If it's not rail rust, what the 'H' is it?
Discussion in 'General Tundra Discussion' started by AxelsHumanDad, May 16, 2015.
  1. May 16, 2015 at 3:34 PM
    AxelsHumanDad
    AxelsHumanDad [OP] Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    I've read around about something called "rail rust" from the metal bits flinging up from the railroad wheels and landing on vehicle paint and then later rusting. There's too many variables in that idea for me to be convinced.
    However...
    My tuck is suddenly pitted with tiny rust specks all over. I bought the truck in October and the spotting just showed up last week. It's everywhere around the sides and back. It's even on the parts that were color matched after the truck was delivered to the dealership. It's also on the plastic flares and the plastic LED light panels below the headlights. All things that were done to the truck after the dealer took possession of it. This is what leads me to think it isn't rail rust. To further irritate the issue, I now see it in the sides of my company supplied vehicle, a white 2013 Chevy van. Same thing, all around the sides and back.
    What the heck is this coming from?
    Thoughts?
    ~Mike~
  2. May 16, 2015 at 3:51 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Just a guess but since its on your company vehicle as well, maybe its acid rain? Does it wash off?
  3. May 16, 2015 at 4:09 PM
    Mike Tread lightly.
    south carolina
    Im going to go on a thought here for a second. Do you like where the roads are salted or brine? If you do thats the salt eating the paint away digging into the paint all the way down to bare metal why washing every other day helps in those conditions. Also road salt is very acid ( depends on who the supplier is )
  4. May 16, 2015 at 4:18 PM
    AxelsHumanDad
    2015 CM Platinum
    It hasn't washed off. Using an after-wash detail spray doesn't take it off, nor does liquid polish used on airplanes.
    It is very salty around here during winter. Good thinking, but it's on the plastic parts too, there is no metal to rust. It is something that has hit the paint and then rusted.
    I have a nanoskin scrubbing sponge on the way. I've read about using clay bar to take it off, and the nanoskin giving similar results.
  5. May 16, 2015 at 4:29 PM
    mdavis
    Michael
    Rock Hill, SC
  6. May 16, 2015 at 5:01 PM
    Mike Tread lightly.
    south carolina
    I will give the guy credit good theory. i could see this.
  7. May 16, 2015 at 9:10 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would think that it would then be more prevalent on the front of the vehicle, just like rock chips.
  8. May 17, 2015 at 8:16 AM
    Hmmm...either way I would be using the wax like the guy in the video uses to get it off.
    Just a thought...if someone applied clear bra to the whole truck, could that prevent it?
    Can't say I've ever seen any rust spots on my truck....yet anyways.
  9. May 17, 2015 at 9:29 AM
    Mike Tread lightly.
    south carolina
    Sean. Im willing to bet you might have to wait till your humidity starts to go up there with the hot sun before this would happen I believe. Few good hot days I bet it will show up if it does.
    Way to prevent this might just be wax it and seal the paint every year or a clear bra like you said might do the trick.
  10. May 17, 2015 at 10:38 AM
    My last tundra I had for 2 years was white...no issues there. The member that bought it has it...don't think he has any issues either...maybe I'm just lucky? High hopes anyways haha.
  11. May 17, 2015 at 11:02 AM
    Mike Tread lightly.
    south carolina
    Could be where the op lives then they have high corrosive salt content.
  12. May 17, 2015 at 11:16 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    But OP says it's in the plastic as well...I'd like to have a look at it with a magnifying glass or jeweler's loupe...or some such.
  13. May 17, 2015 at 1:17 PM
    Mike Tread lightly.
    south carolina
    If the surface of the plastic is painted I have seen rust from the painted surface before.
  14. May 17, 2015 at 1:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Do you mean like metalflake paint where the corrosive gets embedded in the paint and the "flake" begins to rust? Or is metal flake not really metal? Shucks, I don't even know. heh
    Or might you mean where metal particulate gets embedded into the paint and rusts as it's exposed to a humid environment or whatever the heck is being used on the roads these days?
  15. May 17, 2015 at 2:19 PM
    Mike Tread lightly.
    south carolina
    Correct. metal no matter what the surface area is ( metal or plastic) will do a rust spot to it do to corrosion. If the metal say is cold for example the clear coat should be safe, but say it the metal particulate is HOT clear coat will burn with paint. That said if you have hot flakes for example your corrosion should increase faster do to oxidation then corrosive part of the metal. The metal would be bare so it can accept moisture do to its not painted surface and its exposure to elements in air. You can make rust form on bare plastic with shaving of metal for example leave it out watch what happens.
