ICS FAB dash mount for gen 2s
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Jan 15, 2021.
  1. Jan 15, 2021 at 8:38 AM
    TheBeast [OP] The Beach
    vq35721, JDimaggio4x2, Skew12 and 3 others like this.
  2. Jan 15, 2021 at 1:14 PM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    Looks good, but it seems like if anything was bolted to the top it would block the clock and info screen...
  3. Jan 15, 2021 at 3:25 PM
    I hear you but seeing how limited the info screen is on the gen 2 I can live with it :)
    I ordered one. We'll see how that goes ;)
    RepeatPete[QUOTED] likes this.
  4. Jan 15, 2021 at 5:39 PM
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    I actually have one of these sitting on the shelf awaiting install. I’ve been debating what I want to mount to it and how it will all sit together. So far I’m thinking a midland radio, garmin in reach mount, and possibly a iPad mount.
    RepeatPete and TheBeast[OP] like this.
  5. Jan 16, 2021 at 11:59 AM
  6. May 1, 2024 at 2:35 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Did y'all end up getting them mounted? If so, how much "bouncing" or vibration passes through the plate? I have a phone and ipad mount screwed into the speaker grill that would normally be there, and my phone mount (bulletpoint) bounces up and down even on concrete. Looking for a solution to at least stop some of the bouncing
  7. May 7, 2024 at 7:48 PM
    yep. good to go. I have a 67 mount for phone and camera on it and it's not budging.
    joseph_womack[QUOTED] likes this.
  8. May 7, 2024 at 8:39 PM
    joseph_womack
    Joe
    Louisiana
    This seems to be the consensus from everyone who has it, ordering tonight, thank you for the input!
  9. May 8, 2024 at 4:28 AM
    Tundra1D6
    Don’t forget 07 and 08’s have dash board flexing issues. Notice when you go over a bump on these glorious La roads if the center section of the dash bounces.
  10. May 8, 2024 at 7:58 AM
    joseph_womack
    Joe
    Louisiana
    oof, yep they are quite terrible, I didn't know that was a generation problem. Yes the center of my dash definitely flexes, I always just thought it was the mounts I had on it; do you know if there is any solution to it?
    Do you know of any threads on this? I couldn't find any
  11. May 8, 2024 at 9:04 AM
    Tundra1D6
    Yes and no, they do have threads about it on the “other” tundra site. Look up sinking dash. That’s how I found out about the 07-08’s with this problem. My front A-pillars wouldn’t lineup properly no matter what I did to adjust them. I suppose you might be able to add some sort of strapping under the dash that runs side to side for support but at the end of the day is it worth the work?
    I’d like to get the same mount system but that’s a hefty price for a phone holder.
  12. May 8, 2024 at 9:51 AM
    joseph_womack
    Joe
    Louisiana
    Yeah I didn’t want to justify it at first, but if it holds my phone mount and iPad mount when I go wheeling and at least doesn’t shake the phone up and down as bad, then I’d say it’s worth it. It also keeps me from having to buy a new speaker grill for right there since I drilled a couple holes in it
  13. May 14, 2024 at 6:52 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    This looks good, but how hard is the installation?
    I don't understand why you have to remove the radio and parts of the front dash.
  14. May 14, 2024 at 8:43 PM
    joseph_womack
    Joe
    Louisiana
    I just installed mine this past weekend; install wasn't that difficult, I've removed my radio a couple times. There are plenty of YT videos on it. You have to remove the radio because the dash plate bolts through the dash, it doesn't just screw into the dash from the top side
    myt1[QUOTED] likes this.
  15. May 20, 2024 at 4:53 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    Thanks.
    I ordered mine and I should get it any day now.
    I watched some YouTube videos, and I thought I would give it a whack.
  16. May 20, 2024 at 4:54 PM
    joseph_womack
    Joe
    Louisiana
    I couldn’t quite find any YouTube videos worth watching (on installing the mount itself), but if you have some questions shoot them my way
  17. May 25, 2024 at 5:13 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    I just did the install as well.
    The below video is not specifically for the ICS mount, but it shows how to remove the pieces of the dash.
    Unlike most YouTube videos, this one is actually pretty accurate and it is as easy as they make it look; although I still managed to break one clip.
    Between the video and the written instructions on the ICS website, no instructions are provided in the box, it's pretty easy to figure out how it all fits together.
    I wanted all my screws to match, so in addition to ordering the mount, I ordered two sets of 1" screws to mount my 2 1/2" Ram ball mounts.
    1" screws were recommended, but depending on the location you want to mount the ball, they may be too long. I had to shorten one of the screws with a hacksaw.
    Also, the screws didn't fit in the holes of the Ram mounts, and I had to enlarge the holes with a drill, no big deal, just surprising.
    The product itself is rock solid and I can't imagine it will give me any issues.
    I am very satisfied.
    P.S. I found it super helpful to have an extended length 10mm socket to fit over the long screws in the back of the mount. I can't believe I actually had one.
    DirectFit Phone Mount Installation - 2007-2013 Toyota Tundra
    joseph_womack likes this.
