ICS FAB 2014+ Dash Mount- ram mount compatible
Discussion in '2.5 Gen Tundras (2014-2021)' started by L3TT3RS, Jan 23, 2019.
  1. Jan 23, 2019 at 3:37 PM
    L3TT3RS
    L3TT3RS [OP] New Member
    Taylor
    19 Tundra
    Fox/Total Chaos/Coachbuilder
    I've been looking for quite some time for a solution to allow me to run my Galaxy tab 3 as my gps for offorad navigation. I recently found ICS FAB on Instagram thanks in part to @4lobound ( I know you're on here but cant remember your username). And this seems to be the solution to what Ihave been looking for.
    First, the review of the product, followed by detailed install instructions with pics.
    **I paid for this product so that I could give an honest review of the product without any obligation to the company. **
    ICS asked me for feedback as soon as I got the product and the only feedback I offered at the time was that I would have preferred a lesser price @ $75ish bucks vs the $90sh I paid when ordering. He promptly responded that he had in fact reduced his price to that point.
    For those that dont want to keep reading that are looking for a way to be able to mount anything you can think of to your central dash, stop looking for other products and go buy this.
    here is the link to purchase
    https://www.ics-fab.com/products/tundra-amps-dash-mount
    Ill do my review using a 10/10 point scoring system with 10 being best possible or exceeds expectations. 10's in my book are hard to achieve.
    The Following criteria will be reviewed
    1)Ease of ordering
    2)Communication with company
    3)Speed of Shipping
    4)Packaging
    5)Quality of product out of box
    6)Fit of product into designated location
    7)Level of difficulty of install- scored differently with 1 being no install necessary to 10 being specialized tools and fab skills necessary
    8) Final Thoughts
    1) Ease of Ordering-
    10/10- vendors website is easy to use
    2)Communication with Company-
    9/10- After my order was placed I got an immediate email generated by the vendors website, I will say I likely had a little better communication with the vendor than your average Joe as he and I had been talking about the product and possible future products via Instagram Messenger for about a month. This being said, I would say that "average Joe" would receive more than adequate communication status post order placement.
    3)Speed of shipping-
    9/10- only way it could have exceeded my expectation is if it had been overnight shipped to me, which is unreasonable. After order, I received shipping notice the following morning and shipped that same day( order placed after business hours.)
    4) Packaging-
    10/10- This came in a USPS small flat rate box that was well taped with ICS FAB personalized tape. The mount was then wrapped with bubble wrap followed by a plastic bag with the hardware inside in an individual bag. Excellent packing. Below are pictures of the packaging as well as what is included in your order.IMG_20190118_145844.jpg
    5)Quality of Product out of box-
    10/10- I don't see any flaws to the overall design, the cuts are smooth and professional looking. The coating on the mount is top notch, just the right texture.
    6)Fit of Product into designated Location-
    8/10- This product is slightly smaller than the space in the dash it is designed to fill, I would have preferred it to be slightly larger and take up all of the space of the "cubby"(is that what its called?) With this being said, the end user is able to move the mount slightly front to back and side to side. This is being picky as the product comes with a template for install that allows the customer to ensure proper fitment. See install instructions.
    7) Level of difficulty of install- scored differently with 1 being no install necessary to 10 being specialized tools and fab skills necessary
    This gets a 4/10 because I did not have a set of automotive trim tools and needed them for this install, otherwise, this is as straight forward as it gets. You'll be able to see in the install section where I attempted to remove the panels with a flat head and scuffed the plastic a bit. Not a worry for me, as you cant see it when put back together, but I would highly recommend the trim tools.
    8)Final Thoughts-
    This is an excellent product that gets top marks in my opinion, it is the perfect solution to my needs and I anticipate that this up and coming company will be producing more innovative and useful products for us Tundra owners in the future.
    See next post for install instructions. Ill get it posted tonight after we get the kids in bed.
  2. Jan 23, 2019 at 3:37 PM
    L3TT3RS
    Taylor
    19 Tundra
    Tools needed for install:
    1. 6mm Allen
    2. 10mm Socket
    3. Long extension
    4. Ratchet
    5. Trim removal tools
    6. 1/8" Drill bit
    7. 1/4" Drill bit
    8. Drill
    9. Center Punch
    1)remove the lowest portion of the dash using a trim removal tool, patience is key here.
