Idling the truck for extended periods
Discussion in 'General Tundra Discussion' started by Jackstraw, Aug 7, 2021.
  1. Aug 7, 2021 at 3:10 AM
    Jackstraw
    Jackstraw [OP] New Member
    2020 DC TRD Off Road
    Hey all, as a superintendent in residential construction it’s inevitable that I’m in my truck for much of the day driving the subdivision and getting in and out to check houses, make calls and work on my tablet. Often times the truck is idling with the AC or heater on. I’ve read this isn’t good for the engine but it’s pretty unavoidable. Is there anything I can do to offset the negatives? Change the oil more frequently or use an additive? Thanks in advance for any help.
  2. Aug 7, 2021 at 3:29 AM
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    I'll be interested in the experts answers here also...
    I've always heard it's bad for gas motors, diesels are fine for idle....bit I've never heard WHY...
    And does being in drive, but food on brake at idle matter...as in someone who lives in Los Angeles or DC or other heavy traffic areas, do their cars die faster?
  3. Aug 7, 2021 at 3:57 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I’ve always been told that if you’re idling for extended periods and / or in stop and go traffic frequently that you should go by engine hours and not miles for oil changes . For example : if you’re travelling at 60 mph it would take approximately 166 hours to reach 10,000 miles so you should look at changing your oil at around 166 hours of running time give or take .
  4. Aug 7, 2021 at 5:52 AM
    Jackstraw
    That’s good to know. Thanks.
    Lovetrucks[QUOTED] likes this.
  5. Aug 7, 2021 at 5:55 AM
    timsp8
    NY
    In my old job we had tahoes that would idle all day, sometimes well over 8 hours a day. We only did basic maintenance and oil changes at 5k. The engines never broke down. We’d keep them to anywhere between 36k to 60k before getting new truck. I’m sure it will damage longevity though beyond that. I’d never buy one of those trucks used.
    Jackstraw[OP] and YardBird like this.
  6. Aug 7, 2021 at 6:44 AM
    Diesels are not fine to idle. In fact, it's harmful to them. There is a high idle feature (raises idle to <1100 rpm) on all modern diesels for that reason alone. This is one of the reasons I do not recommend diesels to most people. In fact I just talked one of my best friends out of buying a F-350 PowerStroke and he went with the 7.3L gas motor.
    https://learndiesels.com/8-idle-facts/
  7. Aug 7, 2021 at 8:07 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Go by hrs, not miles for oil changes. I managed a fleet of 160 units and 60 of them were trucks of all makes that ran/idled for 24 hrs a day 7 days a week 4-6 months out of the year. It doesn't hurt them any more than driving does.
    Randy Morton and 2mchfun like this.
  8. Aug 7, 2021 at 8:12 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Install a engine hours meter, like the gradall
  9. Aug 7, 2021 at 8:15 AM
    timsp8
    NY
    The army idles HMMWVs and other vehicles for days, especially when it’s cold out. They use the jp-8, which I think is diesel.
    I know that’s probably different than commercial diesel vehicles in build and usage though.
  10. Aug 7, 2021 at 8:21 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    All commercial equipment have hours meter, that’s how the equipment rental company keep track of maintenance.
  11. Aug 7, 2021 at 8:38 AM
    Yes they do. Military diesel mechanics (we have one employed from the Army) also do a lot of maintenance on them. Besides GM, Gale Banks is the largest purchaser of Duramax motors due to having the military contracts. Cool little fact.
    Idling diesels came from the 1930-40's when they were very hard to start before glow plugs/heater grids.
  12. Aug 8, 2021 at 6:32 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    The department that I worked for was poor, We hot seated Ford 4.6 liter motors for months, I don't even think those those motors ever got shut off! Lol, They were turned into auction at 200k..
  13. Aug 8, 2021 at 9:00 AM
    Gray223
    Gray223 New Member
    2014 Tundra Double Cab Limited
    I always wonder why no one ever shuts them off when filling up....like it seems like a requirement to have your f250 running while filling up.
    Also I know that that it really inst that good to let it idle in the winter time to let it "warm up". Another thing transfering over from the carb days... Modern engines do not need to warm up and its best to just get in the and drive them, especially diesel since they take forever to warm up at idle.
    ...as I see that it is all mentioned in the link you posted. Very informative.
  14. Aug 8, 2021 at 9:23 AM
    In the winter, no more that 3 minutes for me for warm up. To be honest though, my truck is in the garage 24/7 and the coldest I have seen it was 56*F. Turn back/butt warmers on….good to go.
  15. Aug 8, 2021 at 9:25 AM
    2mchfun
    Change oil after 80 hrs of your idle and drive time combined. Don't forget your drivebelt, plugs, etc. will be due for replacement probably about 30% less than the recommendation on the mileage. So if plugs are due at 100,000 you should be changing them about 70,000.
    Jackstraw[OP] likes this.
