Idle time...
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXRailRoadBandit73, Jun 23, 2016.
  1. Jun 23, 2016 at 2:07 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Any one ever let ther engine idle for long period of time? With a/c running? Are the engines built like a semi rig? lol was at work today from 830am to 330pm slept in back with a/c running that ok on truck?
  2. Jun 23, 2016 at 2:14 PM
    Mike Tread lightly.
    south carolina
    Not really... the oil pressure is low on idle coolant is not flowing fast enough (transfer).. if you could keep it at 1500 rpms it would help.
    I remember if I can find it I will post it but for every hour a engine idles it's like 10,000 highway miles on a gasoline engine.
    If we had diesel engines it doesn't matter(they are designed that way).. gasoline engines aren't..
  3. Jun 23, 2016 at 3:53 PM
    Well we are group didn't do much today and it was super hot n muggy so I sat n back slept with truck running and a/c on medium speed was wondering if that was good on engine
  4. Jun 23, 2016 at 4:39 PM
    Mike Tread lightly.
    south carolina
    Honestly for 7 hours of idle .. no..
  5. Jun 23, 2016 at 4:40 PM
    I've heard both sides to this. I've heard u should start up and just go. I've heard you should let it settle for 45 seconds then go ...the discussion came up for winter / summer seasons ref cooling the car down or heating it up
  6. Jun 23, 2016 at 4:52 PM
    What I did was nap in truck for a long time with a/c running from 830am to 330pm jus wondering if bad on engine
  7. Jun 23, 2016 at 4:56 PM
    Mike Tread lightly.
    south carolina
    Today's modern engines don't need warming up to do the advance ecm of today's cars and trucks.. the ecm is able to calculate and do the math fast. Soon as oil pressure is reached go.
    cooling down is only used with engines that have turbo chargers(reason: so the bearings in the turbo charger cool down from the oil, from high speed rpms, this also applies to diesel also)
  8. Jun 23, 2016 at 9:31 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    You're good bro. I've heard arguments from both sides too; oil pressure, temperature, thermostat, etc. Tundras have a check valve in the oil system to keep the pressure stable and IMHO idling is easiest on the engine.
    I had a work buddy who swore that idling the engine for a good 5 minutes before driving was the best thing since sliced bread. There must be something to it b/c he had a 15 yr old Ford station wagon with over 250k miles on it.
  9. Jun 24, 2016 at 7:27 AM
    Motel 6
    NewImprovedRon likes this.
  10. Jun 24, 2016 at 7:59 AM
    Mike Tread lightly.
    south carolina
    They leave the light on for ya too...lol
    Black Wolf[QUOTED] and T-Rex266 like this.
  11. Jun 24, 2016 at 8:51 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Damn you just put 70,000 miles on your truck in one day!!!! Personally, I would never idle a car for more than like 15 minutes. Without air running through the engine, it gets really hot in there. Especially if it was hot enough that you needed AC.
  12. Jun 24, 2016 at 9:00 AM
    Nor7
    Dang, I can't imagine why they don't put a device in the engine compartment to pull air across the radiator. WHY TOYOTA!?!?! WHY!?!?!?
    Fearthisbeard, jlee and 15whtrd like this.
  13. Jun 24, 2016 at 9:15 AM
    Mike Tread lightly.
    south carolina
    It's just Toyota it's all.. gasoline engines are not designed that way to idle for long periods.
    One thing guys gasoline is a very very dirty fuel.. it leaves carbon and everything else behind when not burned at temperature.. idle is just that.. idle it just enough to keep engine going but not enough to properly burn fuel in turn it leaves deposits behind..
    I remember I couple years back on a GM truck that was idled alot. Reason came in for a miss fire and when we put a camera down in the pistons it needed a tare down from all the carbon.. even the sleeves where damaged..
  14. Jun 24, 2016 at 9:41 AM
    Nor7
    If you guys are worried about heat, you need to re-watch this commercial.
  15. Jun 24, 2016 at 11:44 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    BEDBUGS!
  16. Jun 24, 2016 at 11:51 AM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I have idled for extensive periods of time and my oil pressure and temp gauges have never ever moved even a fraction. SAME temp and pressure as at any higher RPM.
  17. Jun 24, 2016 at 12:08 PM
    Mike Tread lightly.
    south carolina
    Notice at the end they are spray it with water?
  18. Jun 24, 2016 at 12:32 PM
    95° yesterday n with heat index 105° no clouds or shade and very very humid half work group sitting ther vehicles doing same
  19. Jun 24, 2016 at 5:38 PM
    Nor7
    Yeah, search for the 'behind the scenes' version of that video. It was done with no camera tricks or animations, they sprayed it down for the safety of the stunt driver. Pretty intense, and also true for all the other commercials they did. My favorite was this one.
    driverdog and jlee like this.
