ICON Delta Joint Retro Fit Kits now at TOYTEC LIFTS
Discussion in 'Suspension' started by Toytec Lifts, Jun 6, 2017.
  1. Jun 6, 2017 at 7:49 AM
    Toytec Lifts
    Toytec Lifts [OP] New Member
    Denver, CO.
    Check out what just came in stock here ToyTec Lifts!!
    The new ICON Delta Joint Retrofit Kits for the 07+ Tundras and 05+ Tacoma's
    http://toyteclifts.3dcartstores.com/614550--ICON-Delta-Join…
    We also have the tool in stock to swap out the traditional Uniball in the Icon Arms.
    http://toyteclifts.3dcartstores.com/614519--ICON-Delta-Join…
    *** If you have the Billet uppers the tool will be different.
    KEY FEATURES:
    • Patent pending Delta Joint combines the durability of a ball joint with the performance characteristics of a traditional uniball
    • Sealed design and zinc plated housing protects Delta Joint from the elements, road salts, and other debris
    • Metal on metal internals and a greasable design for maximum longevity and noise-free operation
    • Capable of high angularity required for lifted applications
    • Carburized taper pin provides increased corrosion resistance, decreased internal friction, and less chance of thread galling on assembly
    • Pullout strength greater than comparable industry standard uniball
    • Application specific taper pins for precise fit across a wide range of vehicles
    • 5 Year ICON Limited Warranty (When used with ICON Vehicle Dynamics suspension components, visit www.iconvehicledynamics.com/deltajoint for more info)
    Let me know if you have any questions!!!
    -David
    Law323 and T-Rex266 like this.
  2. Jun 6, 2017 at 7:52 AM
