Ideas to add light switches
Discussion in 'Lighting' started by kcaustin66, Feb 10, 2018.
  1. Feb 10, 2018 at 9:32 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    any good ideas for putting additional light switches all the factory spots are being used. would like to add bull bar with light strip and ditch lights.
    dcsleeper408 likes this.
  2. Feb 10, 2018 at 9:56 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Since you have a 2015 I would get the brake controller bezel and plate that section off to add some switches.
    I am going to be doing this for my mic holder and maybe engine kill.
  3. Feb 10, 2018 at 10:05 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
  4. Feb 10, 2018 at 10:41 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  5. Feb 10, 2018 at 11:36 PM
    kcaustin66
    kevin
    Found this on Amazon think I might get it and see if I can mount it below the Tow/Haul button and then cut out the plastic with a dremel tool so the rectangular switches will fit then it will look more factory because later I might want to use the Brake Controller setup on the other side.
    dcsleeper408[QUOTED] likes this.
  6. Feb 11, 2018 at 12:06 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    This is what I'm using. The brake controller is still hooked up, stuffed behind the dash and zip tied in place. It's far from perfect but since these lights are only for offroad I can live with the imperfections.
    newguy209, 1UPPER, boardude and 3 others like this.
  7. Feb 11, 2018 at 2:40 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Black Wolf, 1UPPER, J4RR3N4 and 2 others like this.
  8. Feb 11, 2018 at 10:01 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Bookmarking that! Wireless can come in handy. :thumbsup:
  9. Feb 11, 2018 at 10:20 AM
    Berdine
    Binghamton, NY
    It's about the size of a garage door opener. It's nice cause where I live there are no street lights. So I can turn my leds on until we get inside and turn them off. Or in the morning when leaving for work.
    NewImprovedRon likes this.
  10. Feb 11, 2018 at 1:10 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Lots of great ideas listed above. Here is what I did for my switches. I ordered my switch plate mounts and custom switches from OTRATTW . IMG_8995.jpg
    SDHQ does offer a custom switch pros mount for the Tundra. Very clean install!
  11. Feb 11, 2018 at 1:29 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    What was the easiest way to pull that panel with the cup holder out?
    831Tun and Berdine like this.
  12. Feb 11, 2018 at 1:37 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I have the same but put it near the shifter. It's my ghetto pros
  13. Feb 11, 2018 at 2:13 PM
    1UPPER
    TEXAS
    Flux capacitor!
    The interior instrument panel is super easy to pull out. The whole process takes a few minutes to do. Great time to vacuum all the stuff that falls behind the shifter knob too. Lol
    1. Remove the shifter knob first by unscrewing counter clockwise.
    2. Lift center counsole lid up.
    3. The whole center console is held on by plastic clips. So you want to pry up the section under the center console lid first. IMG_4839.jpg
    That's all there is to it. The center trim pc around the shifter is also removable from the whole center insert.
  14. Feb 11, 2018 at 2:20 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Dang all you guys are so crafty. :bowdown: I always did simple stuff like drill a hole in the dash with a toggle switch. And it would look plain and blah. Lol. :D
    Black Wolf and 1UPPER like this.
  15. Feb 11, 2018 at 2:24 PM
    Berdine
    Binghamton, NY
    I just bought some new rocker switches, was thinking of going this route.
  16. Feb 11, 2018 at 2:29 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Go to https://otrattw.net/ if you want to have a very clean switch mount setup, custom switches, lettering and anything else switch related. I just saw they have a newer cleaner switch mount now that recesses the switches. IMG_2351.jpg
  17. Feb 11, 2018 at 2:52 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Sweet thanks for all the photos brotha! Helps it a lot! :thumbsup:
    1UPPER[QUOTED] likes this.
  18. Feb 11, 2018 at 3:17 PM
    Berdine
    Binghamton, NY
    Those are really nice
  19. Feb 11, 2018 at 5:23 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    Same as a few posted here but I needed the use of the trailer brake so it's behind my shifter. Its been there for atleast 100k now.
    Berdine and 831Tun like this.
  20. Feb 11, 2019 at 9:46 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    What option did you use for the switch plate and housing to the left of the USB / AUX spot?
  21. Feb 11, 2019 at 10:04 AM
    1UPPER
    TEXAS
    Flux capacitor!
    The red switches I believe you're talking about are part of the NSV Lightbar. That isn’t sold separately.
