Icon RXT Tundra Leaf System
Discussion in 'ICON Vehicle Dynamics' started by Icon_Adrian, Feb 26, 2018.
  1. Feb 26, 2018 at 2:31 PM
    Icon_Adrian
    Icon_Adrian [OP] New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    RXT Rear Suspension Systems
    The 2007-2017 Toyota Tundra is a very capable and versatile truck with features that make it suitable for use as everything from daily driver, to tow rig, to adventure vehicle and everything in between. From the brutal deserts of the Southwest to the wooded trails of the East coast ICON suspension systems have been put to the test and performed flawlessly for this popular Toyota. Over the span of hundreds of hours in the shop and over a thousand miles in the dirt, ICON Vehicle Dynamics’ engineers have pushed this vehicle to extremes in order to develop the most sophisticated suspension components on the market. Unable to leave “well-enough” alone, ICON is aiming to raise the bar in Tundra performance with the introduction of the RXT Rear Suspension System.
    Through an accelerated testing process dubbed the “ICON1K” R&D program, ICON has spent over a year pushing the Tundra to off-road extremes to identify limiting factors in OE components and further extrapolate performance out of this vehicle. In a push to provide unparalleled ride quality and vehicle dynamics for everything from high-speed desert running to off the grid expedition, the RXT Rear Suspension System was born. The RXT Rear Suspension System is a combination of an all new ICON multi-rate leaf spring, a hydraulic rear bump stop kit, and three RXT-specific 2.5 Series rear shock options. Installation of this system replaces the aforementioned “limiting factors” and completely redefines the potential of the 2007-2017 Toyota Tundra with a 20% increase in wheel travel and the ability to adjust the leaf spring rate to compensate for varying vehicle setups.
    ICON RXT Multi-Rate Leaf Spring
    The backbone of the Tundra RXT Rear Suspension System is a user-adjustable multi-rate leaf pack that offers a major performance gain for almost every accessory & gear setup imaginable. Features like tip inserts and leaf separators reduce friction and increase ride comfort, while a military wrapped front eyelet improves the durability and strength of the leaf spring. To increase the ride quality of the truck and gain additional droop travel, the spring rate has been lowered slightly. While many Tundra owners will embrace this, there are those who have outfitted their trucks with a significant amount of weight in the form of a bed rack, roof top tent, spare tires, parts, or other additions. Taking this into consideration, the leaf pack was designed with an additional leaf (included with kit) that can be exchanged or added to the pack yielding an additional 15% or 25% in spring rate that will handle more "outfitted" vehicles.
    ICON RXT Rear Shocks
    To compliment the RXT Multi-Rate Leaf Spring, three new ICON shock options have been developed to control the suspension throughout this new range of travel. These include a 2.5 Series remote reservoir shock, a 2.5 Series CDC Valve shock, and a two-tube Omega bypass option – each of which provides unique levels of performance to the rear end of the Tundra. The increase in wheel travel was answered with a unique side-mount eyelet approach that allowed ICON engineers to develop a shock that is shorter in collapsed length, longer at extension, and still fits in the factory mounting location. A large ten inch remote reservoir was added to aid in heat dissipation and resist shock fade during spirited driving.
    http://iconvehicledynamics.com/shop/720-rxt-rear-suspension-systems
  2. Feb 26, 2018 at 3:20 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    there has been some discussion about leaf options for the tundras lately.i have read alot of talk about the leafs going flat or sagging. i know when i had my last f350 i had your 7" leafs and you guys had a no sag guarantee. is this something that passes over to these springs?
    i know alot of people are interested in off road performance but i am very interested in how this set up is for on road comfort. my truck spends most of its time on the hwy or city streets. with two kids that travel with me all the time how is the ride comfort?
    thanks
    TheBeast and Theonlyway like this.
  3. Apr 23, 2018 at 10:07 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    @Icon_Adrian
    Where can I get some new center pins for the RXT packs?
    will these fit?
    Icon_Adrian[OP] likes this.
  4. Apr 23, 2018 at 11:34 AM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    will the rxt leaf packs reduce/eliminate double cab bed bounce?
    speckmon and dcsleeper408 like this.
  5. Apr 23, 2018 at 11:39 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    @joonbug has it on his DC. Set at factory setting from IVD
    joonbug likes this.
  6. Apr 23, 2018 at 12:23 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I personally don't think anything completely eliminates really bad bed bounce. I think mine got reduced a bit with the Icons but that's with the rear bypasses and set all the way to soft. I think it's more the shocks than the leafs though.
    Kerch71, TheBeast and dcsleeper408 like this.
  7. Apr 23, 2018 at 2:41 PM
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    The RXT Leaf Systems come with spare set of center pins. If you are sourcing additional pins they are standard, mas-manufactured pins. As long as the pin mentioned is long enough and the correct diameter it will work as a replacement.