    Insert tool and work it across the top of the panel, prying up on the back end of the tool top pop the panel loose
    Once you do this, there will be electrical connections to remove to completely disengage this pannel. at this time, I chose to replace my cigarette lighter receptacles with dual 2.1 amp USB receptacle port. There are may options out there, but I wanted dual 2.1 amp and no l e d light. there are only a couple options out there I could find and all were more expensive than this.
    see link-https://www.amazon.com/gp/product/B07CJW3ZRP/ref=ppx_yo_dt_b_asin_title_o03__o00_s01?
    There is a write up on this forum describing how to do this.< i did have to enlarge the holes to get the usb ports to fit.>
    Once this panel is removed, you place your hand beneath the a controls and gently pull free.
    As seen here, there is one electrical connection to the back of the ac panel. I chose to remove this to give me a little more room to work. This does have the connection for the passenger air bag so do so at your own risk. I had zero issues. YMMV.
    Next, you will remove the 4(four) 10 mm bolts holding the radio in place.
    You can see the two front bolts here, to the outside of these are the other two, you will need a long extension to reach these. Once the bolts are removed, you will have to place your hand under the radio and pull out, you will fill like you're going to break something before the radio lets loose from the tabs at the top. After removal of the radio, there is one connection at the top driver side of the rear of the radio, black wire with white connector( its the smallest one) I temporarily removed this connection to lay the radio into the passenger side. On my truck, this was the only connection I removed to give me enough slack. I do not think this is necessary in hindsight, but it did give me more room to work. Alas, I forgot to take a picture of this step, hopefully the description is enough for you.
    Next, I triple measured the distance from side to side of the mount itself sitting on the dash and placed the template according to my measurements. The positioning of the mount can be moved based on the end users discretion, I chose to mount as far back as possible and centered from side to side.
    Template taped in place-
    Unable to locate a center punch, I filed down a 3 inch wood screw and poked holes in the screw holes seen above, I tapped the screw with the palm of my hand to make the locations to drill.
    Next up is 1/8" drill bit for a pilot hole followed by the 1/4" bit for the final hole. < i didnt get a pic of the 1/4" holes, imagine these a little larger.
    From here, you place the supplied bolts with allen heads into the mount itself and align to all the holes you just drilled. On the inside of the dash goes the fender washer followed by the locking nut. inset the 6 mm allen into the top of the bolt to keep it from spinning and use the 10mm socket/ratchet wrench to turn the lockinng nut until tight.
    *** pro tip*** install whatever ball and or acessories you plan to use prior to tightening down your Dash Mount... makes it a lot easier, however, accessories can be installed after mount install completed.
    Once bolts are tightened, youre done. reverse the order of dis assembly and put everything back the way you found it.
    Attachments for tablet- specifically a Samsung Galaxy Tab 3 I used the following...
    https://www.amazon.com/gp/product/B008S4JNYO/ref=ppx_yo_dt_b_asin_title_o02__o00_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B0085MDF52/ref=ppx_yo_dt_b_asin_title_o03__o00_s01?ie=UTF8&psc=1
    Do yourself a favor and go ahead and buy the pan head screws and nylock nuts so you don't have to order a pack of 100 like I did.
    **disclaimer, this is the process i used for install, should you choose to follow my steps, I accept zero liability if there is damage or injury that is incurred due to this guide. please take all measures for safety and use this as a tool at your own risk.**
    Njmike13 and Sas like this.
  3. Jan 23, 2019 at 3:57 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
  4. Jan 23, 2019 at 4:01 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Their website should have a picture of this mounted...
    Sas and Quicktan66 like this.
  5. Jan 23, 2019 at 4:07 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Been following them on IG for a while,
    Currently they are doing a giveaway
    WolfPac_Outdoors and Major like this.
  6. Jan 23, 2019 at 4:09 PM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    Waiting for a pic so I know what it’s for...
    Quicktan66 likes this.
