SOLD: Icon AAL, OEM upper control arms, leafs, swaybar links, etc.
Discussion in '1st Gen Tundra Parts Marketplace (2000-2006)' started by shifty`, Oct 4, 2023.
Thread Status:
Not open for further replies.
  1. Oct 4, 2023 at 11:21 AM
    shifty` [OP] Just like witches at black masses
    Here's some low-mile pulls from my 2006 V8 4WD access cab. The Icon kit has under 50 miles usage, everything else is 75k miles new and has decent life in it, especially if you have a northern truck! Everything in excellent shape, rust-free, bind free.
    I'm open to offers on anything!
    Will meet/handoff within ~1h of Atlanta for the low-low price of: Your favorite cold beer. :cheers:
    .... Or I can ship on your dollar.
    Pics below, here's where I am on pricing, some part notes follow:
    • Icon 51100 add-a-leaf (0.75" lift) *****SOLD*****
    • OEM upper control arms: *****SOLD*****
    • OEM swaybar links: *****SOLD*****
    • OEM leaf packs w/overload, w/u-bolts: *****SOLD*****
    • OEM front struts**: *****SOLD*****
    Icon add-a-leaf: Install guide here. Expect 3/4" lift but you can't keep your overload leaf installed with it. You'll need an 8" u-bolt kit, Icon's p/n is 52050, it hovers in the $55-65 @ fleaBay and sites like this. Centering pin is serviceable shape w/plenty of extra threads, you'll cut-to-length during install. I needed more lift, so I upgraded to leaf packs.
    Uppers - Bushings in serviceable shape, zero rust, will shine right up.
    Links
    : Links are fine, serviceable, bushings are a little worn but cost almost nothing to replace.
    Struts: The front struts, springs are superb, one shock bodies shows some damage to the plastic dust shield, mount bushings are not blown yet; I'm basically giving these up b/c I'm sure someone can use the OEM springs, buckets, isolators, etc. there is a LOT to be pilfered from these.
    Leaf springs - OEM run $750/ea right now. Bushings great, all shims intact, part# are 48210-AF131 (RH) and 48220-AF131 (LH) to confirm fitment. U-bolts pristine, no visible stretch, 1st time they've been removed.
    Pics pics pics
    Icon add-a-leaf:
    OEM uppers, swaybars, struts w/HD springs:
    OEM Leaf packs:
  2. Nov 1, 2023 at 1:04 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I sure could use your OEM leaf springs with U bolts (I have an 04 AC...I think they're the same). Would you consider shipping them to 21146?
    Edit:
    48220-0c040 is the driver side, and 48210-0c040 is the passenger side for 2000-2004. 2005-2006 may be different.
  3. Nov 1, 2023 at 6:20 PM
    Yup, not sure the differences. Wouldn't it suck to freight this up only to find out they won't work?
    ToyoMafia likes this.
  4. Nov 2, 2023 at 4:25 AM
    w666
    Maryland
  5. Nov 2, 2023 at 7:33 AM
    It may be it's the case!
    I wonder if we may also find someone going south to north who may be passing through. I made the trip from FL to BK a number of times in my earlier years, and I see plenty of NY tags cruising through on the interstate. I'd totally kick someone on here $50 if they'd toss these in the back of their truck on the way up, and even meet them at a gas station right off the interstate so all they need to do is stop for a piss break while I load up.
    I'm less than 10 minutes from I-75/85, I-285 and I-675 bypasses, and I-20, I can catch someone going any number of directions pretty easily.
  6. Nov 5, 2023 at 12:28 PM
    w666
    Maryland
    I haven't found any more info that tells me your springs are different than mine. What brought me to this page originally was your comment on another thread that you'd be willing to let them go for 1/2 price. That being the case, I'm willing to take the calculated risk they they won't work. Are you still good with $100?
    I haven't any idea how to get them to me other than UPS/FedEx heavy weight. The springs I'm shopping at ATS show shipping for ~ $75 for example. I can spend ~$100 shipping to get them. Most of what I read online says to ship them individually, without any packaging. I can't imagine there would be any way to damage them. I might wrap them in brown paper and shrink wrap, but only for cosmetics. Either UPS or FedEx ground seems suitable. If you agree to all of this, I have access to great pricing. The hassle for you is only to label them and get the to the shipper. Let me know what you think...
