I want to change my own oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockanock, Jan 10, 2020.
  1. Jan 10, 2020 at 8:45 PM
    Rockanock
    Rockanock [OP] 21 Chevy 2500
    After crawling under my truck today after a recent oil change from the dealer, I noticed that they splashed oil everywhere. They also left out three screws that hold the plastic piece of the bumper to the skid plate. It was obvious they didn’t care what they were doing. This worries me as I hope they did not over tighten everything. I have watched a few YouTube videos on how to change the oil in our trucks. Seems pretty easy. My first question is, how tight should I tighten the drain plug and also the filter housing. Should I lube the new o’ring with the oil also? And what oil filter wrench do y’all recommend as well as filter and oil? I’ve always ran full synthetic in my trucks. Usually Rotella T6. Is this still a good choice for our trucks? What oil weight is recommended as well? And I do believe the owners manual states 8.5 quarts is what it holds. Also, will this be more cost effective in the long run or, does it cost about the same to have a jiffy lube do it. Thank you
  2. Jan 10, 2020 at 8:49 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There is a cap socket available on Amazon that you need for the filter housing. Only ten bucks or so
    Other than that it is very simple. Pull skid plate, drain oil, drain filter housing, then unscrew filter housing. Simple and you’ll be a better human for doing so
  3. Jan 10, 2020 at 8:51 PM
    Rockanock
    Thank you for the tips. I’ll go check out Amazon
  4. Jan 10, 2020 at 8:55 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Man card much?
  5. Jan 10, 2020 at 8:56 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    plumber802 likes this.
  6. Jan 10, 2020 at 9:12 PM
    Rockanock
    I never even knew that tool was a thing.
    I used to do it a long time ago but decided to let the dealer or pennzoil do it. Recently I have had some certain circumstances come up in my life that any extra dollar I can save, helps.
    jewsNbrews likes this.
  7. Jan 10, 2020 at 9:18 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
  8. Jan 10, 2020 at 9:19 PM
    Rockanock
    That is the tool I was lookin at shellshock.
  9. Jan 10, 2020 at 9:35 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I use the MotivX wrench and drain tool as well. I run 0W-20 Toyota oil but many here run Mobil1. 04152-YZZA4 is the Toyota filter part number. Filters are available on Amazon but I get mine from the dealer and they always give me a drain plug gasket. You'll want to change the drain plug gasket at each oil change. Something else to consider is changing the plastic filter housing out for the aluminum one. As far as torque specs... 30 ft/lbs on the oil pan drain plug, 18 ft/lbs on the filter housing, 9 ft/lbs on the housing drain plug, 21 ft/lbs on the skid plate bolts and 48 in/lbs on the three screws the dealer forgot to put back in.
  10. Jan 10, 2020 at 9:40 PM
    Rockanock
    invaluable info, thank you much
  11. Jan 10, 2020 at 10:28 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2, i have to agree
  12. Jan 10, 2020 at 10:44 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    same torque specs i use. i do run 0W-20 mobil1.
    call me a cock-eyed optimist, but i do not change the drain plug gasket. i do change the filter housing, and filter plug gaskets though. they're included with the OEM filter.
    i may get flamed for this, but i do not use any of the fumoto plugs, e-z drains, whatever you want to call em. :crapstorm:
    remove drain plug, let drain for 15 minutes. replace drain plug w/ torque specs above = done.
    just dont like the idea of any road debris hanging up on the lever and draining my oil pan. maybe i am paranoid.
    again, i may get flamed, but any 0W-20 oil from a reputable company should do just fine. i do use OEM filters, and buy several at a time; they're a couple of bucks each.
    additionally, i've kept the "plastic" filter housing... no issues, 4 oil changes. some members here prefer the aluminum replacement.
    i do change every 5k... i cannot EVER see myself going 10k like OM suggests for "normal" conditions.
    oil is VERY DARK after 5K
    do it yourself, know it's done right, drive it one million miles.:woot:
    Toyotoholic likes this.
  13. Jan 10, 2020 at 11:41 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    You should go back to the dealer and tell the service manager what happened.
