Identifying fasteners by part number
Discussion in '1st Gen Tundras (2000-2006)' started by Desrat, Sep 20, 2020.
  1. Sep 20, 2020 at 9:08 AM
    Desrat
    Desrat [OP] New Member
    AZ
    06 Double Cab RWD V8
    I took this "skid plate"/splash guard off a loooooong time ago and, what do you know, I lost the fasteners.
    Is there any way to get the details (e.g. M8x1.25x30) for these fasteners by just using these part #s shown in the diagram?
    I showed these pictures to the parts department at my local dealer and they said they couldn't find out. Pretty lame. I would really like to go to Ace/Home Depot and pick up the stuff today instead of waiting 2 weeks, if possible.
  2. Sep 20, 2020 at 9:40 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I didn’t read through the whole thread, but this might help you.
    https://www.tacomaworld.com/threads/stock-skid-plate-bolt-size.572942/
  3. Sep 20, 2020 at 9:43 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    They may have been superseded by the current bolts... I'd advise to call ahead to make sure, then order them online...
  4. Sep 20, 2020 at 5:55 PM
    If you can circle the specific fasteners you need, I believe I can find them. If not, you may want to ping @Roman
    1lowlife and Desrat[OP] like this.
  5. Sep 20, 2020 at 7:09 PM
    Desrat
    AZ
    Thanks, but no worries, I went and tried a few combos to find the right one. For anyone who may stumble across this, 5x M8x1.25x20 was what worked for me. I was really most interested in finding out if it was possible to get part details such as thread pitch and length from the part numbers.
    Was a bit tough to get them in, probably due to some contamination or galling of the female threads, but they're in there now...
  6. Sep 23, 2020 at 4:20 PM
    Professional Hand Model
    Hand Protectors
    Just ordered 5 of these (90080-11373) bolts with washers for my front skid. They cost about .90c each from stealership. Should be delivered in 2 days.
  7. Sep 23, 2020 at 8:11 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    A tap would have cleaned the threads up, and made it a little easier to drive the bolts in. Glad you were able to get them in, though
  8. Sep 24, 2020 at 5:28 AM
    Hand Protectors
    My plan today is run one of my good bolts up in there first with some grease. A pre-game before the new bolts go in. Tapped one out yesterday and have 2 more today.
  9. Sep 24, 2020 at 6:05 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    This happened on my Land Cruiser (which has 8 or 10 bolts!). I drilled and tapped, bought new bolts, and then applied generous amounts of anti seize before reinstalling. I drop the pan from time to time, and it's been ~ 5 yrs or more...the bolts always slide right out :)
  10. Sep 24, 2020 at 8:39 AM
    NEXT
    NEXT New Member
    2006 Tundra crew cab SR%
    None
    Can anyone tell me what bolts go on the bottom of the fender flares?
  11. Sep 24, 2020 at 2:05 PM
    Hand Protectors
    Go to your local stealership (or any online stealer) and plug in your VIN# and then start a search. You’ll be empowered by this.