  8. Apr 23, 2018 at 2:56 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Thanks! Picked up a few sets from Josh @Wheeler's Off-Road Inc
  9. Jun 10, 2019 at 7:20 PM
    Hartc90
    Hartc90 New Member
    2015 Toyota Tundra Crewmax
    I have a 2015 Toyota Tundra crewmax. Hey anyone else with a rxt leaf pack option 2 found that when driving off the line your truck has a slight vibration? I’m just trying to figure it out. It’s more annoying more than anything.
    Thanks!
  10. Jun 10, 2019 at 7:33 PM
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    I just installed mine this weekend on option 2 and I have the same thing happening.
  11. Jun 10, 2019 at 7:41 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Doesn’t lifting the rear change pinion angle? Doesn’t matter if you do leaf spring lift, shackles or blocks.
  12. Jun 10, 2019 at 8:33 PM
    Hartc90
    Hartc90 New Member
    I’ll call a local shop here and ask them, get back tomorrow hopefully with an answer
  13. Jun 10, 2019 at 8:47 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I just bought a set of RXTs, should be here any day now. Planning on option 2 to compensate for my habitat and gear, should get me back to stock or a little more. Won’t be able to get them installed for a couple weeks.
  14. Jun 11, 2019 at 2:03 PM
    Hartc90
    Hartc90 New Member
    So I left a voicemail for my local shop but spoke with coachbuilder1 and about 5 hours of research, looks like the solution is a carrier drop kid that coachbuiler sells and it’s a freaking great deal. I ordered both just in case but I’m gonna install the 2” carrier drop kit first and see what happens. I also spoke with coach builder who is very resourceful. His number is ‭(801) 635-4872‬. Give him a call with questions
  15. Jun 11, 2019 at 2:23 PM
    JDL17CM4x4
    JDL17CM4x4 Adventure Mobile
    Daniel
    Riverside, CA
    2017 White Tundra TRD 4x4
    More to Come ...
    You and @Hartc90 might want to look into a Carrier Bearing drop kit. I hear this helps with the vibration you get from a stop to about 10 MPH.
    Hartc90 likes this.
  16. Jun 11, 2019 at 2:24 PM
    JDL17CM4x4
    Daniel
    Riverside, CA
    More to Come ...
    Well looks like my reply was 20 minutes too late. Happy you found it. Ignore my last reply. LOL
  17. Jun 11, 2019 at 4:49 PM
    Hartc90
    Hartc90 New Member
    Nah your fine! Thank you for the help. I’m praying once installed, I have no more vibrations.
    JDL17CM4x4 likes this.
  18. Jun 21, 2019 at 8:45 PM
    shellshock
    Iowa
    2019 TRD PRO
    Got my RXT leaf pack installed, this was exactly what i needed. Running option 2.
  19. Jun 22, 2019 at 2:46 PM
    Hartc90
    Hartc90 New Member
    Just FYI you might wanna look at the abs and brake line relocation parts. Wheeler off road and coachbuilder sell it. I bought the wheeler off road one. It’s old man emu which is a good brand from what I understand.
  20. Jun 22, 2019 at 2:49 PM
    TheBeast The Beach
    I have the coachbuilder set. Nicely made. Easy install.
  21. Jun 22, 2019 at 3:04 PM
    JDL17CM4x4
    Daniel
    Riverside, CA
    More to Come ...
    Very nice! With that much weight in the back why did you not opt for the 750 load option #3?
  22. Jun 22, 2019 at 7:38 PM
    shellshock
    Iowa
    2019 TRD PRO
    Running about 350-400 lbs for the habitat plus gear. Icon recommend option 2 as well as the place I bought them through. It’s been spot on. I’ve got about 300 miles on it so far and zero complaints.
    With my current load, the rear is still a bit higher than the front. Option 3 would have been too much. Changing the spring config is pretty easy so I can always add that in down the road if I add more weight.
  23. Jun 22, 2019 at 7:40 PM
    shellshock
    Iowa
    2019 TRD PRO
    We had it at full droop and there’s still some slack in the lines. I’m definitely going to keep an eye on it though as I’d much prefer to not break them.
  24. Jun 22, 2019 at 7:47 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Did you use the same centering pin for option 2 as option 1? I need to do this soon and don’t think I have the instructions.
  25. Jun 22, 2019 at 7:50 PM
    shellshock
    Iowa
    2019 TRD PRO
    joonbug[QUOTED] likes this.
  26. Jun 22, 2019 at 8:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  27. Jun 23, 2019 at 1:58 PM
    shellshock
    Iowa
    2019 TRD PRO
    Better picture
  28. Jun 24, 2019 at 7:58 AM
    JDL17CM4x4
    Daniel
    Riverside, CA
    More to Come ...
    Wow that camper is lighter then i thought. Nice choice and looks great!!!!
  29. Jun 25, 2019 at 7:50 PM
    BL4CKS4IL5
    BL4CKS4IL5 New Member
    Johan
    2012 Toyota Tundra
    What do you recommend for just running an RTT?
  30. Jun 25, 2019 at 7:58 PM
    shellshock
    Iowa
    2019 TRD PRO
    RTT plus bed rack would likely be pretty close to the same weight, I’d probably go option 2 (250-500 lbs over stock)
