Icon Suspension help
Discussion in 'Suspension' started by Justin14Cmax, Sep 18, 2017.
  1. Sep 18, 2017 at 9:57 AM
    Justin14Cmax
    Justin14Cmax [OP] New Member
    Justin
    2014 SR5 crew max 4x4
    Pro Comp phaser wheels 35” Toyo Open Country R/T Nfab MRDS front bumper K&N intake Black widow muffler BDS spacer/block kit Future plans: Icon Stage 5 suspension Tubular UCA's w/ delta joints Rigid light bar and pods Go Rhino running boards Lots of little details....
    Questions, yes many questions regarding Icon 2.0 vs. 2.5 series for 14 Tundra crewmax. I've got spacers and blocks now, but have decided it's time to be an adult and get serious about the suspension. Unfortunately, no deserts to run here in MD, but we do have public beaches where I fish, and mountain trails to crawl. I'm looking to go versatile here. I'd like some more travel overall and I get it w/ Icon. Their reviews are solid and products seem top shelf. Plan is tubular UCAs w/ delta joints. I'm entertaining either Stage 2 w/ the 2.0 coilovers and shocks, or stage 5 w/ the 2.5's (bigger, beefy, + ext. reservoirs) both kits have the add a leaf pack. What's everyone's experience been with these? Solid setup, money is better spent elsewhere? Cost is a concern and it'll be sweat labor putting them in. Feedback is really appreciated!
  2. Sep 18, 2017 at 10:00 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    If you're not bombing deserts, there's no real reason to go with the stage 5 kit for performance reasons -- the stage 2 will be just fine for the needs you mentioned. That said, ICONs are a great choice despite the cost and I'm running remote reservoirs on 2.5s up front myself along with Omega bypasses in the rear.
    Black Wolf and TheBeast like this.
  3. Sep 18, 2017 at 10:14 AM
    Justin14Cmax
    Justin
    Appreciate some truth! Sales guys know how to get right to my core, they tell me bigger is always better :) I'm simple, so of course I love their pitch. Thanks for the experienced advice. Any noticeable difference in ride over stock? I thought ride would get a little chunky with spacers/blocks, but it's still smooth.
    4x4_Angel likes this.
  4. Sep 18, 2017 at 10:25 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    @Hattori is a big fan of the expansion pack, that's the route I'm going with mine as well.
    Hattori likes this.
  5. Sep 18, 2017 at 10:49 AM
    Cfincke
    San Antonio
    You may want to look at the Stage 3 setup, it has 2.5" rear shocks - larger fluid capacity than the stage 2 rear shocks and larger shock shaft
    I did a modified version of the Icon Stage 3 setup - 2.5" coil-overs, 2.5" rear shocks, Icon upper control arms, and Toytec rear shackles
  6. Sep 18, 2017 at 11:08 AM
    TheBeast The Beach
    check also toytec lifts for options that don't break the bank
    smslavin likes this.
  7. Sep 18, 2017 at 11:42 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Hard to go wrong with a stage 5 set up. de22b80f678e9b2fc0afa86f476c9742_290b13e01ce7551844df4dae05697f7748526a41.jpg54672d0482389ebf233e766790d33413_f56ab8079b9baa2917267fdf5bdca4d2ff27dc49.jpg
    Noodle and Theonlyway like this.
  8. Sep 18, 2017 at 11:52 AM
    Justin14Cmax
    Justin
    "Just when I thought I was out, they pull me back in..." over the KO2's looks great! I'm on 31" KO2's now and will be stepping up to 33" in another 10K miles or so. Great visual though gives me a really good perspective. Looks like the tubular UCA's, did you do the delta joint? Primary concern is that in MD we salt the shit out of the road, and the corrosion on a uniball would be hell. I feel like I'd be on constant upkeep with the uni set up.
  9. Sep 18, 2017 at 1:24 PM
    Omohundro
    Jody
    McMinnville TN
    I have the uni set up. It was very stiff steering in the beginning but it's all good now. They make a cover for the top to keep junk out. fad77b1b90fe74c41b6f3e89eccb7443_ff8872f65d7b61ebbb80e81bf5f2dd09efa35f59.jpg
  10. Sep 18, 2017 at 1:32 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Did you put in their leaf pack yet?
  11. Sep 18, 2017 at 2:03 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @Omohundro im in the same boat as you. My choices are icon stage 2 or 2 or go with toytec radflos. I know icons have 1.5" more travel than stock which sounds more appealing. I can't find any information if boss or radflos have any more travel than stock. I don't bash my truck but want the best ride possible.
    Please keep us updated with which method you go with and how you like the outcome.
  12. Sep 18, 2017 at 2:18 PM
    Omohundro
    Jody
    McMinnville TN
    I put the leaf packs in, and then removed them. The ride was very stiff, hindsight I should have drove it for awhile.
  13. Sep 18, 2017 at 2:27 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I've NEVER installed a set of Icon leafs and the customer not like them. One of the best aftermarket leaf spring solutions outside of a custom pack. I sell them every chance I get! I'd run em if i weren't trying to catch air everywhere I go! :mudding:
    Flyinryank likes this.
  14. Sep 18, 2017 at 2:38 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Icon does not make 2.0 coilovers, so just keep in mind no matter what Icon stage you do, you will be improving the front end. Tailor the kit to you needs currently and what you plan on doing. Far too many people tailor what they buy to what can scrape them by and they end up regretting it.
    Theonlyway likes this.
  15. Sep 18, 2017 at 2:39 PM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I like mine. Perfect amout of extra height too
  16. Sep 18, 2017 at 2:54 PM
    Omohundro
    Jody
    McMinnville TN
    I have thought about trying them agin, but it was a drastic change in ride. I took a few coworkers on a ride and they all said the same thing. It was way stiff in the rear.
  17. Sep 18, 2017 at 3:05 PM
    Justin14Cmax
    Justin
    Yeah, up front the 2.5's no doubt are going to be everything I need. I'm seeing some fade now in my OE leaf springs and the 2" blocks. That's what has gotten me seeking a more solid solution.
  18. Sep 18, 2017 at 7:24 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Or.... you can go with the stage 7 and upgrade to the 3.0 coilovers. I'm thinking this is my plan. Because reasons............
  19. Sep 18, 2017 at 7:44 PM
    Justin14Cmax
    Justin
    Hah! See, and that's how it happens. A community of enablers! If only my wife reasoned like this...