  14. Jan 11, 2020 at 3:12 AM
    Rockanock
    I’ve considered this. I’m not entirely sure what I’d get out of it.
  15. Jan 11, 2020 at 3:55 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Been changing my oil since I was old enough to DRIVE !!
    Did my first change on my 18’ @ 2500k just to get out any “break-in” debris etc and get in my choice of oil ASAP
    MOBIL 1 0w20
    Aluminum housing
    Motivx wrench/ drain tool/ hose
    Fumoto valve- ( first time using this product-
    Also skid plate will protect from debris)
    Will change oil every 5k -
    ( 10k is crazy to me )
    Also rotate tires at every oil change
    Air filter & cabin filter every 10k
    (some say too soon)
    Oil pump - WTF !!
    Never herd of such a thing
    Talk about MAN card !!
    JM2C- you do you !!
  16. Jan 11, 2020 at 4:09 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    Check your owners manual for the correct amount of oil. My '07 Tundra with the 5.7 called for 7.5 quarts and my '17 5.7 calls for 7.9.
  17. Jan 11, 2020 at 5:08 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  18. Jan 11, 2020 at 7:18 AM
    Done That
    Done That New Member
    The Motivx kit is great. Also purchased the oem metal cap and a fumoto, got the locking clip for it so I'm not too worried about it. Went super easy thanks to all the great tips on this forum.
    41bigdawg likes this.
  19. Jan 11, 2020 at 7:38 AM
    classiccat
    classiccat New Member
    2017 Tundra Limited SuperWhite
    Don't blame you OP @Rockanock ! Oil changes are a gateway drug to servicing your brakes, 4x4 (diffs/xfer case), power-steering, coolant, ujoints........!
    I started using an EWK extractor last year ("only" holds ~ 6qts so you have to stop mid-way since ours hold ~8qts). It will suck out every lost drop; skeptical at 1st, I pulled the drain plug...not a drop came out. Very versatile tool.
    plumber802 and wakeboarder like this.
  20. Jan 11, 2020 at 9:18 AM
    Rockanock
    Awesome deal! I may have to check out these extractors.
    does anyone have a link to metal OEM filter cap metal always makes me feel better than plastic
  21. Jan 11, 2020 at 9:34 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
  22. Jan 11, 2020 at 9:45 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Just funning ya. I change my oil on vehicles that I don't want monkeys screwing around under it.
  23. Jan 11, 2020 at 9:48 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Always cheaper to do it yourself. Filter costs $4 and I recently bought 6 5qt jugs of Valvoline 0w20 for $11 per 5qt jug. So it's going to cost me less than $20 to change oil.
  24. Jan 11, 2020 at 9:51 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Also, someone told me you can get jug of Mobil 1 at Walmart much cheaper than the parts store. Something like low $20 range.
  25. Jan 11, 2020 at 9:54 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You can if you catch it on sale. Most of the time it hovers around $24-25. Cheapest I've found it was $19.
  26. Jan 11, 2020 at 9:54 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Just make sure any jug you purchase at wally world is properly sealed. And any filter is the proper one in the box. I've heard of folks returning used oil and getting a refund. Even water in the jug, then it goes back on the shelf. And seen first hand a few owners coming into my garage having paid for a premium filter to see a supertech stuffed in the box.
    Inspect your parts before leaving the aisle/store.
    TWJLee, Twinky, 15whtrd and 1 other person like this.
  27. Jan 11, 2020 at 9:56 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    THIS. I always look at what's in the box and look for missing pieces in whatever I buy from there.
  28. Jan 11, 2020 at 10:10 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s where I get it. Usually right around $24-$25. This last time I picked up some Pennzoil 0- 20 for $22. a 5 quart jug.
    Twinky likes this.
  29. Jan 11, 2020 at 10:12 AM
    15whtrd
    15whtrd Mr. Blonde
    Whoever does that deserves a punch in the mouth. Someone else is always out there trying to screw someone else over.
  30. Jan 11, 2020 at 10:16 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Well nothing for what happened but it's always good to make them aware of poor service like that for the future.
    15whtrd likes this.