  16. Aug 9, 2021 at 4:53 AM
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    This is something I’ve always like about small engines. Most dirt bike/lawnmower/boat motors go by hours which makes sense to me. Because as you eluded to someone who does a lot of city driving might only hit 2k miles in 150 hours but someone who does a majority of highway driving might hit 10k miles in 150 hours. Either way I think as long as your in a consistent oil change interval then you’ll be fine.
  17. Aug 9, 2021 at 5:21 AM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I wonder how the fuel injectors play into this paradigm and if using lower octane, more additive filled gas plays into the idling as described?
  18. Aug 9, 2021 at 5:55 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Ideally you'd measure by engine cycles with a load based factor, but hours is close enough. Miles is a convenience thing adopted by the passenger car market, why people say "all highway miles" means high miles = low hours. The manufacturer usually has asterisks for odd duty cycles like idling or towing heavy cases to reduce maintenance intervals from the typical grocery getter.
  19. Aug 9, 2021 at 7:09 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Good move. I’ve read a lot that the 7.3 gasser is a good substitute for a diesel. Certainly not the same power and torque, but also not the cost and maintenance of a diesel. I’d be curious what your friend thinks of the “Godzilla” motor.
  20. Aug 9, 2021 at 7:20 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Just change oil a little more often. Idling is about the lowest stress an engine sees. Shouldn’t affect longevity too much as long as it’s maintained well. I’d also verify often that the cooling system is full with no leaks and the fan clutch is in good working order.
    Jackstraw[OP], 2mchfun and YardBird like this.
  21. Aug 9, 2021 at 7:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    A buddy used to work in the maintenance yard for the state, trucks used to come in complaining of rough idle because of them sitting at the jobsites with the a/c blasting all day.
    They had cabinets full of Berrymans B12 Chemtool and would put a bottle in the tank and go out and beat the hell out of the truck and get it good and warm....this was back in 2005 so ymmv.
  22. Aug 9, 2021 at 8:24 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm not sure if it has been mentioned yet but I believe it says in the manual for our 1st gens that it's bad for the cat's to idle longer than 15 minutes.
  23. Aug 9, 2021 at 8:48 AM
    I got the opportunity to drive his truck and agree this is a great substitute for a diesel.
    The 7.3/10 speed/4:30 gears is a really good combo. Power/torque is smooth through the rpm range.
    Raven67 likes this.
  24. Aug 9, 2021 at 9:05 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’d worry more about heat buildup than changing the oil.
  25. Aug 9, 2021 at 9:38 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    How long do you think Cop cars idle?? Besides driving them all day long, they sit in many places filling out reports, etc. Taxi companies typically try to buy them up after, and drive them some more. Pretty sure regular oil changes will keep them going.
  26. Aug 9, 2021 at 9:45 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    The automatic high idle feature on a diesel was implemented to prevent wet stacking in the cylinders when operating in cold temperatures. Wet stacking is no longer an issue due to the use of grid heaters throughout the industry. The other reason for the high idle feature on a diesel engine is to run items such as a PTO. The modern diesels come with a circuit that you can actually wire a potentiometer into to vary the idle dependent on what is needed.
    On a side note, I don't know who that guy is on that website but he sure as shit is not a diesel mechanic. I owned diesels for over twenty years and I can pick apart most of what he listed.
  27. Aug 9, 2021 at 10:51 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm no expert, but I can chime in with my high mileage 5.7 has done long idles while I do store runs and other errands over the 15 years that I've owned it... my eldest is special needs and it's a gamble the times I'm able to take him in a store, so usually.. he stays with mom in the truck at idle with the AC or heat on..... I've only followed routine maintenance and haven't followed hourly maintenance periods, nor logged any... engine has no issues with the exception of not liking summer heat anymore, lol..... it is said idling can age an engine to twice the amount of miles... this guy breaks it down on a newer Chevy Caprice PPV engine.
    Edit: 14 years, my bad it's an 07.. lol
    https://youtu.be/XBAoaBj7trI
    YardBird and Jackstraw[OP] like this.
  28. Aug 9, 2021 at 11:06 AM
    2mchfun
    One of the best things a person in this situation could do is to swap the fan over to dual electric fans for maximum cooling. Kinda a bit of work though and I would probably use geographic location as a guide to determine the benefits.
  29. Aug 9, 2021 at 11:25 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    My work 2018 Tahoe with the 5.3 runs for up to 16 hours some times, has about 55k miles on it, i just take it to fleet for basic / routine maintenance and it hasn't had any issues.
    YardBird likes this.
  30. Aug 9, 2021 at 12:55 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I used to idle my Titan for about an hour every work day, on top of the driving. After the warranty expired I started doing oil changes at 10k miles with high quality synthetics (Royal Purple or Mobil1) and a Purolator high end oil filter. I sold it at 235k miles to a coworker, who is still driving it at 250k+.
