I think my check engine light was disconnected for the sale
Discussion in '1st Gen Tundras (2000-2006)' started by Robpad29, May 23, 2024.
  1. May 23, 2024 at 6:23 PM
    Robpad29
    Robpad29 [OP] New Member
    Robert
    Miami, Fl
    2006 silver access cab
    Stock
    I’ve had my tundra for a few weeks now, I’ve replace the air filter, new plugs and upstream 02 sensors. Just to be safe. Today I hooked up my new mini ultra gauge and the alarm went showing a P0016 code. I hooked up my code reader and I also got a P0018 code. But the check engine light has not come on. I noticed it doesn’t come on when you turn on the ignition also. So I’m thinking the previous owner disabled it for the sale. I also pulled the right timing belt cover to check the belt, seems ok, with a little wear.
  2. May 23, 2024 at 6:32 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
    Darn. That’s too bad. If it was a dealer I’d take it back and make him pay me.
    That light can be temporarily reset, may be what happened. It comes back on in 50 or 100 miles or something if the problem’s still there.
  3. May 23, 2024 at 6:33 PM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    It's easy to pull the gauges and replace the bulbs.
    https://youtu.be/zIaFkWv-mSw?si=ChRPZdIjt2ZW7b25
  4. May 23, 2024 at 6:34 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    JasonC. likes this.
  5. May 23, 2024 at 6:35 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Definitely sound alike it's been pulled or burnt out. When I was an inspector, we always checked functionality of the CEL by watching all the dash lights come on with the key turn without starting the engine, specifically for this reason
    JasonC.[QUOTED] likes this.
  6. May 23, 2024 at 7:31 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    @455h0le_dachshund you're right, I missed this in the OP.
  7. May 24, 2024 at 5:14 AM
    shifty` In South Dakota Trouble ain't hard to find
    Hopefully it's not even the sensor, just a wire is nicked or something easy to repair.
    Riverdale21[QUOTED] likes this.
  8. May 24, 2024 at 9:31 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    It's an 06. That means it's an LED soldered to the circuit board right?
  9. May 24, 2024 at 9:41 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I was under the impression that was only the gauge lights, but I could be wrong.
