Idle time
Discussion in 'General Tundra Discussion' started by C-tundra, Sep 9, 2016.
  1. Sep 9, 2016 at 3:44 PM
    C-tundra
    C-tundra [OP] New Member
    I've owned ford's the past 28 year's always liked toyota though, so i bought one a month or so ago, is it normal for the engine to idle high for 5 min before dropping below 1000 rpm on cold start up
    Law323 likes this.
  2. Sep 9, 2016 at 3:47 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Hasn't happened to me on my 2016. Usually takes 30" to 1' in the AM.
  3. Sep 9, 2016 at 4:49 PM
    Mike Tread lightly.
    south carolina
    Most engines idle high. Reason is so you can get the cats up to temperature faster..
    Alot depends on outside temperature also. If cooler it runs higher and warmer not so high...
    If you have a cold weather package on the truck it's designed in the ECM to run higher rpm on start up... my Tacoma and tundra both have cold weather packages and both run on high side before going to normal idle rpm.
    T-Rex266, Law323 and NewImprovedRon like this.
  4. Sep 9, 2016 at 5:35 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    It's normal for them to idle high but not for 5 mins. Might just have the cold weather package?
