Nevermind :)
Discussion in '3rd Gen Tundra Parts Marketplace (2022+)' started by PapaDave418, Oct 31, 2024.
Thread Status:
Not open for further replies.
  1. Oct 31, 2024 at 6:30 PM
    PapaDave418
    PapaDave418 [OP] A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    This is for a 3rd Gen Tundra to drop the sway bar for a 2.25” lift and more. Never installed as I have an RCI skid plate that would interfere it turns out. Super simple to install.
    $50 shipped
    ICON 2022-2024 TOYOTA TUNDRA/2023-2024 TOYOTA SEQUOIA, FRONT SWAY BAR DROP KIT
    The 2022-2024 Toyota Tundra/2023-2024 Sequoia Sway Bar Drop kit features CNC machined 6061 aluminum sway bar brackets that drop the truck’s sway bar slightly lower on the frame in order to reduce bind in the OE sway bar links. These sway bar drop brackets are required for front lift heights above 2.25” over stock but are recommended for any amount of front lift to minimize sway bar link bind through the suspension travel range. This helps the suspension move more freely and allows for the full range of wheel travel without over stressing any OE components.
  2. Nov 21, 2024 at 5:00 PM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    2023 white tundra 1794 TRD
    Hey just an fyi you can run them with rci skids. Just gotta add larger spacers and bolts
    PapaDave418[OP] likes this.
  3. Nov 21, 2024 at 7:06 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Did you do it? I figured spacers would help but the holes mid-way down the skids would have their angle changed a little and at the time I didn’t bother, but curious if you did it and the length of stand offs?
  4. Nov 21, 2024 at 7:58 PM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    I just ordered parts today after test fitting with spare parts in the tool chest. (4)M8x1.25x50 and (4) 1 inch aluminum spacers. I have the transmission skid as well but you can reuse those bolts. So spacers and longer bolts up front.
    Keeps it about a cm or so gap from sway bar. Keeps similar geometry since skids already come with spacers, just added longer ones to accommodate the drop brackets. I bolted the middle first, rear then front.
    Parts come in Saturday from Amazon so I can add pics.
    what lift you install?
  5. Nov 21, 2024 at 8:26 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Currently Westcott Designs
    Kona_boy likes this.
  6. Nov 21, 2024 at 9:06 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Let me know how it goes, I might do that as well
  7. Nov 22, 2024 at 4:12 PM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    All bolted up. I ended up using 1” spacers in the front and the washers included in the kit for the middle. I did it in reverse, front bolts rear then middle. Otherwise the rear bolts wouldn’t line up. Got about a cm clearance. I don’t do hardcore wheeling so it’s good enough and helps with oil changes haha
  8. Nov 22, 2024 at 5:39 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Awesome nice work!
Thread Status:
