the ignition cutting out after hitting bumps. Longest is about 1 second, then it's back up & running flawlessly. I say it's cutting the ignition b/c the lights never flicker, mileage still on the display, radio on, etc, etc. but the engine acts & sounds like you've turned the key off.
    Upon arriving back at home, I've taken my valet key (which still have sharp edges) and used it to start the truck. It will not pull out of the ignition (so I reckon the ignition cylinder isn't the culprit) & during a test drive down a city street that could be used as a rhythm section on an MX course it didn't miss a beat. Now I know 30mph bumps can't double as 70mph bumps but.......thoughts? Advice? I'm leaning towards the worn out key being the culprit.
    Edit: oh yeah, it's a dot key
    TIA
  2. Sep 23, 2024 at 6:30 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I'd check batt and ground connections to engine first.
    baraynavab and koditten like this.
  3. Sep 23, 2024 at 6:41 AM
    Trident
    2007 Tundra DC 4X4
    Rock solid with new OEM battery terminals installed less than a year ago.
    Again, the 12V isn't affected. During these instances, the mileage is still there, dash lights still there, radio still playing, etc.
  4. Sep 23, 2024 at 9:22 AM
    Johnsonman
    Austin
    Sequoia
    Right yet the ground for the engine is not the same ground as for all the interior stuff - just something to cross off the list. ECU ground tested?
  5. Sep 26, 2024 at 9:09 PM
    Trident
    2007 Tundra DC 4X4
    After 200+ driven miles, I'm ready to call this mystery solved. Using my valet key that's been used less than a handful times in the 7 years I've owned the truck, I've experienced no issues. I believe the original key in its worn state was the sole cause.
    2007 Tundra with 289k miles.
    On the left, original black Toyota key
    On the right, original grey valet (or sub) key
    baraynavab and Johnsonman like this.
