iForce Gauge
Discussion in '3rd Gen Tundras (2022+)' started by 22PlatWCP, Mar 29, 2022.
  1. Mar 29, 2022 at 11:38 AM
    22PlatWCP
    22PlatWCP [OP] New Member
    Mississippi
    2022 WCP Platinum 4x4
    Is the iForce gauge the boost gauge and if so, shouldn’t it be showing something when the accelerator is pressed? I’ve never seen any indication at all on mine.
  2. Mar 29, 2022 at 12:31 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    To clarify, you don't see the gauge move while in park or while driving?
  3. Mar 29, 2022 at 1:36 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    You have to pay the $8 monthly subscription fee to Toyota in order to unlock the iForce Boost Gauge. :spending:
  4. Mar 29, 2022 at 2:10 PM
    22PlatWCP
    Mississippi
    Not a bit…don’t see a needle, a bar, nothing moving…just a blank gauge.
  5. Mar 29, 2022 at 2:28 PM
    Breathing Borla
    Northern Illinois
    its the new software turbo fix TSB.
    just turn them off and you don't have to worry about it.
  6. Mar 29, 2022 at 2:46 PM
    tropro
    tropro New Member
    Troy
    MN
    2022 Blueprint Platinum
    Excelerate hard and boost should show. I don't see mine very oftern unless I get on the throttle. Also, via settings, you can change the right side of your screen to see boost, engine and tranny temp at the same time. There is a couple of different option to choose from. Pretty cool. :)
    22PlatWCP[QUOTED][OP] likes this.
  7. Mar 29, 2022 at 2:59 PM
    xc_tc
    xc_tc New Member
    There’s a bar that goes around the outside, should be gray. Maybe somehow boost signal isn’t being transmitted on the CAN bus? Try accelerating strongly on the highway, it should boost up.
  8. Mar 29, 2022 at 3:02 PM
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    You could always take it in for service and wait 2mos for the part to arrive…. Sorry,
  9. Mar 29, 2022 at 3:50 PM
    mass-hole
    mass-hole New Member
    It would only move if you are making manifold pressure greater than 14.7 psi absolute. Which is probably only if you get on the gas pretty good. Otherwise, under normal cruising conditions, you are probably at or just below 14.7.
    If it was a boost/vacuum gauge then it would be moving all the time.
  10. Mar 29, 2022 at 4:09 PM
    22PlatWCP
    Mississippi
    Thanks all, more than likely I’ve just been babying it too much to make it register.
  11. Mar 29, 2022 at 4:13 PM
    KroppDuster
    Bilstein 5100s
    Noticed you've got your truck in Comfort mode, so that's likely. Throw it in Sport mode and then get on the gas. I bet it'll register there. If you don't see it register on your boost gauge...then you'll DEFINITELY see it register in your gas gauge. haha.
  12. Mar 29, 2022 at 4:19 PM
    That little symbol is a turbo, so, yes, that is your boost gauge. If you are babying it and not getting into boost it won't move. If you get on it and it doesn't move then you might need to get the gauge looked at.
  13. Mar 29, 2022 at 5:00 PM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    so let me understand from this pic.
    Comfort (1) is for throttle response not suspension. So it is on easy does it.
    There is no (2) turbo involved and (3) its getting 14.3 mpg ?
    and its 81 degrees - wish I was there.
    Medic343 likes this.
  14. Mar 29, 2022 at 5:21 PM
    xc_tc
    xc_tc New Member
    Comfort = Normal
  15. Mar 29, 2022 at 5:27 PM
    Breathing Borla
    Northern Illinois
    I thought comfort was only the avs suspension setting
  16. Mar 29, 2022 at 5:35 PM
    22PlatWCP
    Mississippi
    The truck only has about 250 miles on it plus a lot of time spent sitting in the driver’s seat with the engine idling while I was reading the Owners Manual trying to figure out all the features and info screens. And we’re in south Mississippi so with that 81 degree temperature comes a lot of humidity.
  17. Mar 29, 2022 at 5:39 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    I'd much rather be in Southern Nevada too, 81 degrees.
    22PlatWCP[OP] likes this.
  18. Mar 29, 2022 at 5:44 PM
    Breathing Borla
    Northern Illinois
    I don’t give a shit about mpg , floor it and you should hear and feel the boost , if not take it into dealer and ask wtf
    Platinum_Tundra and Toyotoholic like this.
  19. Mar 30, 2022 at 12:09 PM
    22PlatWCP
    Mississippi
    Update…mine works! Took the truck out and gunned it…gray band started running around the meter. Kinda wish it was brighter and more noticeable…
  20. Mar 30, 2022 at 12:48 PM
    mass-hole
    think of it as an inverse mpg gauge. The higher the band, the lower the mpg.
    now ask yourself, do you really want to notice it?:rofl:
  21. Mar 30, 2022 at 12:51 PM
    KroppDuster
    Bilstein 5100s
    Totally had a brain fart. My eyes saw "Comfort" but my brain registered it as "Eco" mode. haha
  22. Mar 30, 2022 at 1:21 PM
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Result of this thread - All Gen 2 owners: wHaT aBoUt aLl ThE bOoSt GaUgE iSsUeS!?! nEvEr BuY tHe FiRsT yEaR!!!! :crapstorm:
  23. Mar 30, 2022 at 2:11 PM
    tropro
    tropro New Member
    Troy
    MN
    Try changing your right side guages to the bar style. You may like this better.
  24. Mar 30, 2022 at 2:44 PM
    22PlatWCP
    Mississippi
    I tried that but switched back…when I go back to towing I probably will so I can monitor the transmission temperature.
  25. Mar 30, 2022 at 2:59 PM
    tropro
    tropro New Member
    Troy
    MN
    Aswesome! Good idea!