    The guy in the video i will give him credit, and a solved problem for paint, but not a permanent to keep it from do it again like the op might have again. Only thing i can think of ( off the top of my head here) say if it is brake pads / dust doing this, there are low dust pads you can buy to help this problem. More expensive pads they are but might be worth a try for the op.
    Metallic paint shouldnt be a rust helper so to speak in this case i believe IMO.
    T-Rex266 and Wynnded like this.
  16. May 17, 2015 at 2:42 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Thanks Mike.
    I don't know if I'm sold on this phenomena being metal material from the brake pads nor the disc rotors though. I would think that the "hot" flecks would have a much greater accumulated density as you get closer to the caliper and have a "spray pattern" on the exterior sheetmetal much like that of water or mud spray; I would think that the fender liner for example would have a "layer of rust" on it. Ah well, I haven't noticed it on my vehicle, but given time, someone will track down the origin.
  17. May 17, 2015 at 2:47 PM
    Mike Tread lightly.
    south carolina
    I not sold on it either ;) its very plausible.
    One thing fender wouldnt have rust the dust/metal ( in this case) goes with the WIND. fender is x feet higher than pads. more you get away from the pads more like you will get a spray effect on the truck. My theory on the brake part.
  18. May 25, 2015 at 2:03 PM
    So I found some of these "rust spots" while wiping the truck down today...they weren't mothballed to the eye unless u specifically lol for it like I did...took me around an hour to get as much as I could see off with Turtle wax on a rag.
    I found a few small spots on the tail-gate, so I'm not sure I am going with brake dust.
    While my truck is white, I bet this is on other vehicles of different colors too....just not sure if they are rust spots...
    Skeezo likes this.
  19. May 25, 2015 at 2:14 PM
    Mike Tread lightly.
    south carolina
    can you buff it off sean like in the video?
    Edit spelling police.
  20. May 25, 2015 at 3:42 PM
    Ya I just used some elbow grease and it's good to go. For having it just over a year, it wasn't too bad....just wondering how they get there.
  21. May 25, 2015 at 3:52 PM
    Mike Tread lightly.
    south carolina
    Looks like the (rail dust) or fall out is more plausible now.
  22. May 25, 2015 at 4:12 PM
    I bet this is on all vehicles....obviously only noticeable on white though is my guess. Im going to ask Toyota on my next service.
    Mike likes this.
  23. May 29, 2015 at 3:45 PM
    what the process like? Just throw some on a rag and clean it, or is like a real wax job that has to be done?
  24. May 29, 2015 at 8:22 PM
    AxelsHumanDad
    2015 CM Platinum
    I hosed down the sides of the truck, swabbed most of the water off with a drying towel, then sprayed the Iron-X on. Let it stand about 3 minutes(long enough that it doesn't dry on there), then wiped it down with a regular sponge. I did a couple panels at a time so the drying wouldn't get away from me. All but the bigger spots are gone. I'm hoping wiping down with the Nanoskin will resolve that.
    The purple showed up on the painted plastic and the chrome. The rust dots are everywhere...
  25. May 29, 2015 at 9:17 PM
    And the purple washes off easily from the plastic?
  26. May 30, 2015 at 3:44 AM
    AxelsHumanDad
    2015 CM Platinum
    I swabbed it all off before it dried, so I had no issues.
    T-Rex266 likes this.
  27. May 30, 2015 at 9:18 AM
    Link to where you got it? And how much did you have to use?
  28. May 30, 2015 at 10:09 AM
    AxelsHumanDad
    2015 CM Platinum
  29. Jun 2, 2015 at 7:34 AM
    TODDK
    TODDK New Member
    Todd
    Hibbs, PA
    2014 Tundra TRD
    6" lift sitting on 20x10x-24 wrapped with 35 MTs
    Did you or anyone do any grinding around your vehicle? Looks like that could be a culprit if its plausible.
  30. Jun 2, 2015 at 10:34 AM
    I have - front bumper and some stuff for the lift...but nothing on the rear where I had a few spots on the tail-gate..
