Idle reset/reprogram.
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, Nov 15, 2018.
  1. Nov 15, 2018 at 7:52 AM
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
    I cleaned my TB last night and, predictably, the idle is now high. What's the sequence to reset/reprogram the idle? I've read I can disconnect the battery, which I'd rather not do, or I've seen a bunch of different brake and ignition sequences to follow but, none I've read are specific to a 1st Gen, so here I am asking the proper people. What's the sequence? Thanks for any help that can be provided.
  2. Nov 15, 2018 at 9:06 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It will self heal, drive around a bit. A lot of people think the battery needs to be reset for anything, these computers are smart enough to adjust.
  3. Nov 15, 2018 at 4:03 PM
    Professional Hand Model
    Hand Protectors
    Yeah buddy. Like Darkness says it should self heal. I’d reset the battery for grins if it was mine. 10mm wrench takes about 30 seconds.
    Did you tighten up that throttle cable while in there? Mine had some play from the cable stretch of 15 years. Tighten it about 1/4”. Big difference!
    FrenchToasty and theblurry1 like this.
  4. Nov 15, 2018 at 4:10 PM
    Baller
    '05 Tundra SR5 DC
    Unless I'm mistaken, there's no throttle cable. I've got an '05 and I'm pretty sure it's fly by wire. I'll admit, and my wife can testify, that I'm unable to find or notice something in the fridge or pantry but, I think I would have noticed a throttle cable last night when I had the TB off.
  5. Nov 15, 2018 at 8:18 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    03 and newer are drive by wire, previous models had a cable.
    Funny things will upset the idle temporarily. When I removed my K&N kit and went back to stock my idle was high while parked. When I drove around the block it got so low at stop signs that it stalled. Started up again and drove more, was normal a few blocks later.
  6. May 18, 2021 at 5:13 PM
    TOMMYTOYOTA89
    TOMMYTOYOTA89 New Member
    Thomas
    2005 Toyota Tundra SR5 AC V8 4.7
    I know this post is from 2018, but I’m new to this page and hoping someone can answer my question. I did a TB cleaning last night and not sure if my problem is a bad TB or it needs to re learn. My vehicle idles fine, between 500 and 1. When I put it in D or R it accelerates on its own, to about 3mph. Thoughts? Haven’t been successful with any re learn procedures yet.
  7. May 18, 2021 at 7:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Normal. Press the brakes harder.
  8. May 19, 2021 at 5:13 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    When you say it accelerates on its own, is it lunging when you put it gear, or just idling off when you let off the brake?
  9. May 19, 2021 at 5:22 AM
    TOMMYTOYOTA89
    Thomas
    To me it feels like it’s slightly lunging off, but no increase in RPMs. Maybe I’m just getting used to a V8... I can put it in reverse and truck will back into my driveway on its own with no gas from me. I have a somewhat steep driveway and it’s all rock, so not just an easy surface to move up on. Maybe it’s nothing, not sure. TIA for any help on this.
  10. May 19, 2021 at 1:27 PM
    TOMMYTOYOTA89
    Thomas
    Idling off when I release the brake