  7. Jan 23, 2019 at 4:21 PM
    L3TT3RS
    Taylor
    19 Tundra
    Until I can get the rest of the write up done you can take a look at the website listed in the first post for detailed pics of the mount or see their Instagram
  8. Jan 23, 2019 at 4:24 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  9. Jan 23, 2019 at 4:47 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    From what I've seen, it's used to mount devices like iPads, etc about the radio for Nav and the such...I'd image a phone could be mounted with this as well.
  10. Jan 23, 2019 at 4:49 PM
    dandailey
    Dan D
    Newport News Va.
    Not a fan of drilling into my dash..
    easleycrawler and Major like this.
  11. Jan 23, 2019 at 4:49 PM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    Sub'd for pics. This is hands down one of the best product reviews I've ever read.
    Tundyfundy, Sunnier and L3TT3RS[OP] like this.
  12. Jan 23, 2019 at 4:52 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Handy I guess.
    Drilling into my dash.
  13. Jan 23, 2019 at 4:55 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    5.7TRDProm and L3TT3RS[OP] like this.
  14. Jan 23, 2019 at 5:08 PM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Pretty cool.
    You can mount CB radio
    Pro-Yota likes this.
  15. Jan 23, 2019 at 5:08 PM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    TRD15559, WolfPac_Outdoors and Sas like this.
  16. Jan 23, 2019 at 5:10 PM
    Sas
    OKC, OK
  17. Jan 23, 2019 at 5:20 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  18. Jan 23, 2019 at 5:39 PM
    L3TT3RS
    Taylor
    19 Tundra
    seems like this wont be for you sir.
  19. Jan 23, 2019 at 5:42 PM
    L3TT3RS
    Taylor
    19 Tundra
    Updated with install instructions.
    You can install anything to this mount that uses the amps mounting solutions.
    Here is everything installed with tablet in place before re-assembly of dash.IMG_20190118_160113.jpg
  20. Jan 23, 2019 at 5:42 PM
    L3TT3RS
    Taylor
    19 Tundra
    see install.
  21. Jan 23, 2019 at 5:43 PM
    Sas
    OKC, OK
    That's a big blind spot.
    Datenney, porkitt and Major like this.
  22. Jan 23, 2019 at 5:44 PM
    Sas
    OKC, OK
    Nice write-up
    WolfPac_Outdoors likes this.
  23. Jan 23, 2019 at 5:50 PM
    L3TT3RS
    Taylor
    19 Tundra
    Here are some stock photos Istole from Alex and Isaac over @ ICS FAB
    IMG_7669_1024x1024@2x.jpg IMG_7657_1024x1024@2x.jpg IMG_7670_1024x1024@2x.jpg IMG_7718_1024x1024@2x.jpg IMG_7719_1024x1024@2x.jpg
  24. Jan 23, 2019 at 5:53 PM
    L3TT3RS
    Taylor
    19 Tundra
    thank you
    The arm I used would be the one you need, just move the ball mount to the forward most position on the ICS mount.
    I've also got this one layed in a manner in which it will rest just above the radio.
  25. Jan 23, 2019 at 5:58 PM
    L3TT3RS
    Taylor
    19 Tundra
    I was standing beside the truck when I took this. At this height, it covers part of the hood, but does not stick up any further in my line of sight... the good thing though, its infinitely adjustable due to the ram balls at both ends, so I can move it if someone shorter is driving..
    Major and Sas[QUOTED] like this.
  26. Jan 23, 2019 at 6:00 PM
    L3TT3RS
    Taylor
    19 Tundra
    once I got it all installed I grabbed it with both hands ans shook the entire truck with zero deflection trying to test strength. i was more than impressed. 10/10 on strength
    WolfPac_Outdoors[QUOTED] and Sas like this.
  27. Jan 23, 2019 at 6:01 PM
    Phishindude
    Phishindude New Member
    Pretty serious mount!
  28. Jan 23, 2019 at 6:07 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Darn nice find. I have always thought that spot on the dash was totally wasted space and useless.
  29. Jan 23, 2019 at 6:45 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I use that spot to hold my chipotle burritos quite often!
    OP, great write up!! I may look at this versus the Tesla screen option
    Midsouth Jacket, Sas and L3TT3RS[OP] like this.
  30. Feb 15, 2019 at 3:36 PM
    coTony
    Tony
    Montrose, CO
    Went to order and the free shipping was no longer available. Bummer, that to me was the deal breaker
