If You get a P0325 Code, or a Broken Wire on a Knock Sensor....
Discussion in '1st Gen Tundras (2000-2006)' started by Chuck W., Sep 7, 2019.
  1. Sep 7, 2019 at 10:42 AM
    Chuck W.
    Chuck W. [OP] New Member
    With any luck, someday someone will do a search and come across this thread and it will help them out.
    Short story is I got a check engine light with the code P0325: Knock Sensor Malfunction. I found that a rat(s) had made a nest under the intake manifold and chewed through the wire to the knock sensor.
    To get to the wire I followed the below instructions which are for changing the starter motor. The starter is in the same area under the intake manifold.
    http://www.someguyinnevada.com/toyota-tundra-starter-repair-a-journey-of-discovery
    Once I got to the chewed wire I found that it was chew right at the base. I needed a new plug with a pigtail. Toyota does not sell just a plug and pigtail; you have to buy a complete harness. However, searching the internet I found a part that would work. It was for a 1995 Toyota pick-up. It had the plug I need on one end and another plug at the other end. Toyota Part No. 82219-35010. It can be bought online for under $20.
    Its a pretty easy DIY.
  2. Sep 8, 2019 at 7:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, I had the same problem. I used the same web site, and bought the same harness. Problem is the harness. I couldn't find where it led back to so I had to cut and splice. This was actually one of my first problems fixed on my truck and first couple posts on this site.
    https://www.tundras.com/threads/is-it-worth-it-long-read.30954/
    Sas likes this.
  3. Sep 8, 2019 at 8:10 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  4. Aug 31, 2021 at 10:32 AM
    I'm resurrecting a zombie thread here solely because it got linked from another place. It looks like the website linked here has been throwing 500 Internal Server Errors since late 2019. You can find a copy of the text (minus images) in Wayback MAchine, here: https://web.archive.org/web/2019021...-tundra-starter-repair-a-journey-of-discovery
  5. Aug 31, 2021 at 11:07 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The attached pdf is the same article with images if anyone wishes to have a copy. If I told ya how I got it, I'd have to shoot ya :facepalm:
    Brad Majors and shifty`[QUOTED] like this.