    Will
  7. Nov 5, 2023 at 5:46 PM
    Honestly, I'm good with that if you're paying freight but I gotta figure out how the hell to get the damn things to you. :rofl:
    They really should be metal-banded. Tape ain't gonna cut it. These weigh probably ~60lb each, once banded, 120lb is a lot for a delivery company to be lugging around. When my ATS springs got here, the Fedex driver made ME come out to the truck and carry them off the lift gate!
    FishNinja likes this.
  8. Nov 6, 2023 at 2:39 AM
    w666
    Maryland
    Agreed. That's why I suggest shipping them separately. Each piece should be well under the weight limit for FedEx.
  9. Nov 6, 2023 at 9:26 AM
    Yeah, it's totally possible. I'll hafta take measurements.
    It may also be worthwhile to see if we can score a truck passing thru.
  10. Nov 7, 2023 at 5:40 AM
    w666
    Maryland
  11. Nov 7, 2023 at 6:03 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    there is a slight difference, but not enough to matter. I've had bmf's leafs (02), wumbo's (06 AC), and FT's (06 DC) same enough to interchange, but slightly more meat on the AC springs compared to DC.
    shifty`[OP] and w666[QUOTED] like this.
  12. Dec 2, 2023 at 8:45 AM
  13. Dec 5, 2023 at 3:49 PM
    rtom
    rtom New Member
    03 AC tundra
    bilsteins, 285/75/16,
    how much for the upper control arms shipped to 06242
  14. Dec 5, 2023 at 5:12 PM
    How's $100 shipped sound?
  15. Dec 5, 2023 at 5:20 PM
    $99.99
  16. Dec 5, 2023 at 5:21 PM
    $99.98, and that's my last offer! :rofl:
    T-Rex266[QUOTED] likes this.
  17. Dec 5, 2023 at 6:00 PM
    shifty`[OP] likes this.
  18. Mar 17, 2024 at 10:48 PM
    voodoo2626
    voodoo2626 02 AC 4.7 V8 2WD
    Harry
    Louisiana
    02 SR5 2WD 4.7 V.8 366k
    Plastic bed lining, storm floor mats. Nothing special
    Upper Control Arms still available?
  19. Mar 18, 2024 at 5:40 AM
    They are technically, but I told another member I'd grab the box and pull the part numbers to check if they're compatible. Let me round back with them (the last 1-2 months has been chaos at work), and I'll tag you here if they're not taking them.
    voodoo2626[QUOTED] likes this.
  20. Mar 18, 2024 at 3:07 PM
    @voodoo2626 I can confirm: I did promise these to another member in the Atlanta area. I totally spaced on it, and never came back to update this post. I've marked all items above that are currently taken.
    I think @FishNinja was interested in the AAL kit, but I haven't heard back on that one either.
    voodoo2626 likes this.
  21. Mar 18, 2024 at 3:22 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    nahhhhh I'm gonna get ATS
    shifty`[QUOTED][OP] likes this.
  22. Mar 18, 2024 at 3:22 PM
    Smart man!
  23. Apr 8, 2024 at 7:19 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    @shifty` are the Icon AALs still sitting around? I know you weren't a huge fan of them but they might fit my needs. Im not looking for big lift or offroad performance but I do think I need a little more support out back as my stock leaf packs seem tired.
    I have a buddy running around Atlanta for work this week and might convince him to throw them in his trunk.
  24. Apr 8, 2024 at 7:23 PM
    Yup, still sitting on my garage floor. Last thing left for sale. Happy to meet wherever. It's like Friday everyday in my world ever since the layoff.
    Burgmane[QUOTED] likes this.
  25. Apr 8, 2024 at 7:33 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    I will coordinate with him in the AM, if I can arrange it I'll let you know. Thanks!
  26. Apr 8, 2024 at 9:04 PM
    Cool, let me know I’m super flexible and will drive anywhere within ~20 miles of the I-20 and 75/85 cross downtown, as long as it’s before 2pm.
  27. Apr 9, 2024 at 12:43 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    Pm sent
  28. Apr 10, 2024 at 11:40 AM
    Bumping for SOLD closure.
    T-Rex266 and FrenchToasty like this.
Thread Status:
