Idle gas usage
Discussion in 'General Tundra Discussion' started by Tracker, Feb 2, 2017.
  1. Feb 2, 2017 at 8:27 PM
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    So I wanted to discuss the prolonged idle usage of cars in general also in relation to our trucks. I am working some job sites where I use my own car parked for about 8 hours. During the cold and hot weather it will be running the whole time. I have a Pontiac G6 that does well gas wise but my truck is so much more comfortable. I assume the V-8 will suck more gas at idle than a V-6 anyways. Dang lack of active fuel management in the Tundras! So you guys think there's really a significant difference in vehicles burning gas at idle? And what about wear and tear at idle?
  2. Feb 2, 2017 at 8:44 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    interested to hear comments on this.
  3. Feb 2, 2017 at 8:49 PM
    You're going to get pro and con opinions here.
    I've let my truck idle for long periods in traffic, or in extreme cold / snowy winters while I shovel the driveway.
    I didn't monitor the mpg on it during that time...but you know where the habits of leaving cars idling come from ;)
    There are a ton of guys that have 300k+ and have let their truck idle for 15+ minutes- parked.
    Some will say you're killing the life of the engine letting it idle for 8-12 hours...others (articles support both parties) will say the opposite.
    Personally I plan on getting another remote start (after market) and start it and not worry about it if needed.
    joonbug and Tracker[OP] like this.
  4. Feb 2, 2017 at 8:49 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would never idle any of my cars for even an hour... let alone 8 hours. :confused: Especially when it's hot.
    ColoradoTJ likes this.
  5. Feb 2, 2017 at 8:59 PM
    Tracker
    Shane
    Well when its 25 degrees out and I'm sitting in it its gonna need to keep me warm. If you look at police cars they sit at idle for majority of their life time. Usually on a scene or waiting for the speeder. Maintained the crown Vic's converted into taxis have lived in the 300k mile range before.
    T-Rex266 and joonbug[QUOTED] like this.
  6. Feb 2, 2017 at 9:03 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah I meant unless you're in 25 degrees weather. :)
  7. Feb 2, 2017 at 9:11 PM
    Your transmission might hate you. I would keep a close eye on that temperature, especially if in park.
    When stating up my current truck, after 8 minutes of idle time, the Allison temp is at 150-165*. That might not sound like it is high and it isn't until I tell you where it is at towing 9k at 65-73 mph.
    100-134* is the max I have seen it towing and working hard.
    Point of this, the trans can get hot. Sometimes placing the transmission in neutral with the parking brake on can help.
    joonbug likes this.
  8. Feb 2, 2017 at 11:09 PM
    Tracker
    Shane
    Interesting, I never knew a trans in park doing nothing could get that hot. I wonder why it does. Anyone else seen that as well?
  9. Feb 3, 2017 at 3:02 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    I wouldn't worry about the transmission it is bolted to the engine so heat transfers to it, it doesn't generate heat sitting still. Of course you will be causing wear to the engine since it's running but it's not working so wear will be minimal.if you do let it idle a lot on a regular basis just change your oil more often and don't worry about it.
    Y0TA PR0 likes this.
  10. Feb 3, 2017 at 7:45 AM
    I think it depends a lot on where you live and what you are doing at the time. In AK during the winter, if working at a outdoor job site, sometimes you are waiting around for long periods. I've seen trucks both gas and diesel left running idle for hours. Got to stay warm.
  11. Feb 3, 2017 at 7:51 AM
    Really? A transmission doesn't generate heat sitting still?
    tomsinamerica likes this.
  12. Feb 3, 2017 at 8:04 AM
    I would have to ask a transmission tech to see how the valve body is set up on the Tundra transmissions. This will determine how hot and how quick they heat up.
    For instance, Dodge transmissions in park would get very hot in Park. The valve body didn't allow for much flow and would spin the torque converter out of fluid and cause excessive heat. The fix to this was this:
    -If idling for extended periods, put vehicle's parking brake on, place transmission in Neutral. This would give adequate flow and cooling to not self destruct.
    -Change or modify the factory valve body in transmission, and even then, a good idea to idle in Neutral.
    Our old work truck was a 2003 Dodge 1500. This poor truck had a lot of extended idle time. It was sent off to auction at 50K miles last year. We had installed 3 sets of injectors, one factory automatic transmission and and one transmission that was supposed to handle more abuse. We were on the third one at 45K miles. The motor was the smallest 4.7L V-8. Power was not tearing these transmissions up. It couldn't pull a greased up rope out of a goats ass.
    My advice, would be to find a scan gauge II and monitor how things are. Toyota makes good products, and the transmissions are very good from my experience. If you do see an elevated temps, try the Neutral and parking brake option.
    joonbug likes this.
  13. Feb 3, 2017 at 8:29 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would definitely not run a car at idle for any length of time in the heat to keep an AC on. That I'm sure will hurt your engine. Running the heater in extreme cold is a little better but I would still try to avoid doing that on a regular basis. I would get a small generator and a tiny heater before running my truck just for heat. The problem with people saying it's ok, is how the hell does someone prove it's ok? Are they measuring wear on all the components? There are people saying warming up your car for a few minutes in the cold is bad, how the hell can idling for hours be ok? It's just something difficult to prove either way so I would rather be safe than sorry. Especially with my truck.
  14. Feb 3, 2017 at 8:53 AM
  15. Feb 3, 2017 at 9:42 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I have a very hard time believing that idling your truck for 8 hours is harmful to the truck other than the wear on the moving components.
    You have a transmission warning indicator that will illuminate if the transmission temperature is out of line. You have a coolant temp gage that will tell you when and if you truck is getting too hot.
    I also have a very hard time believing that the fuel consumption will be all that high at idle. I would guess about 40% more than your G6. The load of the accessories will be about the same. The internal engine friction will be higher as well as the volume of air pumped. I bet you could idle all day for less than a gallon of fuel.
    The Dodge transmission that was referenced earlier has been well noted for being a very bad design.
  16. Feb 3, 2017 at 11:25 AM
    The Allison transmission was designed in the 70's and has been in production since the mid 80's, and it gets warm sitting at idle. Like stated earlier, it gets hotter than anytime I have towed.
    Will the transmission cook itself over night? No. It is just gradually wearing the transmission prematurely.
    Hell, not sure why I even discuss this stuff. I learn from others misfortunes, and apply it to what I do.
  17. Feb 3, 2017 at 12:16 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    We both discuss these things because is it just not in our nature to let it sit. It is a curse :eek:)
    Personally I would have a hard time leaving my car/truck idling all day long. I am way too Dutch for that as well as my desire to minimize cycles on the engine and everything else would override.
    That being said I know a lot of people who do it all the time. I work with a guy who never shuts his car off in the winter. He lets it idle in the parking lot all day because he hate scraping snow and getting in a cold car. His current car has nearly 200k on the odometer (Toyota Camry). He also argues that a cold start causes more wear than running the car all day long.
  18. Feb 3, 2017 at 12:56 PM
    Tracker
    Shane
    We discuss it because thats how we learn and tell others we heard it on the internet :rofl:I never heard of that so now its on my mind and appreciated. I would think it would only put premature wear on the fluid and not the tranny itself. Some more researching might be in order.
  19. Feb 3, 2017 at 1:01 PM
    Most people keep their vehicles for 4-6 years max. I doubt you would see the long standing results of doing the extended idle problems.
